NL2X output configuration
DJ dyNASTY
PostPosted: Wed Jan 22, 2014 3:40 pm    Post subject: NL2X output configuration
Subject description: All sounds as one instrument
Hello fellow electro musicians!
I just have a quick question regarding the Nord Lead 2X
I realize that the Nord Lead 2X is 4 part multi timbal and the way I've always used it has been to sequence each of the 4 layers (parts) on its on instrument track in logic. (Each one Mono)
I've always wanted to have the ability to sculpt all 4 parts as one through a filter in the Nord and treat them as one patch. Is this possible via another output configuration?
Right now it just feels like I've got 4 Nord leads outputting from one synth, each part playing something different with no way to modulate or filter everything as one (other than note pitch)
So just to clarify, I'm not really looking to control 4 filters at the same time , what if love to do is sculpt 4 layered sounds with one filter and then treat that as one instrument in logic
Thanks in advance guys!
I really appreciate your input!
Don
Audio files: 347
PostPosted: Wed Jan 22, 2014 4:04 pm    Post subject: Re: NL2X output configuration
If you control all 4 filters in the same way, it would be like having just one filter, no? Through some clever MIDI routing you could have the filter knob control the filters in all the parts at the same time, it may sound like it is one filter.
There is no way that you can have all 4 parts go through one filter internally in the 2X.
Muied Lumens Base Star
DJ dyNASTY
PostPosted: Thu Jan 23, 2014 2:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Muied Lumens!
Thanks for your response, ya this is what I figured, I just wanted to make sure
Cheers !
