Yusynth VCLFO2 problem
Page 1 of 1 [6 Posts]
yoopee
PostPosted: Fri Jan 24, 2014 2:38 pm    Post subject: Yusynth VCLFO2 problem Reply with quote  Mark this post and the followings unread
hello,
thanks for this wonderful modular diy project.
I'm building few of this modules, now trying to trim the VC LFO2 module.
The pulse and sawtooth waveforms are ok, but triangle and sinus are distorted as you can see on attached screenshots.
I tried to change U3, checked R19,R20,R21,R22,R23,R24, diodes D1,D2
and everything looks ok...
any suggestions what else to check?
thank you
yoopee
PostPosted: Fri Jan 24, 2014 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
uh, I've attached wrong screenshots,these are correct
 Filesize:  18.65 KB
 Viewed:  221 Time(s)
 Filesize:  18.25 KB
 Viewed:  245 Time(s)
marfoski
PostPosted: Fri Jan 24, 2014 11:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's a known quirk of this circuit, something you have to live with, in a sense.
Take a look at this : http://electro-music.com/forum/viewtopic.php?highlight=lfo&t=44023
yoopee
PostPosted: Sat Jan 25, 2014 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you! So my VCLFO is trimmed okay...
kupfer_m
PostPosted: Sat Aug 02, 2014 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
So there's nothing that can be done to get rid of these spikes?
gibrancurtiss
PostPosted: Sat Apr 08, 2017 7:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
PLease, check this:
http://electro-music.com/forum/topic-44023.html&postorder=asc&highlight=lfo&start=25
