A new book by Thomas Henry - The PICAXE 18M2 Cookbook!
Tim Servo
PostPosted: Tue Jan 28, 2014 12:59 pm    Post subject: A new book by Thomas Henry - The PICAXE 18M2 Cookbook! Reply with quote  Mark this post and the followings unread
Announcing a new book by Thomas Henry - THE PICAXE 18M2 COOKBOOK!! A great introduction to using and programming the PICAXE Microcontroller, this book covers a wide range of topics in an easy to read step-by-step guide. Available this Sunday (Jan 26th) from the Magic Smoke Electronics print to order service at:
www.lulu.com/spotlight/magsmoke
I've also posted this on the Thomas Henry forum, but I thought I'd add it here to see who might be interested!
 Filesize:  418.08 KB
 Viewed:  179 Time(s)
Tim Servo
PostPosted: Tue Jan 28, 2014 1:03 pm    Post subject: A new book by Thomas Henry - The PICAXE 18M2 Cookbook! Reply with quote  Mark this post and the followings unread
And for those of you looking for a Table of Contents:
CHAPTER 1 FIRST STEPS
WHAT’S INSIDE THE PICAXE 18M2?
PLAN OF ATTACK
OVERVIEW OF THE PROGRAMMING PROCESS
A FEW WORDS ABOUT THE PINS
SOME HARDWARE CONSIDERATIONS
WHAT ABOUT THE VARIABLES?
CHAPTER 2 OUTPUT DISPLAYS
PROJECT 1: SERIAL OUTPUT TO A PC
PROJECT 2: LIGHT AN LED
PROJECT 3: LED DIMMER
PROJECT 4: BICOLOR LED
PROJECT 5: TRICOLOR LED — I
PROJECT 6: TRICOLOR LED — II
PROJECT 7: TRICOLOR LED — III
PROJECT 8: TEN-STAGE LED DOT DISPLAY — I
PROJECT 9: TEN-STAGE LED DOT DISPLAY — II
PROJECT 10: TEN-STAGE LED DOT DISPLAY — III
PROJECT 11: TEN-STAGE LED BAR GRAPH — I
PROJECT 12: TEN-STAGE LED BAR GRAPH — II
PROJECT 13: DIRECT 7-SEGMENT DISPLAY
PROJECT 14: MULTIPLEXED TWO-DIGIT 7-SEGMENT DISPLAY
PROJECT 15: LATCHED TWO-DIGIT 7-SEGMENT DISPLAY
PROJECT 16: SERIAL TWO-DIGIT 7-SEGMENT DISPLAY
PROJECT 17: QUAD 7-SEGMENT DISPLAY
PROJECT 18: INCANDESCENT LIGHT BULB
PROJECT 19: PARALLEL DATA LCD
CHAPTER 3 DIGITAL INPUT
PROJECT 20: SPST SWITCH
PROJECT 21: CENTER-OFF TOGGLE SWITCH
PROJECT 22: DIGITAL JOYSTICK
PROJECT 23: BINARY SWITCH
PROJECT 24: FOUR-BIT GRAY ENCODER
PROJECT 25: MATRIX KEYPAD
PROJECT 26: SLOTTED OPTO SWITCH
PROJECT 27: TOUCH SWITCH
PROJECT 28: INFRARED REMOTE CONTROL
PROJECT 29: HANDCLAP SWITCH
PROJECT 30: 60HZ TIMEBASE
CHAPTER 4 ANALOG INPUT
PROJECT 31: POTENTIOMETERS
PROJECT 32: CADMIUM SULPHIDE LIGHT SENSOR
PROJECT 33: HOMEBREW PRESSURE SENSOR
PROJECT 34: TEMPERATURE SENSOR
PROJECT 35: ENVELOPE AMPLITUDE DETECTOR
CHAPTER 5 ANALOG OUTPUT
PROJECT 36: THREE-BIT DAC
PROJECT 37: FOUR-BIT DAC
PROJECT 38: FIVE-BIT DAC
PROJECT 39: PRECISION 7-BIT DAC
PROJECT 40: THREE OPTIONS FOR AUDIO OUTPUT
PROJECT 41: EASY DRUM VOICE
CHAPTER 6 MOTOR CONTROL
PROJECT 42: DC MOTOR SPEED CONTROL
PROJECT 43: DC MOTOR DIRECTION CONTROL–I
PROJECT 44: DC MOTOR DIRECTION CONTROL–II
PROJECT 45: UNIPOLAR STEPPER MOTOR CONTROL
PROJECT 46: BIPOLAR STEPPER MOTOR CONTROL
CHAPTER 7 ODDS AND ENDS
PROJECT 47: INFRARED TRANSMITTER
PROJECT 48: RESET SWITCH
PROJECT 49: LOW VOLTAGE ANALOG SWITCH
PROJECT 50: BIPOLAR ANALOG SWITCH
PROJECT 51: ADJUSTING THE INTERNAL CLOCK FREQUENCY
PROJECT 52: INTERNAL SR LATCH
PROJECT 53: I2C DATA EEPROM
PROJECT 54: MIDI OUTPUT
PROJECT 55: MIDI INPUT
PROJECT 56: ULTRASONIC RANGING DEVICE
RESOURCES
