adc distortion?
jbucks
PostPosted: Fri Feb 07, 2014 7:07 am    Post subject: adc distortion? Reply with quote  Mark this post and the followings unread
Hey everyone, just starting to do a bit of ChucK again a few weeks after the Coursera course finished.
I'm trying to use ChucK to sample my modular synth through my Presonus audio interface. To keep things simple, I've got a sine wave pulse going into ChucK like this:
adc.chan(0) => Gain inGain => dac;
0.2 => inGain.gain;
while ( true ) {
    2::second => now;
But the sine wave comes through with distortion, sounds almost like it's being amplitude modulated. When I listen to that sine wave through a DAW, it sounds perfect.
What am I doing wrong?
jbucks
PostPosted: Fri Feb 07, 2014 9:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Found a clue: changing the buffer size in miniAudicle causes different kinds of distortion… so at least one step closer to figuring out the problem.
EDIT: fixed, looks like setting the buffer size to 512 did the trick.
Audio files: 332
G2 patch files: 99
PostPosted: Fri Feb 07, 2014 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad to see that you were able to solve it. Yeah non-standard settings can cause all kinds of weird behaviour in the audio interfaces. When I use multiple inputs and/or outputs on my Motu Ultralite, there are only a few specific configurations that work. I can for instance set ChucK to use 4 or 8 outputs, but if I try setting output count to 6 I get behaviour similar to what you describe; screeching distortion coming from all ouputs at once etc.
