help demistify vcf's please
tegleg
PostPosted: Fri Feb 07, 2014 5:30 pm    Post subject: help demistify vcf's please
Subject description: having trouble getting my head round a few things
hello
sorry for the vague title.
i can make a basic hi or lo pass filter with a resistor and a capacitor, the resistor of course controls the cutoff.
i can make for example a 'decay' circuit that smoothly drops from +9v to 0 that is triggered from a sequencer.
how would i (in as few analog parts as possible) make that voltage controll the filter cutoff?
i can't get my head round how to replace a resistor with a voltage in a circuit like that. i can add some pictures is somethings not clear.
thanks for any help
JovianPyx
Audio files: 190
PostPosted: Fri Feb 07, 2014 5:48 pm    Post subject: Re: help demistify vcf's please
tegleg wrote:
hello
Both the resistor and the capacitor control cutoff.
thanks for any help
First, the filter you described above is the simplest and least interesting of all filters. It is a single pole filter. If you want the kind of sounds you hear from modular synthesizer filters, then you want a filter with more poles - at least 2. There are many types. It depends on what you're after as to which filter is best. An easy to build filter that has the control aspects you described (voltage control over cutoff) would be the state variable filter. This can be done with an LM13700 IC - there are many many schematics for this filter type on the web. Just google "analog state variable filter" as a starting point.
Time flies like a banana.
corruptio optimi pessima
tegleg
PostPosted: Sat Feb 08, 2014 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
thats exactly what i needed thank you
its sometimes difficult to find something if you dont know what its called.
Smile
