 Forum index » Instruments and Equipment » Eventide
Eventide Eclipse Remote Control app for iPad/iPhone
Post new topic   Reply to topic Moderators: Dougster
BobTheDog
Audio files: 32
PostPosted: Thu Feb 13, 2014 3:57 am    Post subject: Eventide Eclipse Remote Control app for iPad/iPhone Reply with quote  Mark this post and the followings unread
Now available in the App Store.
The Eclipse Remote Control app allows you to remotely control an Eventide Eclipse using either an iPhone or iPad running iOS 5 or above.
Key-presses can be sent from the app to the Eclipse and the Eclipse display is mirrored onto the apps display.
The app supports network midi over WIFI or Bluetooth and uses Bonjour to find any network midi connections on the local network.
The app also supports any Core Audio compliant midi interface connected to the device.
The app works by sending midi commands for the button presses to the Eclipse, it then sends a command to get the screen data from the Eclipse and displays an image of it.
The app supports landscape and portrait on the iPad. Portrait is not supported on the iPhone.
Limitations:
The Encoder on the Eclipse is not supported due to limitations in the Eclipse Sysex.
There are some limitations in how the eclipse display is displayed in the app.
For example if you are in the modulation setup and you have a source of an LFO, on the actual Eclipse display you will see a bar-graph animating with the varying value, you will not see this on the app display. The reason for this is that the the screen data is transmitted over midi Sysex and this is too slow to show these sorts of animations.
Details, images and video here: http://www.iosaudio.co.uk/IOSAudio/EclipseRemote.html
App Store: https://itunes.apple.com/gb/app/eclipse-remote-control/id814413514?mt=8
