Steiner Parker filter v.2 rotary switch
oneoff
PostPosted: Sun Feb 23, 2014 7:41 am    Post subject: Steiner Parker filter v.2 rotary switch Reply with quote  Mark this post and the followings unread
Can I use a 2 pole 4 positions rotary
Switch instead of the 3 poles 4 positions that's
Recommended ? As I can see in the schematics
There is no use for the 3rd pole ...
Am i missing something here?
oneoff
PostPosted: Mon Feb 24, 2014 10:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Anybody?? Rolling Eyes
PostPosted: Mon Feb 24, 2014 9:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
A link to the schematic might help Smile
marfoski
PostPosted: Mon Feb 24, 2014 10:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Of course you can. But since most of 2 pole rotary switches are actually pre-configured as 2 pole 6 positions, you may have to reduce the travel of the switch to four using the keyed ring which is on top, under the nut. Those rotary switches are all mechanically the same, only the electrical wiring change, so I assume that Yves used the 3 pole 4 positions for sake of simplicity.
oneoff
PostPosted: Tue Feb 25, 2014 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks !
