Trying to play an array of Noise objects
Someone...
PostPosted: Mon Mar 10, 2014 5:22 am    Post subject: Trying to play an array of Noise objects
Subject description: but getting no sound. There are no syntax errors.
Noise noiseArray[10];
LPF lpfArray[10];
0.1 => float gain;
200.0 => float lpfFreq;
//initialize values for the noises in the array
for (0 => int i; i <10> lpfArray[i] => dac;
    gain => noiseArray[i].gain;
    0.01 -=> gain;
    lpfFreq => lpfArray[i].freq;
    20 +=> lpfFreq;
//play all the noises
while (true){
    1::second => now;
So I'm trying to make an array of noises with different low pass filters on them and play all these noises at the same time but I'm getting no sound.
G2 patch files: 99
PostPosted: Wed Mar 12, 2014 12:12 am    Post subject: Reply with quote  Mark this post and the followings unread
It's difficult to see since your code has been mangled a bit - please click the "Disable HTML in this post" and "Disable Smilies in this post" checkboxes when posting code.
Someone...
PostPosted: Wed Mar 12, 2014 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow, it really did get mangled. I didn't even notice. I'll be sure to disable HTML and smilies in the future...
Embarrassingly enough... the code I wrote works. It wasn't working when I posted that message but it started working when I opened it up and ran it 2 days later. No idea why. I suppose I'll post the working code in case anyone is curious.
LPF lpfArray[10];
0.1 => float gain;
for (0 => int i; i < 10; i++){
    noiseArray[i] => lpfArray[i] => dac;
    0.01 -=> gain;
    20 +=> lpfFreq;
while (true){
    1::second => now;
G2 patch files: 99
PostPosted: Thu Mar 13, 2014 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Heh glad you got it working. Smile Maybe it was some audio interface issue or something, like if you have more than one soundcard to choose from?
Someone...
PostPosted: Fri Mar 14, 2014 7:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm not sure... I only have a built in soundcard. Now I'm getting practically the same problem (which I posted in another thread) but I've closed it and gone back to it twice over the past few days and still no sound.
