Echo Rockit - LFO, Osc, and Dry"Bypass" Signal on Output
maxdemian
PostPosted: Thu Jun 05, 2014 12:11 pm    Post subject: Echo Rockit - LFO, Osc, and Dry"Bypass" Signal on Output
Subject description: propably an easy fix but i just dont get it at the moment
Hello
I just finishes soldering and Front Panel Wiring for the Echo Rockit.
the thing is,
I always have a dry Signal on top(actually I have true bypass, even when the Unit is turned off)
I always hear the Oscilator even if its turned Off
I also hear the Square Wave from the LFO
hmmmmm....
Shocked
best max
sndbyte
PostPosted: Fri Jun 06, 2014 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
How loud is the osc/lfo sound that you are hearing? I have noticed the osc when it is turned off but it is a faint sound that is difficult to hear.
maxdemian
PostPosted: Sat Jun 07, 2014 1:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
it did not really make a difference if it was turned on or off
i cant check it now as it is in my studio, but as i remember the lfo sqr wave and the osc where also going thru the filter/delay, but i am not 100% sure about tthe LFO now...
propably it is 2 problems:
1. The input signal is always coming thru, even when turned off, maybe some shortcut on the front panel?
2. the osc/lfo thing
maxdemian
PostPosted: Thu Jun 12, 2014 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
ok i found it more or less, messed up some wiring.
but the delay is extremely noisy, tried 2 pt2399 not that much a difference.
maybe change some capacitors?
