Joined: Apr 03, 2004 Posts: 24493 Location: The Netherlands, Enschede
Posted: Thu Oct 23, 2014 4:53 pm Post subject:
Musics for sun and moon |
First here was a scream, then there was a ligtht.
All according to http://eclipse.gsfc.nasa.gov/solar.html
the date was 2014, October 23
PHOBoS started streaming - I mixed it all up somehow.
| Quote: | | "This is the 9th eclipse of Saros 153 (Espenak and Meeus, 2006). The series began on 1870 Jul 28 with a string of 13 partial eclipses. The first of 49 annular eclipses begins on 2104 Dec 17. The series ends with a set of 8 partial eclipses the last of which occurs on 3114 Aug 22. In all, Saros 153 produces 70 solar eclipses in the sequence of 13 partial, 49 annular, and 8 partial eclipses. |
| Description: |
| First here was a scream, then there was a light 1 |
 Download (listen) |
| Filename: |
2014-10-23--PHOBoS blue hell--moon and sun dance 1.mp3 |
| Filesize: |
40.61 MB |
| Downloaded: |
3447 Time(s) |
| Description: |
| First here was a scream, then there was a light 2 |
 Download (listen) |
| Filename: |
2014-10-23--PHOBoS blue hell--moon and sun dance 2.mp3 |
| Filesize: |
6.89 MB |
| Downloaded: |
3436 Time(s) |
_________________ Jan
JovianPyx
Joined: Nov 20, 2007 Posts: 1988 Location: West Red Spot, Jupiter
Audio files: 224
Posted: Thu Oct 23, 2014 4:56 pm Post subject:
Some photographs:
http://scott.joviansynth.com/eclipse_10_23_2014/
The images of the eclipse were photographed using a pinhole in foil to project an image on paper which I photographed with a low cost digital camera. There is at least one photograph of the setup for that. 3 of the images show a wall where the sun filtered through plant leaves first. The plant leaves formed enough of a "pinhole" lens to capture the image of the eclipse as a projection on the wall. _________________ FPGA, dsPIC and Fatman Synth Stuff
Posted: Fri Oct 24, 2014 1:12 pm Post subject:
| PHOBoS wrote: | Nice mix jan , thanks for recording (apparently I forgot ) |
Forgot ... wow .. I thought you had it always on.
Thanks! and thank you
Nice apparatus and pics Scott  _________________ Jan
Joined: Dec 11, 2010 Posts: 1021 Location: Toronto, Ontario - Canada
Posted: Sun Oct 26, 2014 8:53 am Post subject:
Awesome stuff - music and pics.
The sun was behind buildings here, so I couldn't watch even if I had the means. |
