10 band graphical EQ
Ollitron
PostPosted: Mon Apr 02, 2018 5:22 am    Post subject:  10 band graphical EQ Reply with quote  Mark this post and the followings unread
Hello,
since I'm still very convinced about using analog audio effects instead of VST plugins, I built my own graphical equalizer for the eurorack format (see attached PDF file). It is designed for high quality audio editing.
Therefore I'm very interested in your opinion about that:
What would you think about such a module?
What do you miss, what is unnecessary?
How much would you spend for such a module?
Thank you very much in advance!
Best regards,
Olli
GOAD PQ-EQ EN.pdf
 Filename:  GOAD PQ-EQ EN.pdf
 Filesize:  142.92 KB
 Downloaded:  44 Time(s)
