delayed lfo
Page 1 of 1 [6 Posts]
and70it
PostPosted: Sun Jun 26, 2005 11:43 pm    Post subject: delayed lfo Reply with quote  Mark this post and the followings unread
I need some help to build a delayed lfo (like in the moog modular: the lfo with delay and fade in).
Thanx
Unfed
G2 patch files: 11
PostPosted: Mon Jun 27, 2005 12:43 am    Post subject: Reply with quote  Mark this post and the followings unread
send the LFO signal through an envelope first? ie - attack setting would control the fade-in...
just a thought.
and70it
PostPosted: Mon Jun 27, 2005 1:38 am    Post subject: ok Reply with quote  Mark this post and the followings unread
it's ok for the fade in, but for the delay?
And than i think that an env. cause only a rate fade in (from slow to fast)
not an amplitude fade in:
_____/
delay -fade in
thanx
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Mon Jun 27, 2005 1:45 am    Post subject: Reply with quote  Mark this post and the followings unread
If you route the output of the lfo through the envelope it will be an amplitude fade in (or decay or however you setup the envelope). A delay for the lfo requires a bit more work. First, turn off the "kb" button on the envelope. Then insert a keyboard module, and a logic delay module. Connect the keyboard gate output to the logic delay, then the delay output to the gate input on the envelope. The logic delay knob determines how long before the lfo fade in starts.
G2 patch files: 625
PostPosted: Mon Jun 27, 2005 2:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I usually use the AHD env with the output mode set to pos inv. The H time becomes the delay, the D time is the fade in. You also have the choice of fade in slope.
delay vibrato
 Filesize:  11.82 KB
 Viewed:  1786 Time(s)
and70it
PostPosted: Mon Jun 27, 2005 2:44 am    Post subject: thanx Reply with quote  Mark this post and the followings unread
thanx
thanx
thanx
