 Forum index » Online Music
PHOBoS & Blue Hell - apples & bananas
PostPosted: Sat Apr 21, 2018 1:48 pm    Post subject: PHOBoS & Blue Hell - apples & bananas
Subject description: Live improvisation, recorded april 20th, 2018
apples from Blue Hell and bananas from the Moon Base.
a bit droney
a bit dark
a bit psychedelic
 Filesize:  1.46 MB
 Viewed:  755 Time(s)
PHOBoS & Blue Hell - apples & bananas (part I).mp3
 Filename:  PHOBoS & Blue Hell - apples & bananas (part I).mp3
 Filesize:  40.63 MB
 Downloaded:  2851 Time(s)
PHOBoS & Blue Hell - apples & bananas (part II).mp3
 Filename:  PHOBoS & Blue Hell - apples & bananas (part II).mp3
 Filesize:  41.32 MB
 Downloaded:  2826 Time(s)
PostPosted: Mon Apr 23, 2018 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
I think you may be mixing up your fruit photos, but the mixing of your fruit sounds is really nice! I like it a lot! Thanks for sharing.
.:james:.
P.S. I feel a little sheepish mentioning this, since I don't want to take focus away from this great music, but the high-pitched drone at the beginning of Part I reminds me a bit of an old drone piece I did using VFD's... it can be listened to for free here: http://squint.press/00v_james-schidlowsky_ringen/ .
PostPosted: Sat Apr 28, 2018 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for listening James, what are VFD's?
Listening now to Ringen, sounds good :-)
PostPosted: Sun Apr 29, 2018 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
what are VFD's?
Vacuum Fluorescent Displays. One can feed sound through them, and pick up the vibrations of the filaments. It sounds a bit like ring modulation, and pretty high-pitched. I got the idea from The Electronic Peasant ( http://www.electronicpeasant.com/projects/ringmod/trmod.html ).
My piece is based on an improvisation I did using 4 of them, then I took the recording and made 3 copies, each slowed down (affecting pitch) to different speeds. As the piece progresses, I mixed in one of the slowed copies until at its peak, all 4 copies/octaves are heard.
Thanks,
.:james:.
PostPosted: Sun Apr 29, 2018 4:27 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks for listening and commenting james, much appreciated Very Happy
Ringen was a nice listen and now the videotapes and display photos make more sense too. (I still have a lot of old videotapes myself.
not sure what to do with them,. I thought about putting NANDulators in it for a bit but after opening one up I discovered that there is
less space in there than expected because of all the reinforcements that keep the tape from falling apart)
