Military Jet Flypasts
glow worm
PostPosted: Sun Aug 26, 2018 8:08 am    Post subject: Military Jet Flypasts
Subject description: wwwhhhhhoooooooooossssshhh!!!
We live on the approach path to Biggin Hill Airport (a famous WW2 fighter station in its day) and they held their annual "Festival Of Flight" the other weekend.
So I set up the Zoom H2 in the back garden, pointing straight up at the sky, set to Mid / Side, with the levels turned up half way and the stereo spread to 150 deg.
I managed to catch the Red Arrows display team twice (once in two groups, then all together later on) and a Eurofighter Typhoon FGR4 towards the end of the day.
The Red Arrows use training jets (BAe Hawks) and came out a little on the soft side, so were boosted with Amplify in Audacity (it seems to give a more natural sound than Normalisation). The Eurofighter (being a real fighter jet) came out badly clipped, so I fixed it - not with Audacity's Clip Fix function, but by splitting the tracks, going through them in fine detail and applying Repair to each clipped peak and trough, individually. It took a few hours over a few evenings and obviously isn't perfect, but I think it's come out OK.
I've left fairly generous tails before and after each flypast, which include a bit of general, suburban noise.
PS - Play LOUD! shakng2
eurofighter_typhoon_fgr4_flypast_(clipping_repaired).wav
 Filename:  eurofighter_typhoon_fgr4_flypast_(clipping_repaired).wav
 Filesize:  15.14 MB
 Downloaded:  747 Time(s)
red_arrows_flypast_02_(all_9).wav
 Filename:  red_arrows_flypast_02_(all_9).wav
 Filesize:  20.19 MB
 Downloaded:  808 Time(s)
red_arrows_flypast_01_(5_then_4).wav
 Filename:  red_arrows_flypast_01_(5_then_4).wav
 Filesize:  13.7 MB
 Downloaded:  757 Time(s)
It may stop, but it never ends.
gabbagabi
PostPosted: Mon Aug 27, 2018 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
well done!
PostPosted: Tue Aug 28, 2018 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
these are great Razz
varice
G2 patch files: 54
PostPosted: Tue Aug 28, 2018 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
Thanks for sharing this!
varice
