 Forum index » Artists » JovianPyx
Ukulele Practice
Post new topic   Reply to topic Moderators: JovianPyx
Page 1 of 1 [20 Posts]
JovianPyx
Audio files: 224
PostPosted: Thu Sep 27, 2018 9:20 am    Post subject: Ukulele Practice
Subject description: Ukulele Practice
I had lots of problems trying to record my ukulele, but finally overcame most of them. The remaining problem is that the contact mic adhesive needs to be pressed more so that there is better acoustical contact.
uke_2b.mp3
Ukulele Practice Recording
 Filename:  uke_2b.mp3
 Filesize:  1.81 MB
 Downloaded:  2876 Time(s)
Time flies like a banana.
corruptio optimi pessima
PostPosted: Fri Sep 28, 2018 8:35 am    Post subject: Reply with quote  Mark this post and the followings unread
well-done
Lovely!
JovianPyx
Audio files: 224
PostPosted: Fri Sep 28, 2018 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! Cool Cool Cool
I plan to make more out of it, add acoustic guitar and KS for bass.
Hmm. Seems I misspelled Ukulele in the title.
Audio files: 500
PostPosted: Mon Oct 01, 2018 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice indeed. Very Happy
JovianPyx
Audio files: 224
PostPosted: Tue Oct 16, 2018 6:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's another one. I'm finding that just leaving the recorder on while practicing is a good idea. Anyway, this one is a boogie on a ukulele with too much reverb.
ukaboogie_1.mp3
ukaboogie_1.mp3
boogie on an ukulele.
 Filename:  ukaboogie_1.mp3
 Filesize:  1.15 MB
 Downloaded:  2817 Time(s)
JovianPyx
Audio files: 224
PostPosted: Tue Oct 16, 2018 7:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
And another
picking_2018_10_16a.mp3
picking
 Filename:  picking_2018_10_16a.mp3
 Filesize:  1.7 MB
 Downloaded:  2816 Time(s)
PostPosted: Thu Oct 18, 2018 10:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
A couple questions:
All the recording done with contact mics?
What kind of strings? They sound a lot more metallic than the typical nylon.
A soprano?
My eldest has been quite taken with the ukulele for nearly a year now, and he's been noodzhing to get a studio together when we can afford it (and when he meets my requirements about school) and I'm interested in what special things we might need.
PostPosted: Fri Oct 19, 2018 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds wonderful scott flower
JovianPyx
Audio files: 224
PostPosted: Fri Oct 19, 2018 7:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks PHOBoS Smile
elmegil: The instrument is a Mele Tenor Ukulele. The last two recordings were done using a new contact mic "John Pearse" with the mic on the treble end of the bridge. The signal was recorded through a DigiTech Polara reverb into Audacity. The recording was then mildly EQ processed to slightly boost bass and slightly attenuate highs.
The strings are nylon for the upper two and wire wound nylon for the two lower strings. This instrument uses the low G tuning (not traditional Hawaiian). I have a 10 band guitar EQ pedal that I want to try to preprocess the mic signal before sending it to the reverb. The mic is very sensitive and tends to respond lop-sidedly well to highs. I will also try putting the mic on the bass side of the bridge.
What I've read about ukulele is that it's a difficult instrument to mic and I can understand that conclusion.
The mic comes with two methods of installing - there is a permanent adhesive dot (circle) on one side with the adhesive covered by a sort of wax paper. I did not use that. There are also 2 pieces of temporary adhesive included which is what I used to stick the mic to the bridge. It appears to work with the temp adhesive on the side opposite the permanent. The instructions say that the permanent adhesive can be removed if not used. I've not tried that. I read from one reviewer (who seemed really pissed about the permanent adhesive) that it's difficult to remove. From my experience, the mic is sensitive on both sides. Watch hanging sleeve touching the mic while playing, it will cause noise. I play with short sleeves.
PostPosted: Fri Oct 19, 2018 8:43 am    Post subject: Reply with quote  Mark this post and the followings unread
great, thank you for the detailed reply Very Happy
JovianPyx
Audio files: 224
PostPosted: Sun Oct 28, 2018 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Another tune, this one is called "6 to the bar for Ukulele"
uke_2018_10_28_a.mp3
 Filename:  uke_2018_10_28_a.mp3
 Filesize:  1.85 MB
 Downloaded:  2745 Time(s)
JovianPyx
Audio files: 224
PostPosted: Fri Dec 28, 2018 8:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just got both ukuleles back from the luthier shop where both were intonated and both had Aloha Twin mics installed. The 4 string tenor also had a problem with the fingerboard which they fixed. Action was setup on both instruments. They are so much better to play now. And since both have built in mics, it's too easy to plug in and record when I practice.
So here are some snippets of working with the 4 string tenor Mele ukulele.
Played through a DigiTech Polara on plate setting.
seg_00_rec_20181228-172931.mp3
segment 00
 Filename:  seg_00_rec_20181228-172931.mp3
 Filesize:  874.35 KB
 Downloaded:  2648 Time(s)
seg_01_rec_20181228-172931.mp3
segment 01
 Filename:  seg_01_rec_20181228-172931.mp3
 Filesize:  1.98 MB
 Downloaded:  2649 Time(s)
seg_02_rec_20181228-172931.mp3
segment 02
 Filename:  seg_02_rec_20181228-172931.mp3
 Filesize:  1.54 MB
seg_03_rec_20181228-172931.mp3
segment 03
 Filename:  seg_03_rec_20181228-172931.mp3
 Filesize:  1.38 MB
 Downloaded:  2564 Time(s)
JovianPyx
Audio files: 224
PostPosted: Sat Dec 29, 2018 7:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some more ukulele stuff, these were done on my 8 string Baritone ukulele.
seg_00_rec_20181229-132912.mp3
segment 00
 Filename:  seg_00_rec_20181229-132912.mp3
 Filesize:  1.04 MB
 Downloaded:  2574 Time(s)
seg_01_rec_20181229-132912.mp3
segment 01
 Filename:  seg_01_rec_20181229-132912.mp3
 Filesize:  730.67 KB
 Downloaded:  2654 Time(s)
seg_02_rec_20181229-132912.mp3
segment 02
 Filename:  seg_02_rec_20181229-132912.mp3
 Filesize:  458.83 KB
 Downloaded:  2629 Time(s)
seg_03_rec_20181229-132912.mp3
segment 03
 Filename:  seg_03_rec_20181229-132912.mp3
 Filesize:  416.79 KB
 Downloaded:  2530 Time(s)
seg_04_rec_20181229-132912.mp3
segment 04
 Filename:  seg_04_rec_20181229-132912.mp3
 Filesize:  1.12 MB
 Downloaded:  2622 Time(s)
JovianPyx
Audio files: 224
PostPosted: Sat Dec 29, 2018 7:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
more
seg_05_rec_20181229-132912.mp3
segment 05
 Filename:  seg_05_rec_20181229-132912.mp3
 Filesize:  1.11 MB
 Downloaded:  2566 Time(s)
seg_06_rec_20181229-132912.mp3
segment 06
 Filename:  seg_06_rec_20181229-132912.mp3
 Filesize:  2.42 MB
 Downloaded:  2538 Time(s)
seg_07_rec_20181229-132912.mp3
segment 07
 Filename:  seg_07_rec_20181229-132912.mp3
 Filesize:  1.12 MB
seg_08_rec_20181229-132912.mp3
segment 08
 Filename:  seg_08_rec_20181229-132912.mp3
 Filesize:  1.46 MB
 Downloaded:  2587 Time(s)
seg_09_rec_20181229-132912.mp3
segment 09
 Filename:  seg_09_rec_20181229-132912.mp3
 Filesize:  1.5 MB
 Downloaded:  2603 Time(s)
JovianPyx
Audio files: 224
PostPosted: Sat Dec 29, 2018 7:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
more
seg_10_rec_20181229-132912.mp3
segment 10
 Filename:  seg_10_rec_20181229-132912.mp3
 Filesize:  937.2 KB
 Downloaded:  2514 Time(s)
seg_11_rec_20181229-132912.mp3
segment 11
 Filename:  seg_11_rec_20181229-132912.mp3
 Filesize:  1.7 MB
 Downloaded:  2668 Time(s)
JovianPyx
Audio files: 224
PostPosted: Sun Dec 30, 2018 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
a bit more Tenor
seg_00_rec_20181230-133625.mp3
segment 00
 Filename:  seg_00_rec_20181230-133625.mp3
 Filesize:  2.03 MB
 Downloaded:  2657 Time(s)
JovianPyx
Audio files: 224
PostPosted: Wed Apr 24, 2019 8:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
More practice stuff, some a bit rough...
20190424_two_bits.mp3
two bits
 Filename:  20190424_two_bits.mp3
 Filesize:  6.03 MB
 Downloaded:  2504 Time(s)
JovianPyx
Audio files: 224
PostPosted: Thu May 23, 2019 6:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some baritone ukulele harmonics
20190510_snippet_20190528.mp3
Baritone Ukulele Harmonics 50 seconds
 Filename:  20190510_snippet_20190528.mp3
 Filesize:  793.65 KB
 Downloaded:  2461 Time(s)
JovianPyx
Audio files: 224
PostPosted: Thu May 23, 2019 7:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is what I call PinklePinkle.
20190510_eq_end_snippet_PinklePinkle.mp3
PinklePinkle
 Filename:  20190510_eq_end_snippet_PinklePinkle.mp3
 Filesize:  1.35 MB
 Downloaded:  2501 Time(s)
JovianPyx
Audio files: 224
PostPosted: Thu Apr 23, 2020 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
I had a very difficult time with the set I did on the last solstice. I had a problem hearing because of two pieces of gear that were more than 40 years old and were both contributing noise.
I've improved my studio getting rid of a 40+ year old noisy mixer and a 40+ year old noisy graphical EQ. I replaced the mixer with a much newer one and replaced the EQ with a simple passive second order high pass filter with cutoff at 100 Hz. The filter (and EQ) is intended to reduce body thumping while playing an instrument like ukulele.
Here is a snippet of practice time recorded through my new setup.
20200423uke-practice.mp3
Short bit of practice.
 Filename:  20200423uke-practice.mp3
 Filesize:  1.28 MB
 Downloaded:  2037 Time(s)
