Pseudo Stereo
Page 1 of 1 [6 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Nov 02, 2005 3:29 am    Post subject:  Pseudo Stereo Reply with quote  Mark this post and the followings unread
Some things are so obvious they go unnoticed... like this simple allpass filter application. So I thought I'd post it here.
Of course, it ain't mono-compatible. Mixing L and R together results in the frequencies being 6dB-lowpass filtered at the cutoff frequency. But still, it's an cheap usable technique, nice if you're working eg. on the stereo imaging of a a complex mix.
tim
PseudoStereo TK.pch2
Stupidly obvious but oh well...
 Filename:  PseudoStereo TK.pch2
 Filesize:  1.19 KB
 Downloaded:  967 Time(s)
Audio files: 143
PostPosted: Wed Nov 02, 2005 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
This is very interesting. I've been using two phase shifters to get pseudo stereo, but this is a lot cheaper... more subtile though... but sometimes that's better.
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Nov 02, 2005 12:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, Howard, the allpass filter is actually phase shifter.Wink
What I like about this is that the allpass filter frequency determines the position in the spectrum from where on upwards things start to become 'wide', due to frequencies being increasingly shifted to their respective antiphase above the cutoff.
This is nice because it leaves the low and lower components mono, which is better anyway.
I like to use it on high-freq percussion (shakers, cymbals), in order to push them to the sides of the stereo image while kick and snare are more in the middle.
As I say, it's so simple...
cebec
G2 patch files: 31
PostPosted: Wed Nov 02, 2005 12:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
I wish I knew what the hell was going on in that red block!
Rob's G2 workshops go over some of this stuff but my understanding is still rather basic.
I'm wondering if there're other resources for learning how to use the G2's Level and Mixer modules to perform computations and create DIY sub-patches like many of those you, ik, and Rob have shared.
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Nov 02, 2005 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's just an allpass filter, gradually shifting the (mono) signal into antiphase above the cutoff, to perform a pseudo stereo effect when panning the shifted signal hard left and the original one hard right (or vice versa).
Here's what's going on: if you subtract a 6dB LP-filtered signal from the original, you get the remaining HP component (first mixer module) And if you then subtract that from the LP-filtered signal (second mixer module), all frequencies will be present again, but the HP component will be in antiphase. Voilà the allpass filter.
dasz
Audio files: 29
G2 patch files: 56
PostPosted: Thu Nov 03, 2005 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice one, tim.
/Dasz
http://www.dasz.com
Electronic Music Instruments From Vancouver, Canada
(Cycling log - https://www.strava.com/athletes/5681257 )
