Phaser with true Pos/Neg feedback control
davep
Audio files: 10
G2 patch files: 73
PostPosted: Sat Dec 03, 2005 8:55 pm    Post subject: Phaser with true Pos/Neg feedback control Reply with quote  Mark this post and the followings unread
Hi all,
Something I've noticed about the feedback control on phasors - when using negative feedback, it sounds best when the phasor output is inverted before mixing it with the dry signal, but when using positive feedback, it sounds best if you DON'T invert the phasor.
So, attached is a handy 'lil phasor control circuit that uses one knob to control feedback from negative to positive, and automatically switches the phasor output to an inverted signal when the feedback is negative. The circuit is the yellow modules. Use the red module to sweep from negative to positive.
I tried a simpler approach, using a morph group to control both the phasor feedback knob and the INVERT button on the 2-ch mixer, but it makes an annoying 'pop' when it switches. The crossfader with a lagged logic pulse is smoother. Enjoy!
Phaser Pos-Neg idea.pch2
 Filename:  Phaser Pos-Neg idea.pch2
 Filesize:  2.06 KB
 Downloaded:  983 Time(s)
Dave Peck
