Recent Changes - Search:
Contents
Site
Help
« nov 2017 · mar 2018 »
    add a calendar item
    Articles / Feedback Or No Input Mixing
    Articles.FeedbackOrNoInputMixing History
    Hide minor edits - Show changes to output
    2013-03-24 19:16 [UTC-7] by cleaninglady -
    2013-03-24 19:15 [UTC-7] by cleaninglady -
    Changed line 69 from:
    The ideal feedback mixer in my opinion is a Matrix mixer, one which has as many outputs as inputs. Any mixer that has several Aux and Buss outs is great though. If you team this up with various effects and processing and take some time to explore how everything interacts, you have a very powerful modular setup that can make a wide variety of sounds. Having a couple of foot pedals to control volume could give you extra expressiveness for example, but in the end it all comes down to how you perform on your system, and that is not something you can learn from a wiki article. For inspiration, listen to [[https://soundcloud.com/alcohol-label/sets/toshimaru-nakamura-no-input | Toshimaru Nakamura]] who coined the phrase "no-input mixing". Arvo Pärt also did a piece that you can listen to and watch here:
    to:
    The ideal feedback mixer in my opinion is a Matrix mixer, one which has as many outputs as inputs. Any mixer that has several Aux and Buss outs is great though. If you team this up with various effects and processing and take some time to explore how everything interacts, you have a very powerful modular setup that can make a wide variety of sounds. Having a couple of foot pedals to control volume could give you extra expressiveness for example, but in the end it all comes down to how you perform on your system, and that is not something you can learn from a wiki article. For inspiration, listen to [[https://soundcloud.com/alcohol-label/sets/toshimaru-nakamura-no-input | Toshimaru Nakamura]] who coined the phrase "no-input mixing". Christian Carriere also did a piece by Arvo Pärt that you can listen to and watch here:
    2013-02-21 17:51 [UTC-7] by Muied Lumens -
    Changed line 77 from:
    Thesre are several threads on the forum, like [[http://electro-music.com/forum/viewtopic.php?t=51548 | this one]], and [[http://electro-music.com/forum/post-292335.html | this one]] discussing the theme, and especially [[http://electro-music.com/forum/viewtopic.php?t=51548 | this post]] which i recommend reading. [[~Acoustic Interloper]] has a recording from the 2012 electro-music festival posted in [[http://www.electro-music.com/forum/viewtopic.php?t=55056 | this thread]]:
    to:
    There are several threads on the forum, like [[http://electro-music.com/forum/viewtopic.php?t=51548 | this one]], and [[http://electro-music.com/forum/post-292335.html | this one]] discussing the theme, and especially [[http://electro-music.com/forum/viewtopic.php?t=51548 | this post]] which i recommend reading. [[~Acoustic Interloper]] also has a wonderful recording from the 2012 electro-music festival posted in [[http://www.electro-music.com/forum/viewtopic.php?t=55056 | this thread]]:
    2013-02-21 15:50 [UTC-7] by Muied Lumens -
    Changed line 23 from:
    An additional note on using modulars with guitar pedals: these two often operate at very different levels, and while I must admit that I don't know if there is any danger of damage, please ensure this for yourself before you proceed.
    to:
    An additional note on using modular synthesizers with guitar pedals: these two often operate at very different levels, and while I must admit that I don't know if there is any danger of damage, please ensure this for yourself before you proceed.
    Added lines 22-23:
    2013-02-21 15:23 [UTC-7] by Muied Lumens -
    ->{track: 55056 | Zero-input mixing performance} Copyright (c) 2012 Bill Manganaro, John Driscoll, Jeremy Parson and Dale Parson on Zero-Input Mixer Collaboration
    to:
    ->{track: 31924 | Zero-input mixing performance} Copyright (c) 2012 Bill Manganaro, John Driscoll, Jeremy Parson and Dale Parson on Zero-Input Mixer Collaboration
    ->[track: 55056 | Zero-input mixing performance]] Copyright (c) 2012 Bill Manganaro, John Driscoll, Jeremy Parson and Dale Parson on Zero-Input Mixer Collaboration
    to:
    2013-02-21 15:18 [UTC-7] by Muied Lumens -
    Added lines 75-79:
    Released under the Creative Commons Attribution License (http://creativecommons.org/licenses/by/2.5)
    2013-02-18 07:53 [UTC-7] by Muied Lumens -
    Changed lines 45-46 from:
    Delays will slow down the development of the feedback, if you have them set up correctly. This can make it easier to "play" the feedback, because it gives you more time to react to changes, provided the delay time is long enough. You should start with a 100% wet signal, from the mic, through the delay (with no internal feedback) and out of the speakers. No direct signal from the mic should reach the speakers. The delay time is up to you, but 500 ms is probably a good starting point. Now take the mic in your hand and move it around the room (but be within reach or the main fader). If everything is set up and you have enough gain, you should be able to play the room! Different spots will give you different sounds or tones. I find that adding distortion makes it easier to achieve this at lower volumes, but YMMV. Also adding resonators, like placing the mic inside a bowl or tube will accentuate this effect. You may have to go quite loud to get it working properly, so make sure your neighbours are sane, sensible people.
    to:
    Delays will slow down the development of the feedback, if you have them set up correctly. This can make it easier to "play" the feedback, because it gives you more time to react to changes, provided the delay time is long enough. You should start with a 100% wet signal, from the mic, through the delay (with no internal feedback) and out of the speakers. No direct signal from the mic should reach the speakers. The delay time is up to you, but 500 ms is probably a good starting point. Now take the mic in your hand and move it around the room (but be within reach or the main fader). If everything is set up properly and you have enough gain, you should be able to play the room! Different spots will give you different sounds or tones. I find that adding distortion makes it easier to achieve this at lower volumes, but your milage may vary. Also adding resonators, like placing the mic inside a bowl or tube will accentuate this effect. You may have to go quite loud to get it working properly, so make sure your neighbours are sane, sensible people.
    Changed line 63 from:
    The great benefit of software is that you have access to a much larger pallette of feedback techniques. You do not have to limit yourself to straight audio paths, but can create FM feedback, intricate control dependent delay networks, noodles and all sorts of things that I can't think of. A software modular is in its own way a fun way to explore, and is discussably only outmatched in fun factor by a real modular, which brings us to...
    to:
    The great benefit of software is that you have access to a much larger pallette of feedback techniques. You do not have to limit yourself to straight audio paths, but can create FM feedback, intricate control dependent delay networks, noodles and all sorts of things that I can't even begin to think of. A software modular is in its own way a fun way to explore, and is discussably only outmatched in fun factor by a real modular, which brings us to...
    2013-02-16 09:19 [UTC-7] by Muied Lumens -
    Changed line 21 from:
    There is of course no guarantee that your equipment is safe from harm by feeding it levels at the very top (and beyond) of what is was designed to be capable of, so don't use your most prised $10 000 mic preamps, OK? In general, gear should be able to deal with it, even guitar pedals. The big risk is to the speakers (and mikes) '''and your hearing''', so make sure you have them kept safe. Nobody but you will be held responsible if things go wrong though, so again use your best sense.
    to:
    There is of course no guarantee that your equipment is safe from harm by feeding it levels at the very top (and beyond) of what is was designed to be capable of, so don't use your most prised $10 000 mic preamps, OK? In general, gear should be able to deal with it, even guitar pedals. In fact, you can use lower gain guitar pedals as "buffers" or limiters for your line level equipment because pedals often deal with lower levels. The big risk is to the speakers (and mikes) '''and your hearing''', so make sure you have them kept safe. Nobody but you will be held responsible if things go wrong though, so again use your best sense.
    2013-02-15 10:12 [UTC-7] by Muied Lumens -
    Changed line 55 from:
    Whether you are doing it for the sake of raw sampling material (you can get a wealth of great single cycle waveforms from mixer feedback - take a look at the waveforms!) or for a performance, the quality of the equimpent is almost unimportant. I say almost because as mentioned before, budget or old cheap gear is just as useful than modern, clean sounding hifi recording equipment. Lofi stuff will add more tone and character to the sound and hopefully limit the bandwidth too. That said, nothing stops you from using whatever you like, including elements that have nothing to do with feedback whatsoever. It is your playing field, conquer it!
    to:
    Whether you are doing it for the sake of raw sampling material (you can get a wealth of great single cycle waveforms from mixer feedback - take a look at the waveforms!) or for a performance, the quality of the equimpent is almost unimportant. I say almost because as mentioned before, budget or old cheap gear is just as useful than modern, clean sounding hifi recording equipment. Lofi stuff will add more tone and character to the sound and hopefully limit the bandwidth too, as the evolving sound seeks the path of least resistance. That said, nothing stops you from using whatever you like, including elements that have nothing to do with feedback whatsoever. It is your playing field, conquer it!
    2013-02-09 21:17 [UTC-7] by Muied Lumens -
    Changed line 67 from:
    The ideal feedback mixer in my opinion is a Matrix mixer, one which has as many outputs as inputs. Any mixer that has several Aux and Buss outs is great though. If you team this up with various effects and processing and take some time to explore how everything interacts, you have a very powerful modular setup that can make a wide variety of sounds. Having a couple of foot pedals to control volume could give you extra expressiveness for example, but in the end it all comes down to how you perform on your system, and that is not something you can learn from a wiki article. For inspiration, listen to [[http://en.wikipedia.org/wiki/Toshimaru_Nakamura | Toshimaru Nakamura]] who coined the phrase "no-input mixing". Arvo Pärt also did a piece that you can listen to and watch here:
    to:
    2013-02-08 10:09 [UTC-7] by Muied Lumens -
    Changed line 71 from:
    Other less virtuoso techniques (in performance terms) would involve using a sequencer to control the volume of loops for example. You could use an analogue sequencer for this, or a MIDI sequencer controlling CC values of various parameters of a synth or effects unit. Any synth that has inputs could become a target for feedback abuse! Other synths, for example Dave Smith's Evolver, has internal feedback paths that can create interesting sounds. Also making use of other not-so-obvious effects processors, like multi-band compressors, or even feedback eliminators will further expand your sonic territory.
    to:
    Other less virtuoso techniques (in performance terms) would involve using a sequencer to control the gain (and therefore the pitch) of loops for example. You could use an analogue sequencer for this, or a MIDI sequencer controlling CC values of various parameters of a synth or effects unit. Any synth that has inputs could become a target for feedback abuse! Other synths, for example Dave Smith's Evolver, has internal feedback paths that can create interesting sounds. Also making use of other not-so-obvious effects processors, like multi-band compressors, or even feedback eliminators will further expand your sonic territory.
    2013-02-04 21:49 [UTC-7] by Muied Lumens -
    Changed lines 21-22 from:
    There is of course no guarantee that your equipment is safe from harm by feeding it levels at the very top (and beyond) of what is was designed to be capable of, so don't use your most prised $10 000 mic preamps, OK? In general, gear should be able to deal with it, even guitar pedals. The big risk is to the speakers (and mikes) '''and your ears''', so make sure you have them kept safe. Nobody but you will be held responsible if things go wrong though, so again use your best sense.
    to:
    Changed lines 25-28 from:
    Making a simple feedback loop is very easy. You take an amplifier and connect its output back to its input, and turn it up. At some point, the amplifier turns into an oscillator. You can't hear what is going on unless you split the output and that is where a mixer comes in. If you take the main output of a mixer and plug it into one of the channels you have the same thing happening.
    Mixers are very handy in feedback configurations because you can route and split signals and amplify them too. If
    you have a mixer with an aux out, and route that back into one of the channels using a cable, you can control the overall volume of the main output and whack up the channel and aux gain to create feedback. In other words, the volume on the channel will be extremely loud, so you need to almost completely turn down the main fader to compensate for this, and keep a cautious finger on it while you increase the gain of your feedback. Make sure you understand this gain structure before you start, it's at the very foundations of feedback performance.
    to:
    Making a simple feedback loop is very easy. You take an amplifier and connect its output back to its input, and turn it up. At some point, the amplifier turns into an oscillator. You can't hear what is going on unless you split the output and that is where a mixer comes in. If you take the main output of a mixer and plug it into one of the channels you have the same thing happening, just now you can also route an other output to a speaker.
    you can route and split signals and amplify them too. If you have a mixer with an Aux (Auxillary) out, and route that back into one of the channels using a cable, you can control the overall volume of the main output and whack up the channel and Aux gain to create feedback. In other words, the volume on the channel will be extremely loud, so you need to almost completely turn down the main fader to compensate for this, and keep a cautious finger on it while you increase the gain of your feedback. Make sure you understand this gain structure before you start, it's at the very foundations of feedback performance.
    Changed lines 37-38 from:
    Once you have explored one channel, set up an other one, using an other aux out if possible. The extra channel in isolation will act as an other oscillator, and you can create some nice detuned drones this way, but interesting things happen once they start interfering with each other. One can act as an LFO on the other, you can get strange intermodulation going, or other unheard of squeals, unique to your equipment. If it blows your mind like it did mine when I first tried it, you will slowly increase the complexity of your setup, adding external effects and processing until you have no idea what's going on any more! How you proceed is up to you, but there are no rules except for the safety ones. Always be aware of where your main volume output is, both in level and physical space.
    to:
    Once you have explored one channel, set up an other one, using an other aux out if possible. The extra channel in isolation will act as an other oscillator, and you can create some nice detuned drones this way, but interesting things happen once they start interfering with each other. One can act as an LFO on the other, you can get strange intermodulation going, or other unheard of squeals, unique to your equipment and setup. If this blows your mind like it did mine when I first tried it, you will slowly increase the complexity of your setup, adding external effects and processing until you have no idea what's going on any more! How you proceed is up to you, but there are no rules except for the safety ones. Always be aware of where your main volume output is, both in level and physical space.
    Changed lines 43-44 from:
    The limiter a safety precaution, and should be between your mixer main outs and your speakers, to protect from overloads that are too fast for you to react to. Limiters are more important in mic configs bcause of the added instability mikes add. When you feed a channel directly back into itself (i.e. internally in a mixer), it will be overloaded to its maximum possible signal level, and distort. This in itself is a limiter, and older cheaper gear with less headroom will do you a favour here. You do not want to push microphones to this level because it is normally far too loud for comfort and it could break your speakers, ears and mikes in one fell swoop. Be aware that limiters are actually compressors with a high compression ratio, so if you get excessive signal peaks, they may still be capable of breaking through the limiting ceiling.
    to:
    The limiter is a safety precaution, and should be between your mixer main outs and your speakers, to protect from overloads that are too fast for you to react to. Limiters are more important in mic configs because of the added instability mikes add. When you feed a channel directly back into itself (i.e. internally in a mixer), it will be overloaded to its maximum possible signal level, and distort. This in itself is a limiter, and older cheaper gear with less headroom will do you a favour here. You do not want to push microphones to this level because it is normally far too loud for comfort and it could break your speakers, ears and mikes in one fell swoop. Be aware that limiters are actually compressors with a high compression ratio, so if you get excessive signal peaks combined with odd DC offsets and what have you, they may still be capable of breaking through the limiting ceiling.
    Changed lines 47-48 from:
    If you do not have a microphone handy, you can use other types of transducers, like headphones, speakers, piezo trancducers ond so on, in place of a mic. When using something that is not as sensitive as a mic normally is, apart from adding lots of gain, it helps to compress or distort the input to force some decent levels and add harmonics. You can of course also use electric guitars or other instruments, just laid flat on a table. Placing is all important, so slowly add one thing after an other, and move things around as you do. The more complexity you add the better, as long as you are in control of the main output.
    to:
    If you do not have a microphone handy, you can use other types of transducers, like headphones, speakers, piezo transducers and so on, in place of a mic. When using something that is not as sensitive as a mic normally is, apart from adding lots of gain, it helps to compress or distort the input to force some decent levels and add harmonics. You can of course also use electric guitars or other instruments, just laid flat on a table. Placing is all important, so slowly add one thing after an other, and move things around as you do. The more complexity you add the better, as long as you are in control of the main output.
    Changed lines 55-56 from:
    Whether you are doing it for the sake of raw sampling material (you can get a wealth of great single cycle waveforms from mixer feedback - take a look at the waveforms!) or for a performance, the quality of the equimpent is almost unimportant. I say almost because as mentioned before, budget or old cheap gear is just as useful than modern, clean sounding hifi recording equipment, as lofi stuff will add more tone and character to the sound. That said, nothing stops you from using whatever you like, including elements that have nothing to do with feedback whatsoever. It is your playing field, conquer it!
    to:
    Changed lines 61-62 from:
    Not all software will let you create feedback loops, in fact, some software will prevent you from this altogether. Reaper, which is a DAW recording program, has an option that lets you switch off this safety measure (File > Project Settings > Advanced). Most modular software, like Max, Puredata, Supercollider, Plogue Bidule and Kyma will let you create feedback loops, but be aware of a particular difference between software and analog feedback systems. The software has to actually process the data it produces so if you create very short loops it will cost you in processing power, and can cause the program to behave strangely or simply crash.
    to:
    Not all software will let you create feedback loops, in fact, some software will prevent you from this altogether. Reaper, which is a DAW recording program, has an option that lets you switch off this safety measure (File > Project Settings > Advanced). Most modular software, like Max, Puredata, Supercollider, Plogue Bidule and Kyma will let you create feedback loops, but be aware of a particular difference between software and analog feedback systems. The software has to actually process the data it produces so if you create very short loops it will cost you in processing power, and can cause the program to behave strangely or simply crash. One simple way around this is to create an acoustic feedback path, as described above. The latency of the system will do you a huge favour here.
    The ideal feedback mixer in my opinion is a Matrix mixer, one which has as many outputs as inputs, but any mixer that has several Aux and Buss outs is great. If you team this up with various effects and processing and take some time to learn how everything interacts with each other, you have a very powerful modular setup that can make a wide variety of sounds. Having a couple of foot pedals to control volume could give you extra expressiveness for example, but in the end it all comes down to how you perform on your system, and that is not something you can learn from a wiki article. For inspiration, listen to Toshimaru Nakamura who coined the phrase "no-input mixing". Arvo Pärt also did a piece that you can listen to and watch here:
    to:
    2013-02-04 21:29 [UTC-7] by Muied Lumens -
    Changed line 7 from:
    If you have ever pondered upon the mathematics behind those beautiful patterns that make up fractal images you have marvelled at the raw beauty of feedback. Many of these images are made up of very simple mathematical expressions, where the result of that expression is fed back in to itself (or iterated), over and over. Feedback is a phenonemon that exists all around us in various shapes and forms, and by experimenting with this in audio you will maybe gain some insight into it on a new level. Once you start really playing with feedback it almost begins to feel like a living entity. It is something that speaks to your intuitive side more than your intellect, because even with fairly simple setups, the behaviour of the fed back sound goes beyond what you can easily understand, and it simply boils down to how you interact with it in the moment.
    to:
    If you have ever pondered upon the mathematics behind those beautiful patterns that make up fractal images you have marvelled at the raw beauty of feedback. Many of those images are made up of very simple mathematical expressions, where the result of that expression is fed back in to itself (or iterated), over and over. Feedback is a phenonemon that exists all around us in various shapes and forms, and by experimenting with this in audio you will maybe gain some insight into it on a new level. Once you start really playing with feedback it almost begins to feel like a living entity. It is something that speaks to your intuitive side more than your intellect, because even with fairly simple setups, the behaviour of the fed back sound goes beyond what you can easily understand, and it simply boils down to how you interact with it in the moment.
    Changed line 47 from:
    If you do not have a microphone handy, you can use other types of transducers, like headphones, speakers, piezo trancducers ond so on, in place of a mic. When using something that is not as sensitive as a mic normally is, apart from adding lots of gain, it helps to compress or distort the input to force some decent levels and add harmonics. You can of course also use electric guitars or other instruments, just laid flat on a table, the more the merrier! The more complexity you add the better, as long as you are in control of the main output.
    to:
    2013-02-04 21:25 [UTC-7] by Muied Lumens -
    Changed lines 3-4 from:
    !!!by Muied Lumens
    to:
    !!!!by Muied Lumens
    Changed lines 67-68 from:
    The ideal feedback mixer in my opinion is a Matrix mixer, with as many outputs as inputs, but any mixer that has several aux and bus outs is good. If you team this up with various effects and processing and take some time to learn how everything interacts with each other, you have a very powerful modular setup that can make a wide variety of sounds. Having a couple of foot pedals to control volume could give you extra expressiveness for example, but in the end it all comes down to how you perform on your system, and that is not something you can learn from a wiki article. For inspiration, listen to Toshimaru Nakamura who coined the phrase "no-input mixing". Arvo Pärt also did a piece that you can listen to and watch here:
    to:
    Changed line 73 from:
    Hopefully this has given you an idea of how much scope for exploration there is in the humble feedback loop. If you want to understand some of the processes behind this magic, I recommend that you read up on Chaos theory. If you like books you could read for example James Gleick's "Chaos" as an introduction to the theme. There are countless other books on the concept of feedback in areas from physics to biology and for a very different approach, try "I am a strange loop" by Douglas Hofstadter.
    to:
    Hopefully this has given you an idea of how much scope for exploration there is in the humble feedback loop. If you want to understand some of the processes behind this magic, I recommend that you read up on Chaos theory. If you like books you could do worse than read James Gleick's "Chaos" as an introduction to the theme. There are countless other books on the concept of feedback in areas from physics to biology and for a very different approach, try "I am a strange loop" by Douglas Hofstadter.
    2013-02-04 21:19 [UTC-7] by Muied Lumens -
    Changed line 15 from:
    * Use a limiter (or even better, several) - limiters are your safety net, but be aware that very very high levels can break through some limiters.
    to:
    Added line 18:
    *Also be aware that may also get very loud high or low frequencies which may cause strange or unexpected behaviour in your setup... so:
    2013-02-04 21:10 [UTC-7] by Muied Lumens -
    Changed lines 68-70 from:
    http://vimeo.com/30074885#
    Other less virtuoso techniques (in performance terms) would involve using a sequencer to control the volume of loops for example. You could use an analog sequencer for this, or a MIDI sequencer controlling CC values of various parameters of a synth or effects unit. Any synth that has inputs could become a target for feedback abuse! Other synths, for example Dave Smith's Evolver, has internal feedback paths that can create interesting sounds. Also making use of other not-so-obvious effects processors, like multi-band compressors, or even feedback eliminators will further expand your sonic territory.
    to:
    2013-02-04 19:21 [UTC-7] by Muied Lumens -
    Changed line 36 from:
    Once you have explored one channel, set up an other one, using an other aux out if possible. The extra channel in isolation will act as an other oscillator, and you can create some nice detuned drones this way, but interesting things happen once they start interfering with each other. One can act as an LFO on the other, you can get strange intermodulation going, or other unheard of squeals, unique to your equipment will emerge. If it blows your mind like it did mine when I first tried it, you will slowly increase the complexity of your setup, adding external effects and processing until you have no idea what's going on any more! How you proceed is up to you, but there are no rules except for the safety ones. Always be aware of where your main volume output is, both in level and physical space.
    to:
    2013-02-04 15:53 [UTC-7] by Muied Lumens -
    Changed lines 42-43 from:
    The limiter is your safety net, and should be between your mixer main outs and your speakers, to protect from overloads that are too fast for you to react to. Limiters are more important in mic configs bcause of the added instability mikes add. When you feed a channel directly back into itself (i.e. internally in a mixer), it will be overloaded to its maximum possible signal level, and distort. This in itself is a limiter, and older cheaper gear with less headroom will do you a favour here. You do not want to push microphones to this level because it is normally far too loud for comfort and it could break your speakers, ears and mikes in one fell swoop. Be aware that limiters are actually compressors with a high compression ratio, so if you get excessive signal peaks, they may still be capable of breaking through the limiting ceiling.
    to:
    Changed line 70 from:
    Other less virtuoso (in performance terms) techniques would involve using a sequencer to control the volume of loops for example. You could use an analog sequencer for this, or a MIDI sequencer controlling CC values of various parameters of a synth or effects unit. Any synth that has inputs could become a target for feedback abuse! Other synths, for example Dave Smith's Evolver, has internal feedback paths that can create interesting sounds. Also making use of other not-so-obvious effects processors, like multi-band compressors, or even feedback eliminators will further expand your sonic territory.
    to:
    2013-02-04 15:44 [UTC-7] by Muied Lumens -
    Changed line 30 from:
    %width=50pct% http://electro-music.com/forum/phpbb-files/phonicfb_119.jpg
    to:
    %width=60pct% http://electro-music.com/forum/phpbb-files/phonicfb_119.jpg
    2013-02-04 15:38 [UTC-7] by Muied Lumens -
    Changed line 66 from:
    The ideal feedback mixer in my opinion is a Matrix mixer, with as many outputs as inputs, but any mixer that has several aux and bus outs is good. If you team this up with various effects and processing and take some time to learn how everything interacts with each other, you have a very powerful modular setup that can make a wide variety of sounds. Having a couple of foot pedals to control volume could give you extra expressiveness for example, but in the end it all comes down to how you perform on your system, and that is not something you can learn from a wiki article. For inspiration, listen to Toshimaru Nakamura who coined the phrase "no-input mixing". Arvo Pärt also did a piece that you can partly listen to and watch here:
    to:
    Changed lines 66-68 from:
    The ideal feedback mixer in my opinion is a Matrix mixer, with as many outputs as inputs, but any mixer that has several aux and bus outs is good. If you team this up with various effects and processing and take some time to learn how everything interacts with each other, you have a very powerful modular setup that can make a wide variety of sounds. Having a couple of foot pedals to control volume could give you extra expressiveness for example, but in the end it all comes down to how you perform on your system, and that is not something you can learn from a wiki article. For inspiration, listen to Toshimaru Nakamura who coined the phrase "no-input mixing". Arvo Pärt also did a piece that you can partly listen to and watch here: http://vimeo.com/30074885# .
    to:
    2013-02-04 15:37 [UTC-7] by Muied Lumens -
    Changed line 32 from:
    Here, the Aux out is connected back into channel one. The Aux on this mixer is pre-fader, meaning that the channel volume does not affect the Aux level. It is therefore easy to set up a loop and control its volume on the channel itself. The headphone output goes to some old computer speakers and the record out to my handy portable recorder. The sound this setup made can be heard here:
    to:
    Here, the Aux out is connected back into channel one. The Aux on this mixer is pre-fader, meaning that the channel volume does not affect the Aux level. It is therefore easy to set up a loop and control its volume on the channel itself. The headphone output goes to some old computer speakers and the record out to my handy portable recorder. The sound this setup made can be heard here (dry recording, I only filtered out some subharmonics):
    2013-02-04 15:33 [UTC-7] by Muied Lumens -
    Changed line 34 from:
    ->{track: 33635 | One single channel feedback}
    to:
    ->{track: 33635 | Single channel feedback}
    ->{track: 33635 | One channel feedback}
    to:
    2013-02-04 15:32 [UTC-7] by Muied Lumens -
    to:
    2013-02-04 15:31 [UTC-7] by Muied Lumens -
    Added lines 31-32:
    2013-02-04 15:26 [UTC-7] by Muied Lumens -
    %width=95pct% http://electro-music.com/forum/phpbb-files/phonicfb_119.jpg
    to:
    2013-02-04 15:25 [UTC-7] by Muied Lumens -
    Added lines 29-30:
    2013-02-04 15:17 [UTC-7] by Muied Lumens -
    Changed line 42 from:
    If you do not have a microphone handy, you can use other types of transducers, like headphones, speakers, piezo trancducers ond so on, in place of a mic. When uisng something that is not as sensitive as a mic normally is, apart from adding lots of gain, it helps to compress or distort the input to force some decent levels and add harmonics. You can of course also use electric guitars or other instruments, just laid flat on a table, the more the merrier! The more complexity you add the better, as long as you are in control of the main output.
    to:
    2013-02-04 15:15 [UTC-7] by Muied Lumens -
    ->{track: 33653 | Single channel feedback}
    to:
    2013-02-04 15:13 [UTC-7] by Muied Lumens -
    Added lines 29-30:
    2013-02-04 09:27 [UTC-7] by Muied Lumens -
    Changed lines 7-8 from:
    If you have ever pondered on the mathematics behind those beautiful patterns that make up fractal images you have marvelled at the raw beauty of feedback. Many of these images are made up of very simple mathematical expressions, where the result is fed in to itself (or iterated), over and over. Feedback is a phenonemon that exists all around us in various shapes and forms, and by experimenting with this in audio you will maybe gain some insight into it on a new level. Once you start really playing with feedback it almost begins to feel like a living entity. It is something that speaks to your intuitive side more than your intellect, because even with fairly simple setups, the behaviour of the fed back sound goes beyond what you can easily understand, and it simply boils down to how you interact with it in the moment.
    to:
    Changed line 17 from:
    * Have a kill switch or fader - if the feedback loop tries to eascape out of your speakers, your most likely first reaction is to freeze. After that, make sure your first move is very simpleand fast.
    to:
    * Have a kill switch or fader - if the feedback loop tries to eascape out of your speakers, your most likely first reaction is to freeze. After that, make sure your first move requires no thinking.
    Changed lines 20-21 from:
    There is of course no guarantee that your equipment is safe from harm by feeding it levels at the very top (and beyond) of what is was designed to be capable of, so don't use your most prised $10 000 mic preamps, OK? In general, gear should be able to deal with it, even guitar pedals. The big risk is to the speakers (and mikes), so make sure you have them kept safe. Nobody but you will be held responsible if things go wrong though, so again use your best sense.
    to:
    Changed lines 30-31 from:
    Once you have explored one channel, set up an other one, using an other aux out if possible. The extra channel in isolation will act as an other oscillator, and you can create some nice detuned drones this way, but interesting things happen once they start interfering with each other. One can act as an LFO on the other, you can get strange intermodulation going, or other unheard of squeals, unique to your equipment will emerge. If it blows your mind like it did mine when I first tried it, you will slowly increase the complexity of your setup, adding external effects and processing until you have no idea what's going on any more! How you proceed is up to you, but there are no rules except for the safety ones. Always be sure of where your main volume output is, both in level and physical space.
    to:
    Changed lines 38-39 from:
    Delays will slow down the development of the feedback, if you have them set up correctly. This can make it easier to "play" the feedback, because it gives you more time to react to changes, provided the delay time is long enough. You should start with a 100% wet signal, from the mic, through the delay (with no internal feedback) and out of the speakers. No direct signal from the mic should reach the speakers. The delay time is up to you, but 500 ms is probably a good starting point. Now take the mic in your hand and move it around the room (but be within reach or the main fader). If everything is set up and you have enough gain, you should be able to play the room! Different spots will give you different sounds or tones. I find that adding distortion makes it easier to achieve this at lower volumes, but YMMV. Also adding resonators, like placing the mic inside a bowl or tube will accentuate this effect. You may have to go quite loud to get it working properly, so make sure your neighbours are sane, sensible people. ;)
    to:
    Changed lines 44-45 from:
    Once you have set up a few loops that interact with each other - exploiting the nonlinearities that occur at the limits of the circuits incolved and/or the acoustics of your room, instruments and even involving your own feedback, responding to the sounds that you hear - you have arguably created what is called a chaotic (or complex) system. This does not mean that it is completely random, but simply that its long term output is unpredictable, just as the weather and the stock market is.
    to:
    Once you have set up a few loops that interact with each other - exploiting the nonlinearities that occur at the limits of the circuits involved and/or the acoustics of your room, instruments and even involving your own feedback, responding to the sounds that you hear - you have arguably created what is called a chaotic (or complex) system. This does not mean that it is completely random, but simply that its long term output is unpredictable, just as the weather and the stock market is.
    Changed lines 48-49 from:
    Whether you are doing it for the sake of raw sampling material (you can get a wealth of great single cycle waveforms from mixer feedback - take a look at the waveforms!) or for a performance, the quality of the equimpent is almost unimportant. I say almost because as mentioned before, budget or old cheap gear is more useful than modern, clean sounding hifi recording equipment, as lofi stuff will add more tone and character to the sound. That said, nothing stops you from using whatever you like, including elements that have nothing to do with feedback whatsoever. It is your playing field, conquer it!
    to:
    Changed lines 52-55 from:
    So far I have assumed that the feedback has been created more or less in the analogue domain, but you can of course make software based feedback too. The rules do change a little bit though, and unless you put some work in, much of the unpredictability and charm of analogue nonlinearity gets lost. If you distort a digital signal you get a completely different result, and not one that may be immediately useful. I therefore usually stay within levels in the digital domain, and add other effects to bring out the nonlinearities. You could say that the same rules that go for acoustics apply here, which is to stay within the dynamic range. You may need a trigger to get things started, which can be anything that makes sound, anything from a short impulse to noise to a snippet from the Sound Of Music.
    Not all software will let you create feedback loops, in fact, some software will prevent you from creating a feedback loop alltogether. Reaper, which is a DAW recording program, has an option that lets you switch off this safety measure (File > Project Settings > Advanced). Most modular software, like Max, Puredata, Supercollider, Plogue Bidule and Kyma will let you create feedback loops internally in the software, but be aware of a particular difference between software and analog feedback systems. The software has to actually process the data it produces so if you create very short loops it will cost you in processing power, and can cause the program to behave strangely or simply crash.
    to:
    So far I have assumed that the feedback has been created more or less in the analogue domain, but you can of course make software based feedback too. The rules do change a little bit though, and unless you put some work in, much of the unpredictability and charm of analogue nonlinearity gets lost. If you distort a digital signal you get a completely different result, and not one that may be immediately useful. I therefore usually stay within reasonable levels in the digital domain, and add other effects to bring out the nonlinearities. You could say that the same rules that go for acoustics apply here, which is to stay within the dynamic range. You may need a trigger to get things started, which can be anything that makes sound, anything from a short impulse to noise to a snippet from the Sound Of Music.
    Changed line 64 from:
    Hopefully this has given you an idea of how much scope for exploration there is in the humble feedback loop. If you want to understand some of the processes behind this magical thing called feedback, I recommend that you read up on Chaos theory. If you like books you could read for example James Gleick's "Chaos" as an introduction to the theme. There are countless other books on the concept of loops and for a very different approach, try "I am a strange loop" by Douglas Hofstadter.
    to:
    2013-02-03 15:40 [UTC-7] by Muied Lumens -
    Changed lines 52-54 from:
    So far I have assumed that the feedback has been created more or less in the analogue domain, but you can of course make software based feedback too. The rules do change a little bit though, and unless you put some work in, much of the unpredictability and charm of analogue nonlinearity gets lost. If you distort a digital signal you get a completely different result, and not one that may be immediately useful. I therefore usually stay within levels in the digital domain, and add other effects to bring out the nonlinearities. You could say that the same rules that go for acoustics apply here.
    a powerful and affordable DAW, has an option that lets you switch off this safety measure (File > Project Settings > Advanced). Most modular software, like Max, Puredata, Supercollider, Plogue Bidule and Kyma will let you create feedback loops internally in the software, but be aware of a particular difference between software and analog feedback systems. The software has to actually process the data it produces so if you create very short loops it will cost you in processing power, and can cause the program to crash.
    to:
    !!!Advanced techniques
    2013-02-02 12:22 [UTC-7] by Muied Lumens -
    Once you have explored one channel, set up an other one, using an other aux out if possible. The extra channel in isolation will act as an other oscillator, and you can create some nice detuned drones this way, but interesting things happen once they start interfering with each other. One can act as an LFO on the other, you can get strange intermodulation going, or other unheard of squeals, unique to your equipment will emerge. If it blows your mind like it did mine when I first tried it, you will slowly increase the complexity of your setup, adding effects and processing until you have no idea what's going on any more! How you proceed is up to you, but there are no rules except for the safety ones. Always be sure of where your main volume output is, both in level and physical space.
    to:
    2013-02-02 12:19 [UTC-7] by Muied Lumens -
    Added lines 41-54:
    !!!Chaotic systems
    If you are at all familiar with how chaotic systems work, you will know that small changes in input can result in a huge difference in output. You should be able to see this in action when you change a single gain stage in a multiple loop feedback setup for example. You may end up with a situation where you have a relatively large range which makes no difference and suddenly at a specific "hot spot" it will take off in a new direction. It is often around these hotspots that you can find interesting variations to play with, and even where the audio can take on that strange, alien quality and start changing without you interfering at all. As comes with the territory, these situations are very difficult to plan ahead for or repeat, but if you keep at it eventually magic will start happening for you.
    !!!Software feedback
    Not all software will let you create feedback loops, in fact, some software will prevent you from creating a feedback loop alltogether. Reaper, which is a powerful and affordable DAW, has an option that lets you switch off this safety measure (File > Project Settings > Advanced). Most modular software, like Max, Puredata, Supercollider, Plogue Bidule and Kyma will let you create feedback loops internally in the software, but be aware of a particular difference between software and analog feedback systems. The software has to actually process the data it produces so if you create very short loops it will cost you in processing power, and can cause the program to crash.
    2013-02-02 12:08 [UTC-7] by Muied Lumens -
    Changed line 38 from:
    Delays will slow down the movement of the feedback, if you have them set up correctly. This can make it easier to "play" the feedback, because it gives you more time to react to changes, provided the delay time is long enough. You should start with a 100% wet signal, from the mic, through the delay (with no internal feedback) and out of the speakers. No direct signal from the mic should reach the speakers. The delay time is up to you, but 500 ms is probably a good starting point. Now take the mic in your hand and move it around the room (but be within reach or the main fader). If everything is set up and you have enough gain, you should be able to play the room! Different spots will give you different sounds or tones. I find that adding distortion makes it easier to achieve this at lower volumes, but YMMV. Also adding resonators, like placing the mic inside a bowl or tube will accentuate this effect. You may have to go quite loud to get it working properly, so make sure your neighbours are sane, sensible people. ;)
    to:
    2013-02-02 10:37 [UTC-7] by Muied Lumens -
    Changed line 40 from:
    If you do not have a microphone handy, you can use other types of transducers, like headphones, speakers, piezo trancducers ond so on, in place of a mic. When uisng something that is not as sensitive as a mic normally is, it helps to compress or distort the input to force some decent levels and add harmonics. You can of course also use electric guitars or other instruments, just laid flat on a table, the more the merrier! The more complexity you add the better, as long as you are in control of the main output.
    to:
    2013-02-02 10:34 [UTC-7] by Muied Lumens -
    Added lines 39-40:
    2013-02-02 10:03 [UTC-7] by Blue Hell -
    Added lines 3-5:
    !!!by Muied Lumens
    (:div:)
    2013-02-02 09:47 [UTC-7] by Muied Lumens -
    Changed lines 1-3 from:
    ![+'''Feedback (No-input Mixing)'''+]
    to:
    !Feedback (No-input Mixing)
    Changed lines 6-7 from:
    '''But hold on... '''
    to:
    !!!But hold on...
    Changed lines 19-20 from:
    '''Setting up your first session'''
    to:
    !!!Setting up your first session
    Changed line 29 from:
    '''Using the room'''
    to:
    !!!Using the room
    2013-02-01 22:10 [UTC-7] by Muied Lumens -
    Changed line 4 from:
    If you have ever pondered on the mathematics behind those beautiful patterns that make up fractal images you have marvelled at the raw beauty of feedback. Many of these images are made up of very simple mathematical expressions, where the result is fed in to itself (or iterated), over and over. Feedback is a phenonemon that exists all around us in various shapes and forms, and by experimenting with this in audio you will maybe gain some insight into it on a new level. Once you start really playing with feedback it begins to take on a life on its own and almost feels like a living entity. It is something that speaks to your intuitive side more than your intellect, because even with fairly simple setups, the behaviour of the fed back sound goes beyond what you can easily understand, and it simply boils down to how you interact with it in the moment.
    to:
    2013-02-01 22:09 [UTC-7] by Muied Lumens -
    If you have ever wondered about the mathematics behind those beautiful patterns that make up fractal images you have marvelled at the raw beauty of feedback. Many of these images are made up of very simple mathematical expressions, where the result is fed in to itself (or iterated), over and over. Feedback is a phenonemon that exists all around us in various shapes and forms, and by experimenting with this in audio you will maybe gain some insight into it on a new level. Once you start really playing with feedback it begins to take on a life on its own and almost feels like a living entity. It is something that speaks to your intuitive side more than your intellect, because even with fairly simple setups, the behaviour of the fed back sound goes beyond what you can easily understand, and it simply boils down to how you interact with it in the moment.
    to:
    2013-02-01 21:53 [UTC-7] by Muied Lumens -
    Changed line 8 from:
    First, a word or two of warning. Taking a signal and amplifying it, then reamplifying it again and again and again ad infinitum results in a very loud signal. It will almost immediately hit the ceiling of what your equipment is capable of reproducing (unless you delay it, more on that later). It is therefore essential that you protect yourself and your equimment from damage. Here are a few guidelines, but use your sense at all times...
    to:
    First, a word or two of warning. Taking a signal and amplifying it, then reamplifying it again and again and again ad infinitum results in a very loud signal. It will almost immediately hit the ceiling of what your equipment is capable of reproducing (unless you delay it, more on that later). It is therefore essential that you protect yourself and your equipment from damage. Here are a few guidelines, but use your sense at all times...
    2013-02-01 21:42 [UTC-7] by Muied Lumens -
    Making a simple feedback loop is very easy. You take an amplifier and connect it's output back to its input, and turn it up. At some point, the amplifier turns into an oscillator. You can't hear what is going on unless you split the output and that is where a mixer comes in. If you take the main output of a mixer and plug it into one of the channels you have the same thing happening.
    to:
    2013-02-01 21:37 [UTC-7] by Muied Lumens -
    Added line 2:
    Changed line 1 from:
    [==][+'''Feedback (No-input Mixing)'''+]
    to:
    to:
    2013-02-01 21:12 [UTC-7] by Muied Lumens -
    Added lines 1-36:
    * Don't use headphones - since they are directly placed over your ears and loud signals will more easily damage your hearing.
    * Lower your main output to protect your speakers - they are the most likely part of your equipment to blow up if things get out of hand.
    * Never leave a feedback loop alone - at least not to start with. Nurse it and get to know how things behave over time.
    * Be sensitive to pets - some very strange things happen to audio gear when you push it that may affect them.
    Mixers are very handy in feedback configurations because you can route and split signals and amplify them too. If you have a mixer with an aux out, and route that back into one of the channels using a cable, you can control the overall volume of the main output and whack up the channel and aux gain to create feedback. In other words, the volume on the channel will be extremely loud, so you need to almost completely turn down the main fader to compensate for this, and keep a cautious finger on it while you increase the gain of your feedback. Make sure you understand this gain structure before you start, it's at the very foundations of feedback performance.
    If your mixer has meters or overload indicators, they will come in handy as they can show you if there is a signal. When you have a stable tone going, experiment with volume changes and other parts of your channel, like the EQ, polarity invert, gain, etc. You will quickly get an idea of how things work. It is very hard to reproduce exact results over and over, so I recommend that you have something standing by to record with.
    Adding a mic gives you literally a whole new set of dimensions to the feedback. It also adds some problems you should be aware of. When a mic comes into the picture, the unreliability of the system increases many fold, and your alertness should too. There are two simple ways of making sure that you are in control, more or less, and you should make use of both of them. They are the limiter and the delay.
    [[~Muied Lumens]]
    Edit - History - Print - Recent Changes - Search Page last modified on 2013-03-24 19:16 [UTC-7] - 12673 views
