Recent Changes - Search:
Contents
Site
Help
« mar 2019 · jul 2019 »
    add a calendar item
    Main / Chatter
    Main.Chatter History
    Hide minor edits - Show changes to output
    2015-03-03 17:17 [UTC-7] by Blue Hell -
    Changed line 90 from:
    [[Radio.RadioInfoSrv2]], [[Radio.RadioInfoSrv3]] and [[Radio.RadioManagePublic]]
    to:
    [[Radio.RadioInfoSrv2]] and [[Radio.RadioManagePublic]]
    Added lines 18-19:
    ->Starting to look cool now... {cool} ??~[Q]??.
    2013-04-03 20:55 [UTC-7] by Blue Hell -
    Changed lines 92-93 from:
    {-Made a menu thingie for it too [[Radio.RadioManagementPages]]
    [[~Blue Hell]]-}
    to:
    [[~Blue Hell]] - and removed it again ...
    2013-04-03 20:53 [UTC-7] by Blue Hell -
    [[~Blue Hell]]
    to:
    [[~Blue Hell]]-}
    2013-04-02 19:01 [UTC-7] by Blue Hell -
    Changed line 224 from:
    Put in some work for [[Radio.ConnectionInfo]] - OMG we made that radio complicated ... some clever thought will be needed to split up the radio pages and then combine them into something coherent.
    to:
    Put in some work for [[Radio.ConnectionDetails]] - OMG we made that radio complicated ... some clever thought will be needed to split up the radio pages and then combine them into something coherent.
    2013-04-01 22:24 [UTC-7] by Blue Hell -
    Changed line 15 from:
    I've totally turned it inside out ... to bring more structure ... and it struck me that visitors dont want to see menu pages, they want content ... so I stripped some of those. Still not quite what I'd want, but at least one can just tune in now immediately after hitting Radio in the side bar.
    to:
    I've totally turned it inside out ... to bring more structure ... and it struck me that visitors dont want to see menu pages, they want content ... so I stripped some of those. Still not quite what I'd want, but at least one can just tune in now immediately after hitting Radio in the side bar and I got out the tech stuff from the intro and program info pages.
    2013-04-01 22:22 [UTC-7] by Blue Hell -
    Added lines 16-17:
    ??~Blue Hell?? 2013-04-01 20:22 [UTC-7]
    Added lines 12-16:
    !!!Radio menus again
    >>bgcolor=#dee3e7 border='0px solid gray' padding=5px<<
    Changed line 62 from:
    I tried to block up the Site.MenuRadio with bgcolor to make it easier to read.. but it does not work [[Help.Drafting1]].. I prefer what we have already.. \\
    to:
    I tried to block up the Site.MenuRadio with bgcolor to make it easier to read.. but it does not work.. I prefer what we have already.. \\
    Changed lines 63-64 from:
    You could always add a dummy * to the bottom to balance things out.. :-) [Q].
    to:
    You could always add a dummy * to the bottom to balance things out.. :-) ??~[Q]??.
    Changed line 75 from:
    [[http://electro-music.com/forum/profile.php?mode=viewprofile&u=26139 | Q]].
    to:
    ??~[Q]??.
    Changed line 88 from:
    ->These new Radio Pages are most excellent and very functional.. thank you.. Menu changes look good too.. :-) [Q].
    to:
    ->These new Radio Pages are most excellent and very functional.. thank you.. Menu changes look good too.. :-) ??~[Q]??.
    Changed lines 100-101 from:
    ->Hehe..  :-) what port does it use.. I have many ports blocked and 80% of google.. [Q].
    to:
    ->Hehe..  :-) what port does it use.. I have many ports blocked and 80% of google.. ??~[Q]??.
    Changed line 104 from:
    -> mmm black screen here.. I must have the IP address blocked.. [Q]. \\
    to:
    -> mmm black screen here.. I must have the IP address blocked.. ??~[Q]??. \\
    Changed lines 113-114 from:
    to:
    ??~[Q]??.
    Changed lines 124-125 from:
    If we make every menu look like this one [[Radio.Temp]] with an appropiate menu title.. the map will indicate where you are.. and we only need to make one change in the [[Site.MenuRadio]] page and its done.. instead of the four entries we currently need to make. phew... not perfect but better.. :-) [Q].
    to:
    If we make every menu look like this one [[Radio.Temp]] with an appropiate menu title.. the map will indicate where you are.. and we only need to make one change in the [[Site.MenuRadio]] page and its done.. instead of the four entries we currently need to make. phew... not perfect but better.. :-) ??~[Q]??.
    Changed lines 132-133 from:
    Done the How  To for changing the [[Help.SiteSpecificMarkup#ntoc33 | Radio Menu]] [Q].
    to:
    Done the How  To for changing the [[Help.SiteSpecificMarkup#ntoc33 | Radio Menu]] ??~[Q]??.
    Changed lines 145-146 from:
    ->I've added a [[Radio.RadioSchedule]] page.. a big oversight {eek} and I've updated [[Radio.FutureEvents]] page so that it focuses on Forthcoming Events (please restore if you want), it still needs some work on the intro. (I've had an idea for the menus that I need to work on before I forget it). [Q].
    to:
    ->I've added a [[Radio.RadioSchedule]] page.. a big oversight {eek} and I've updated [[Radio.FutureEvents]] page so that it focuses on Forthcoming Events (please restore if you want), it still needs some work on the intro. (I've had an idea for the menus that I need to work on before I forget it). ??~[Q]??.
    Changed lines 157-158 from:
    for emphasis is cool.. {cool} [Q].
    to:
    for emphasis is cool.. {cool} ??~[Q]??.
    Changed lines 166-167 from:
    ->The stub box looks cool too :-) [Q].
    to:
    ->The stub box looks cool too :-) ??~[Q]??.
    Changed lines 185-186 from:
    [Q].
    to:
    ??~[Q]??.
    Changed lines 189-190 from:
    -->indets ok :-) [Q].
    to:
    -->indets ok :-) ??~[Q]??.
    Changed lines 224-225 from:
    ->with collapsible menus... :-) [Q]
    to:
    ->with collapsible menus... :-) ??~[Q]??.
    Changed lines 232-233 from:
    -->Please can you delete [[Site.HistoryAndArchiveMenu]] page.. thank you :-) [Q].
    to:
    -->Please can you delete [[Site.HistoryAndArchiveMenu]] page.. thank you :-) ??~[Q]??.
    Changed lines 238-239 from:
    -->I've moved Map of Radio Pages to [=(:include Radio.RadioPagesMap:)=].. thats better :-) [Q].
    to:
    -->I've moved Map of Radio Pages to [=(:include Radio.RadioPagesMap:)=].. thats better :-) ??~[Q]??.
    Changed lines 270-271 from:
    Not sure why [[Site.PageViews | PageViews]] appears in the {_stubs_} :( . [Q].
    to:
    Not sure why [[Site.PageViews | PageViews]] appears in the {_stubs_} :( . ??~[Q]??.
    Changed lines 300-301 from:
    At some point we are going to need a method of archiving long Talk pages. [Q].
    to:
    At some point we are going to need a method of archiving long Talk pages. ??~[Q]??.
    Changed lines 310-311 from:
    Lots of good points there that need discussion.. how about we start a page for discussion of [[ArchivingTalk]].. plenty of time yet. [Q].
    to:
    Lots of good points there that need discussion.. how about we start a page for discussion of [[ArchivingTalk]].. plenty of time yet. ??~[Q]??.
    Changed lines 333-334 from:
    http://en.wikipedia.org/wiki/Wikipedia:WikiProject_Stub_sorting/Stub_types [Q].
    to:
    http://en.wikipedia.org/wiki/Wikipedia:WikiProject_Stub_sorting/Stub_types ??~[Q]??.
    Changed lines 337-338 from:
    was not thinking about using it with stubbing (that was just an example page).. but with large collaborative pages.. to make it easier for people contributing or editing. [Q].
    to:
    was not thinking about using it with stubbing (that was just an example page).. but with large collaborative pages.. to make it easier for people contributing or editing. ??~[Q]??.
    Changed lines 360-361 from:
    Do we have an Icon for a Stub and a page for all Stubs. [Q].
    to:
    Do we have an Icon for a Stub and a page for all Stubs. ??~[Q]??.
    Changed lines 364-365 from:
    [[http://en.wikipedia.org/wiki/Wikipedia:Stub]] it helps people to collaborate. Just look down the list of stubs to see what you can add to articles. [Q].
    to:
    [[http://en.wikipedia.org/wiki/Wikipedia:Stub]] it helps people to collaborate. Just look down the list of stubs to see what you can add to articles. ??~[Q]??.
    Changed line 376 from:
    The stub page does appear on the Category . Stub page :) . [Q]
    to:
    The stub page does appear on the Category . Stub page :) . ??~[Q]??.
    Changed lines 383-385 from:
    The Articles section could benefit from having sub sections such as: Audio, DIY, Bio's, etc. [Q].
    An index of tags would do this.. [Q].
    to:
    The Articles section could benefit from having sub sections such as: Audio, DIY, Bio's, etc. ??~[Q]??.
    An index of tags would do this.. ??~[Q]??.
    Changed lines 392-393 from:
    Being able to apply multiple tags to pages should assist in navagation. [Q].
    to:
    Being able to apply multiple tags to pages should assist in navagation. ??~[Q]??.
    Changed line 396 from:
    defined tags (categories) - that's it :) . [Q].
    to:
    defined tags (categories) - that's it :) . ??~[Q]??.
    Changed lines 20-21 from:
    to:
    ??~[Q]??.
    Added lines 40-41:
    -> :-) ??~[Q]??.
    2013-04-01 16:30 [UTC-7] by Blue Hell -
    Changed line 33 from:
    ?? ?? 's.
    to:
    ?? ?? 's ... on the same line that is.
    Deleted line 32:
    Changed lines 32-34 from:
    Can not use ?? now anymore twice in one line ??
    A
    lil more work needed. Ok, just do not use a | in between two ?? ?? 's.
    to:
    Can not use ?? now anymore twice in one line ?? A lil more work needed. Ok, just do not use a | in between two
    ?? ?? 's.
    2013-04-01 15:42 [UTC-7] by Blue Hell -
    Added lines 113-114:
    Ah, yeah, forgot that the Mibbit page uses stuff too. ??~Blue Hell??
    2013-04-01 15:41 [UTC-7] by Blue Hell -
    Added lines 37-38:
    User names with both a ] and a ? still won't work ... but I'm guessing that ? is an illegal character in phpbb user names.
    2013-04-01 15:32 [UTC-7] by Blue Hell -
    Changed line 36 from:
    [-Hmm .. that means the [@%@][@%@][@%@] is no longer needed either [@~@][@~@][@~@] stuff should always work ... well .. unless a user name has ? and ] in it .. ok removing the [@%@][@%@][@%@] stuff again.-] nonsense ... forget it ... sign with [@%@][@%@][@%@] or [@%@][@%@][@%@][@%@].
    to:
    {-Hmm .. that means the [@%@][@%@][@%@] is no longer needed either [@~@][@~@][@~@] stuff should always work ... well .. unless a user name has ? and ] in it .. ok removing the [@%@][@%@][@%@] stuff again.-} nonsense ... forget it ... sign with [@%@][@%@][@%@] or [@%@][@%@][@%@][@%@] please.
    2013-04-01 15:31 [UTC-7] by Blue Hell -
    to:
    2013-04-01 15:19 [UTC-7] by Blue Hell -
    Added lines 35-36:
    2013-04-01 15:14 [UTC-7] by Blue Hell -
    Changed lines 24-25 from:
     [=??http://electro-music.com/forum/profile.php?mode=viewprofile&u=ID | [username]??=]
    to:
     [=??http://elec ... ile&u=ID | [username]??=]
    Changed line 28 from:
     [=[[http://electro-music.com/forum/profile.php?mode=viewprofile&u=ID | [username]]]=]
    to:
     [=[[http://elec ... ile&u=ID | [username]]]=]
    2013-04-01 15:13 [UTC-7] by Blue Hell -
     [=??http://electro-music.com/forum/profile.php?mode=viewprofile&u=26139 | [username]??=]
    to:
     [=[[http://electro-music.com/forum/profile.php?mode=viewprofile&u=26139 | [username]]]=]
    to:
    2013-04-01 15:12 [UTC-7] by Blue Hell -
    Changed lines 24-30 from:
    [=??http://electro-music.com/forum/profile.php?mode=viewprofile&u=26139 | [username]??=] used now instead of [=[[http://electro-music.com/forum/profile.php?mode=viewprofile&u=26139 | [username]]]=] when there is a ] in the username.
    to:
    used now instead of
    Changed line 24 from:
    [=??http://electro-music.com/forum/profile.php?mode=viewprofile&u=26139 | Q??=] used now instead of [=[[http://electro-music.com/forum/profile.php?mode=viewprofile&u=26139 | Q]]=] when there is a ] in the username.
    to:
    2013-04-01 15:11 [UTC-7] by Blue Hell -
    Ok, a lil more work needed.
    to:
    A lil more work needed. Ok, just do not use a | in between two ?? ?? 's.
    2013-04-01 15:07 [UTC-7] by Blue Hell -
    Added lines 27-28:
    Changed lines 22-28 from:
    Seems fixed [=??http://electro-music.com/forum/profile.php?mode=viewprofile&u=26139 | Q??=] used now instead of [=[[http://electro-music.com/forum/profile.php?mode=viewprofile&u=26139 | Q]]=] when there is a ] in the username. ??~Blue Hell??
    to:
    Seems fixed now.
    ??~Blue Hell??
    2013-04-01 15:04 [UTC-7] by Blue Hell -
    Added lines 21-22:
    Changed lines 83-93 from:
    to:
    nope.. wasn't a blocked IP address... \\
    it uses Port 443 as well.. and the following servers connect.. \\
    173.194.67.104 :443 HTTPS firefox GOOGLE
    205.251.242.100 :443 HTTPS firefox AMAZON-05
    72.21.195.1 :443 HTTPS firefox AMAZON-02
    ->as well as lots on Port 80.. :-( \\
    Changed line 20 from:
    to:
    Added lines 51-54:
    ->It looks good and no crashes so far.. \\
    I don't like the stripy stuff.. I prefer the box and [=bgcolor=#f0f9ff=] :-) \\
    Added lines 18-20:
    ->Alas... ??~[Q]?? the end bracket is the wrong color :-( \\
    2013-03-31 21:21 [UTC-7] by Blue Hell -
    Deleted line 10:
    2013-03-31 20:39 [UTC-7] by Blue Hell -
    Changed line 16 from:
    See [[Help.SiteSpecificMarkup#ntoc34 | there]] for a fix of this. In short, being [Q] you can now sign with [@%@][@%@][@%@] or [@%@][@%@][@%@][@%@] - hopefully, it works on my name .. lemme see ??~[Q]??
    to:
    See [[Help.SiteSpecificMarkup#ntoc34 | there]] for a fix of this. In short, being [Q] you can now sign with [@%@][@%@][@%@] or [@%@][@%@][@%@][@%@] - hopefully, it works on my name .. lemme see ??~[Q]?? :-)
    2013-03-31 20:38 [UTC-7] by Blue Hell -
    to:
    2013-03-31 20:33 [UTC-7] by Blue Hell -
    Changed lines 16-18 from:
    to:
    ??~Blue Hell??
    2013-03-31 20:27 [UTC-7] by Blue Hell -
    Added lines 12-19:
    !!!User names with brackets
    2013-03-31 19:02 [UTC-7] by Blue Hell -
    Added line 333:
    2013-03-31 19:01 [UTC-7] by Blue Hell -
    Changed lines 173-174 from:
    to:
    Deleted line 196:
    Added line 198:
    Changed lines 200-201 from:
    to:
    Added line 206:
    Changed lines 208-210 from:
    to:
    Added line 213:
    Changed lines 215-217 from:
    to:
    Added line 220:
    Changed lines 234-235 from:
    to:
    Added line 240:
    Changed lines 244-246 from:
    to:
    Added line 250:
    Changed lines 264-267 from:
    to:
    Changed line 269 from:
    to:
    Deleted line 275:
    Changed lines 277-280 from:
    to:
    Changed line 282 from:
    to:
    Changed lines 291-294 from:
    to:
    Changed line 296 from:
    to:
    Changed lines 305-308 from:
    to:
    Changed line 310 from:
    to:
    Changed lines 328-331 from:
    to:
    Deleted line 332:
    Changed lines 336-339 from:
    to:
    Changed line 341 from:
    to:
    Changed line 347 from:
    to:
    2013-03-31 18:54 [UTC-7] by Blue Hell -
    Added lines 33-36:
    Ok, fixed likely, had a count variable starting at 0 where it should likely start at 1 ... not 100% sure, we'll see where it crashes now, sofar it looks ok.
    The stripy stuff .. I don't know about that ... besides, if done it is probably something better done from CSS, it is a lot of work this way.
    2013-03-31 18:44 [UTC-7] by Blue Hell -
    Added lines 31-34:
    Turns out that a single colon (:) works as well - looks a tad better ... still trying to understand the code.
    [[~Blue Hell]]
    Changed lines 29-30 from:
    I tried to block up the Site.MenuRadio with bgcolor to make it easier to read.. but it does not work [[Help.Drafting1]].. I prefer what we have already.. [Q].
    to:
    [Q].
    Added lines 27-29:
    -> It's a good plan to split the menus up.. gives each one room to grow.. \\
    Added lines 57-58:
    2013-03-31 17:58 [UTC-7] by Blue Hell -
    Good plan? [[~Blue Hell]]
    to:
    Good plan?
    Deleted lines 22-23:
    [[~Blue Hell]]
    2013-03-31 17:57 [UTC-7] by Blue Hell -
    Good plan? [[~Blue Hell]] 2013-03-31 12:43 [UTC-7]
    to:
    Added lines 24-25:
    [[~Blue Hell]]
    Added lines 27-28:
    [[~Blue Hell]]
    2013-03-31 17:51 [UTC-7] by Blue Hell -
    Added lines 23-24:
    Right ... the unfolding can be stopped by starting the menu with a dummy line having one * only - doesnt look nice though on seeing the menu - so will prolly need be determined what's wrong with the code - don't quite get it tho.
    2013-03-31 16:15 [UTC-7] by Blue Hell -
    Changed lines 18-19 from:
    I think it would be best to split off / Articles / Photo Albums / Schematics Vault / from Site.MenuContents, then rename Site.MenuContents into Site.MenuRadioContents or something and make Site.MenuAlbumsContents etc. as well - then alter the side bar to reflect the changes.
    to:
    I think it would be best to split off / Articles / Photo Albums / Schematics Vault / from Site.MenuContents, then rename Site.MenuContents into Site.MenuRadio and make Site.MenuAlbums etc. as well - then alter the side bar to reflect the changes.
    Changed lines 57-58 from:
    If we make every menu look like this one [[Radio.Temp]] with an appropiate menu title.. the map will indicate where you are.. and we only need to make one change in the [[Site.MenuContents]] page and its done.. instead of the four entries we currently need to make. phew... not perfect but better.. :-) [Q].
    to:
    Changed line 63 from:
    To add, remove or move a page or menu.. it requires one change on the [[Site.MenuContents]] page. \\
    to:
    To add, remove or move a page or menu.. it requires one change on the [[Site.MenuRadio]] page. \\
    Changed line 160 from:
    Editable through [[Site.MenuContents]] - it still runs through the drafting pages now. [[~Blue Hell]]
    to:
    Editable through [[Site.MenuRadio]] - [-it still runs through the drafting pages now-]. [[~Blue Hell]]
    2013-03-31 16:03 [UTC-7] by Blue Hell -
    Added lines 21-22:
    Hmm .. started on it ... it seems to reveal a bug in the menu system .. or is it a feature - the Radio menu is always folded out now.
    2013-03-31 14:48 [UTC-7] by Blue Hell -
    Added lines 46-47:
    Port 80 ... [[~Blue Hell]]
    Changed line 50 from:
    to:
    2013-03-31 14:47 [UTC-7] by Blue Hell -
    Changed line 48 from:
    to:
    2013-03-31 14:43 [UTC-7] by Blue Hell -
    Changed lines 16-20 from:
    I was going to add some sub menus to the Photo Albums section, but that would make the radio menus very large - I think it would be best to split off / Articles / Photo Albums / Schematics Vault / from Site.MenuContents, then rename Site.MenuContents into Site.MenuRadioContents or something and make Site.MenuAlbumsContents etc. as well - then alter the side bar to reflect the changes. Good plan?
    to:
    I was going to add some sub menus to the Photo Albums section, but that would make the radio menus very large.
    Changed lines 14-15 from:
    to:
    !!!Split up menus?
    Deleted line 20:
    Added lines 25-26:
    Added lines 37-38:
    2013-03-31 13:22 [UTC-7] by Blue Hell -
    Deleted line 115:
    Added line 163:
    Deleted line 164:
    Deleted line 165:
    Changed line 116 from:
    to:
    2013-03-31 13:20 [UTC-7] by Blue Hell -
    Added line 118:
    Changed lines 122-125 from:
    to:
    Added line 128:
    Changed line 130 from:
    to:
    Changed line 133 from:
    to:
    Added line 135:
    Changed lines 159-160 from:
    to:
    Added line 165:
    Changed line 167 from:
    to:
    2013-03-31 13:19 [UTC-7] by Blue Hell -
    Changed lines 78-79 from:
    to:
    Changed lines 112-113 from:
    to:
    2013-03-31 13:18 [UTC-7] by Blue Hell -
    Added line 58:
    Changed lines 66-68 from:
    to:
    2013-03-31 13:17 [UTC-7] by Blue Hell -
    Changed line 38 from:
    to:
    Added line 40:
    Changed lines 53-54 from:
    to:
    Added line 29:
    !!!Embedded IRC chat
    Deleted line 30:
    2013-03-31 13:16 [UTC-7] by Blue Hell -
    to:
    Changed line 29 from:
    to:
    Changed lines 31-33 from:
    [[http://electro-music.com/wiki/pmwiki.php?n=Forum.MibbitChat | Mibbit IRC chat]] - to be finished soon - sorry [Q], hope it's not too tempting ;-) [[~Blue Hell]]
    Fixed now - made it accessible for logged in users
    only. [[~Blue Hell]]
    to:
    only.
    [[~Blue Hell]]
    2013-03-31 13:15 [UTC-7] by Blue Hell -
    Added lines 13-14:
    Added line 18:
    Changed lines 23-26 from:
    Made a menu thingie for it too [[Radio.RadioManagementPages]] [[~Blue Hell]]
    to:
    [[~Blue Hell]]
    2013-03-31 13:14 [UTC-7] by Blue Hell -
    Added lines 19-20:
    2013-03-31 12:52 [UTC-7] by Blue Hell -
    [[Radio.RadioInfoSrv2]] and [[Radio.RadioInfoSrv3]]
    to:
    2013-03-31 11:49 [UTC-7] by Blue Hell -
    Changed line 25 from:
    Fixed now. [[~Blue Hell]]
    to:
    Fixed now - made it accessible for logged in users only. [[~Blue Hell]]
    2013-03-31 11:48 [UTC-7] by Blue Hell -
    Changed line 23 from:
    http://electro-music.com/wiki/pmwiki.php?n=Forum.MibbitChat - to be finished soon - sorry [Q], hope it's not too tempting ;-) [[~Blue Hell]]
    to:
    2013-03-31 11:47 [UTC-7] by Blue Hell -
    Added lines 24-25:
    2013-03-30 21:10 [UTC-7] by Blue Hell -
    http://electro-music.com/wiki/pmwiki.php?n=Radio.RadioInfoSrv2 & http://electro-music.com/wiki/pmwiki.php?n=Radio.RadioInfoSrv3
    to:
    2013-03-30 21:09 [UTC-7] by Blue Hell -
    Added lines 13-18:
    !!!New radio pages
    there will be some more prolly, also thinking about embedding all radio overview and control pages into the wiki as well - with some proper group management that should be safe and .. it would be {-googleable-} findable then.
    2013-03-30 20:23 [UTC-7] by Blue Hell -
    Changed line 17 from:
    to:
    2013-03-30 20:22 [UTC-7] by Blue Hell -
    Added lines 12-17:
    Changed line 22 from:
    To add, remove or move a page or menu.. it requires one change on the [[Site.MenuContents]]page. \\
    to:
    2013-03-30 20:14 [UTC-7] by Blue Hell -
    Added line 26:
    ->It improved, thanks! [[~Blue Hell]]
    Changed lines 23-25 from:
    sometimes it's easier to do than explain :-) [Q].
    to:
    Sometimes it's easier to do than explain :-) \\
    sometimes it's easier to do than explain :-)[Q].
    to:
    Changed lines 22-23 from:
    To add, remove or move a page or menu.. it requires one change on the [[Site.MenuContents]]page.[Q].
    to:
    [Q].
    Added lines 20-22:
    It's done.. can restore if not good.. it's different.. :-) \\
    2013-03-30 18:59 [UTC-7] by Blue Hell -
    Added line 19:
    ->Ah, ok, I see what you mean now :-)
    2013-03-30 14:09 [UTC-7] by Blue Hell -
    Added line 18:
    -> o_o no idea what you are talking about, just put 'r in then ;-) [[~Blue Hell]]
    Added line 74:
    ->I can't see the pixel disturbance.. and I love the new page color.. :D
    Added lines 13-16:
    !!!Radio Menu
    Radical Change...\\
    2013-03-30 13:33 [UTC-7] by Blue Hell -
    Added lines 67-69:
    Some pixel milling done on rulers ... they seem less disturbing now to me. [[~Blue Hell]]
    2013-03-30 13:32 [UTC-7] by Blue Hell -
    Added lines 22-24:
    Good plan :-) [[~Blue Hell]]
    Added lines 62-63:
    Added line 21:
    2013-03-30 12:36 [UTC-7] by Blue Hell -
    Added lines 59-60:
    ->set them to indent 24 pixels now, that still enough? [[~Blue Hell]]
    Added lines 50-58:
    Also I'd like to remove some of the horizontal bars on pages (the ---- things) ...
    I think colored backgrounds are easier on the eye than the horizontal rulers ...
    ->I concur. :-) colored backgrounds are nicer..
    Lets go with.. [[Radio.RadioMenu]] as is.. with those colored backgrounds for the menus.
    I like the large indents (in the Map) easy to read..
    [Q].
    2013-03-30 12:20 [UTC-7] by Blue Hell -
    Changed lines 41-42 from:
    I think the green (hmm .. on the mac it's more blue like, on this screen it's more green like) for the radio map is good to make it stand out (and just applied it to [[Site.SpecialPages]] too), but also that on for instance [[Radio.StreamingInfoMenu]] either both colored areas should have a border, or alternatively, both should ''not'' have a border ...
    to:
    I think the green (hmm .. on the mac it's more blue like, on this screen it's more green like) for the radio map is good to make it stand out (and just applied it to [[Site.SpecialPages]] too), but also that on for instance [[Radio.StreamingInfoMenu]] either both colored areas should have a border, or alternatively, both should ''not'' have a border ... also see [[Testing.01]]
    Changed lines 47-49 from:
    Anyway, I was just experimenting a bit ... not too sure either. Oh and I did a lot of pixel fiddling too - add a couple here remove some there ... [[~Blue Hell]]
    to:
    Apart from that the standard nested list markup seems to indent a bit much, guess I should trim some pixels off there too
    . [[~Blue Hell]]
    2013-03-30 10:56 [UTC-7] by Blue Hell -
    Changed lines 41-47 from:
    I think the green (hmm .. on the mac it's more blue like, on this screen it's more green like) for the radio map is good to make it stand out (and just applied it to [[Site.SpecialPages]] too), but also that on for instance [[Radio.StreamingInfoMenu]] either both colored areas should have a border, or alternatively, both should ''not'' have a border ... also I'd like to remove some of the horizontal bars on pages (the [=----=] things) ... I think colored backgrounds are easier on the eye than the horizontal rulers ... you'd want to remove the color backrounds from the menu's too? Anyway, I was just experimenting a bit ... not too sure either. Oh and I did a lot of pixel fiddling too - add a couple here remove some there ... [[~Blue Hell]]
    to:
    Also
    You
    2013-03-30 10:55 [UTC-7] by Blue Hell -
    Added line 41:
    Changed line 39 from:
    ->[Q].
    to:
    Added lines 34-39:
    ->I think too many colored boxes is not good.. I think the Map needs a box and I really like what you did with the green text it indicates where you are on the Map.. :-) I am still not sure about the color of the Map box.. and I like the Menu section at the top of the page without a box this make it consistant with how you have used it on the rest of the wiki. \\
    For comparison...
    *[[Radio.RadioMenu]]
    *[[Radio.StreamingInfoMenu]]
    *[[Radio.Temp]]
    ->[Q].
    2013-03-30 00:56 [UTC-7] by Blue Hell -
    Deleted line 7:
    Deleted lines 10-14:
    Added line 12:
    2013-03-30 00:55 [UTC-7] by Blue Hell -
    Deleted lines 11-14:
    Added lines 13-17:
    Changed lines 7-8 from:
    Please add a new item at the top and precede that item with [=!!!=] to get it into the table of contents properly; don't make an item too long or talk about it forever, start a new item instead of responding on one deep down, otherwise it will be hard to find.
    to:
    Please add new items at the top and precede them with
    [=!!!=] to get it into the table of contents; don't make an item too long or talk about it forever, start a new item instead of responding on one deep down, otherwise it will be hard to find.
    Added lines 16-17:
    2013-03-30 00:53 [UTC-7] by Blue Hell -
    Changed line 1 from:
    >>lframe font-size:smaller<<
    to:
    >>rframe font-size:smaller<<
    Deleted lines 6-7:
    Added lines 12-13:
    2013-03-29 22:17 [UTC-7] by Blue Hell -
    Added lines 18-19:
    Made something quick and dirty - an 11 - 12 moth look ahead thingie, see [[Help.SiteSpecificMarkup]] and for an example see [[Radio.FutureEvents]] which I put into some of the radio menus instead of [[Calendar.Calendar]]. It basically uses the same codse as the sidebar fix, but the sidebar looks 1 - 2 months into the future only. [[~Blue Hell]]
    2013-03-29 20:59 [UTC-7] by Blue Hell -
    I toyed a bit with the calendar code such that [[Calendar.Calendar]] and such don't fuzz up the sidebar anymore. I still want a sort of a category page for calendar pages (where all events can be viewed) - but I want that to be automatic. Tested some stuff before, but deleted it again .. was not good .. back to the drawing board ...
    to:
    I toyed a bit with the calendar code such that [[Calendar.Calendar]] and such don't fuzz up the sidebar anymore. I still want a sort of a category page for calendar pages (where all events can be viewed) - but I want that to be automatic. Tested some stuff before, but deleted it again .. was not good .. back to the drawing board ...  [[~Blue Hell]]
    2013-03-29 20:51 [UTC-7] by Blue Hell -
    it needs the closing [=>><<=] though .. heh, and I sort of stole it from you, some colored boxes are good I think![[~Blue Hell]]
    to:
    it needs the closing [=>><<=] though .. heh, and I sort of stole it from you, some colored boxes are good I think! [[~Blue Hell]]
    2013-03-29 20:50 [UTC-7] by Blue Hell -
    Added lines 13-17:
    !!!Calendar
    2013-03-29 20:46 [UTC-7] by Blue Hell -
    it needs the closing [=>><<=] though .. heh, and I sort of stole it from you ... [[~Blue Hell]]
    to:
    2013-03-29 20:45 [UTC-7] by Blue Hell -
    it needs the closing [=>><<=] though .. heh, and I sort of stole it from you ... [[~Blue Hell]] 2013-03-29 18:45 [UTC-7]
    to:
    Added lines 23-28:
    Added lines 35-36:
    to:
    to:
    Changed lines 15-22 from:
    to:
    !!!Emphasis
    The
    to:
    Added line 20:
    2013-03-28 20:11 [UTC-7] by Blue Hell -
    Changed line 18 from:
    Added website embedding, for an example see [[Articles.NordModularClassicArchive | NM Archive]], added some more info in the [[Help.SiteSpecificMarkup | HowTos]] section. It's not perfect, but it's bloody damn quick to make!
    to:
    Added website embedding, for an example see [[Articles.NordModularClassicArchive | NM Archive]], added some more info in the [[Help.SiteSpecificMarkup | HowTos]] section. It's not perfect (it messes up the wiki layout a bit), but it's bloody damn quick to make!
    2013-03-28 20:09 [UTC-7] by Blue Hell -
    Added line 15:
    Added lines 17-21:
    !!!Website embedding
    Deleted line 22:
    2013-03-26 17:35 [UTC-7] by Blue Hell -
    Added lines 45-46:
    ->Yup! [[~Blue Hell]]
    Changed line 44 from:
    to:
    Changed lines 28-54 from:
    *[[Articles.Articles |Articles]]
    *[[Albums.Albums | Photo Albums]]
    *[[Radio.RadioMenu | Radio]]
    **[[Radio.RadioBroadcastingMenu | Radio Broadcasting]]
    ***[[Radio.ConnectionInfo | Connection Info]]
    ****[[Radio.ConnectInfoButt | Butt]]
    ****[[Radio.ConnectInfoEdcast | Edcast]]
    ****[[Radio.ConnectInfoNicecast | Nicecast]]
    ***[[Radio.ScheduledShows | How to Schedule Shows]]
    ***[[Radio.OpenPortStreaming | Open Port Streaming]]
    ***[[Radio.StreamingInfoMenu |Streaming Info]]
    ****[[Radio.StreamingConnectInfo | Streaming Connect Info]]
    ****[[Radio.StreamingPasswords | Streaming Passwords]]
    **[[Radio.Info | Radio Info]]
    **[[Radio.Radio |Radio Pages Index]]
    **[[Radio.RadioReceptionMenu | Radio Reception]]
    ***[[Calendar.Calendar | Forthcoming Events]]
    ***[[Radio.HistoryAndArchiveMenu | History & Archive]]
    ****[[Radio.HistoricEvents |Historic Events]]
    ****[[Radio.History | History]]
    ****[[Radio.PreviousShows | Previous Shows]]
    ****[[http://electro-music.com/mp3media.php?forums=174&order=date&direction=DESC&owner= | Show Archives]]
    ***[[Radio.HowToListenToTheRadio | How To Listen]]
    ***[[Radio.NextSpecialEvent | Next Special Event]]
    ***[[Radio.ProgramGuide | Program Guide]]
    **[[Radio.RecentChanges |Recent Changes]]
    *[[Schematics.Schematics |Schematics Vault]]
    to:
    2013-03-25 22:37 [UTC-7] by Blue Hell -
    Changed line 68 from:
    Glad you like the folding menus :-) [[~Blue Hell]]
    to:
    ->Glad you like the folding menus :-) [[~Blue Hell]]
    2013-03-25 22:36 [UTC-7] by Blue Hell -
    ->deleted ... to delete remove all contents and put in the single word delete into a page, then save. The map of radio pages would better be on some single page to be included with [=(:include Some.SinglePage:)=]? Or mayeb automated ... not sure if there is a nested list option for auto indexes ...  [[~Blue Hell]]
    to:
    [[~Blue Hell]]
    2013-03-25 22:35 [UTC-7] by Blue Hell -
    Added lines 65-69:
    Changed line 64 from:
    Please can you delete [[Site.HistoryAndArchiveMenu]] page.. thank you :) [Q].
    to:
    Changed lines 62-64 from:
    to:
    -->I think it's {cool} ... I've moved the menus from drafting pages to [[Radio.Radio | Radio group]] and I've added a 'Map of Radio Pages' to the bottom of each menu.. might help stop getting lost..I can remove them if you don't like them.
    Deleted line 27:
    ===[[Contents.Contents | Contents]]===
    Changed lines 30-33 from:
    *[[Help.Drafting2 | Radio]]
    **[[Help.Drafting3 | Radio Broadcasting]]
    ***[[Help.Drafting5 | Connections Info]]
    to:
    Changed lines 38-40 from:
    ***[[Help.Drafting6 |Streaming Info]]
    ****[[Radio.PortData | Port Data]]
    ****[[Radio.PortData20130323 | Port Data Special Event]] (:comment perhaps reuse this page..:)
    to:
    Changed line 43 from:
    **[[Help.Drafting4 | Radio Reception]]
    to:
    Changed line 45 from:
    ***[[Help.Drafting7 | History & Archive]]
    to:
    Changed line 54 from:
    *[[Schematics.Schematics |Schematics Vaults]]
    to:
    2013-03-25 20:45 [UTC-7] by Blue Hell -
    Added lines 15-20:
    !!!Chat room link
    I had typed out that link once too many ... and then there was [={_chat_room_}=] to get {_chat_room_} :-)
    2013-03-25 18:08 [UTC-7] by Blue Hell -
    ->Added something .. seems fine to me, but let me know what you think please.\\
    ->Editable through [[Site.MenuContents]] - it still runs through the drafting pages now. [[~Blue Hell]]
    to:
    Changed lines 56-58 from:
    -->Somehow I saw this coming ;-) Will see if I can find something.  [[~Blue Hell]]
    -->Added something .. seems fine to
    me, but let me know what you think please. [[~Blue Hell]]
    to:
    ->Somehow I saw this coming ;-) Will see if I can find something.\\
    2013-03-25 18:07 [UTC-7] by Blue Hell -
    Changed line 58 from:
    to:
    -->Editable through [[Site.MenuContents]] - it still runs through the drafting pages now. [[~Blue Hell]]
    2013-03-25 17:58 [UTC-7] by Blue Hell -
    Added lines 57-59:
    -->Added something .. seems fine to me, but let me know what you think please. [[~Blue Hell]]
    2013-03-25 15:43 [UTC-7] by Blue Hell -
    Added lines 55-57:
    ->How about something like this in the side bar..
    to:
    ->How about a structure something like this in the side bar..
    Changed lines 20-54 from:
    to:
    ****[[Radio.ConnectionInfo | Connection Info]]
    2013-03-24 22:13 [UTC-7] by Blue Hell -
    Added lines 17-21:
    !!!Radio pages
    Added line 25:
    Deleted line 28:
    2013-03-24 13:29 [UTC-7] by Blue Hell -
    Added lines 13-18:
    !!!Layout details
    Added a thin right border and removed some lines ... think it looks better now. [[~Blue Hell]]
    2013-03-07 18:32 [UTC-7] by Blue Hell -
    Changed lines 16-19 from:
    I've generalized the time stamp thing a bit in that it can translate date-time stamps written in a specific format as user local time - for details see [[Help.SiteSpecificMarkup#ntoc24 | here]]. ~ [[~Blue Hell]] 2013-03-07 16:32 [UTC-7]
    to:
    I've made the lookup tables working - it is not 100% yet, but getting there. See [[http://electro-music.com/wiki/pmwiki.php?n=Help.SiteSpecificMarkup#ntoc27 | Site Specific Markup]]. For a working example see [[Calendar.20130323]] and [[Radio.PortData]] for it's lookup table. Translated elements can contain markup now as well, this should then look OK in both the table and the lookup table. ~ [[~Blue Hell]] 2013-03-07 16:32 [UTC-7]
    to:
    to:
    to:
    2013-03-07 18:30 [UTC-7] by Blue Hell -
    Added lines 12-16:
    !!!Time stamps
    2013-03-06 18:51 [UTC-7] by Blue Hell -
    Added lines 13-17:
    !!!Lookup tables
    2013-03-03 16:17 [UTC-7] by Blue Hell -
    Added lines 26-27:
    ->I deleted the pageviews page and reinstalled it, that seems to have solved the issues.
    2013-03-03 15:03 [UTC-7] by Blue Hell -
    Changed the schedule looks a bit for the radio and playlist schedule things, the markup is the same still .. one problem tho ... can not have both schedule types on one page now .. working on that stilll. [[Main.WikiSwimmingPool]] currently shows the problem .. (it should have both [[JavaScript.PlaylistSchedule]] and  [[JavaScript.RadioSchedule]] in it). ~ [[~Blue Hell]] 2013-03-02 20:27 [UTC-7]
    to:
    Ok, this is fixed now
    - took me the whole day {eek} ~ [[~Blue Hell]]
    Added lines 49-50:
    ->Plenty of time indeed ;-) but if ideas pop up, let's talk there.
    2013-03-03 14:23 [UTC-7] by Blue Hell -
    Added lines 24-25:
    ->And it appears in the Categories . Categories too - it should not.
    2013-03-03 14:21 [UTC-7] by Blue Hell -
    ->That is not the whole story apparently - I did manage to get Category . Stub out of the page views ... just as Category / Stub, Category . Stub-Talk and Category / Stub-Talk ... still that is not enough to solve the problem.
    to:
    ->That is not the whole story apparently - I did manage to get Category . Stub out of the page views ... just as Category / Stub, Category . Stub-Talk and Category / Stub-Talk ... still that is not enough to solve the problem. Not even getting the word Category out all together helps o_O
    2013-03-03 14:07 [UTC-7] by Blue Hell -
    ->[[~Blue Hell]]
    to:
    ->~ [[~Blue Hell]]
    Changed lines 19-23 from:
    ->Me neither .. tried some stuff to get it out to no avail yet. ~ [[~Blue Hell]]
    ->Whatever the reason
    is, it probably is the same reason as to why this page is listed as a stub (while I had destubbed it) ... maybe because it mentions the words Category . Stub (without the spaces). Let me check ... ok, such is indeed the case. Now I had tried to avoid generating those words in PageViews but must have done incorrectly so, or maybe just iterating over the pages does it. ~ [[~Blue Hell]]
    to:
    ->Whatever the reason is, it probably
    ->That is not
    ->[[~Blue
    Hell]]
    2013-03-03 13:55 [UTC-7] by Blue Hell -
    Changed line 21 from:
    ->Whatever the reason is, it probably is the same reason as to why this page is listed as a stub (while I had destubbed it) ... maybe because it mentions the words Category . Stub (without the spaces). Let me check ...
    to:
    ->Whatever the reason is, it probably is the same reason as to why this page is listed as a stub (while I had destubbed it) ... maybe because it mentions the words Category . Stub (without the spaces). Let me check ... ok, such is indeed the case. Now I had tried to avoid generating those words in PageViews but must have done incorrectly so, or maybe just iterating over the pages does it. ~ [[~Blue Hell]]
    2013-03-03 13:53 [UTC-7] by Blue Hell -
    Added line 14:
    Changed lines 21-22 from:
    ->Whatever the reason is, it probably is the same reason as to why this page is listed as a stub (while I had destubbed it) ... maybe because it mentions the words Category . Stub ....
    to:
    Changed line 107 from:
    The stub page does appear on the [[Category.Stub]] page :) . [Q]
    to:
    2013-03-03 13:52 [UTC-7] by Blue Hell -
    Added lines 19-20:
    2013-03-03 13:11 [UTC-7] by Blue Hell -
    Added lines 12-13:
    Changed lines 18-20 from:
    to:
    2013-03-03 12:55 [UTC-7] by Blue Hell -
    ->test: {_stub_}
    to:
    ->test: [={_stub_}=] :: unstubbed by [[~Blue Hell]]
    Changed lines 13-17 from:
    !!!Changed the schedule looks a bit
    for
    to:
    !!!Stubs
    !!!Schedule looks changed
    Added lines 31-32:
    2013-03-02 22:30 [UTC-7] by Blue Hell -
    to:
    Changed line 34 from:
    to:
    to:
    to:
    Changed line 76 from:
    to:
    Changed line 99 from:
    to:
    Changed line 108 from:
    to:
    2013-03-02 22:27 [UTC-7] by Blue Hell -
    to:
    2013-03-02 22:26 [UTC-7] by Blue Hell -
    Added lines 16-20:
    Added lines 33-34:
    Added lines 61-62:
    Added line 96:
    2013-03-02 22:00 [UTC-7] by Blue Hell -
    Added lines 13-15:
    Added lines 18-26:
    ->found some interesting discussions on the PmWiki mailing lists ... all pretty much procedural in nature and eventually going into the question "what is archiving". I agree that shortening up will be needed at some stage, but it will need some thought ... like will archived stuff still be linkable, searchable ... shortening of a long thread, should that be only in the presentation? or in the editor too?
    ->Also .. what should the markup look like to accomplish tings.
    ->Anyway .. to me it seemed it needed some thought and discussion,
    ->~ [[~Blue Hell]]
    Changed line 14 from:
    At some point we are going to need a methord of archiving long Talk pages. [Q].
    to:
    Added lines 13-14:
    !!!Archiving talk pages
    2013-03-01 20:56 [UTC-7] by Blue Hell -
    [[~Blue Hell]] 2013-03-01 18:52 [UTC-7]
    to:
    ~ [[~Blue Hell]] 2013-03-01 18:52 [UTC-7]
    2013-03-01 20:55 [UTC-7] by Blue Hell -
    Added lines 15-16:
    When JavaScript is enabled all time stamps should be in user local time now - they were in server time before.
    2013-03-01 20:53 [UTC-7] by Blue Hell -
    Also there now is a [[Site.SpecialPages]] that can be used with [=(:include Site.SpecialPages:)=] as :
    (:include Site
    .SpecialPages:)
    to:
    Also there now is a [[Site.SpecialPages]] that can be used with [=(:include Site.SpecialPages:)=] - added that in a couple of places.
    2013-03-01 20:52 [UTC-7] by Blue Hell -
    Added lines 13-23:
    !!!Some new stuff
    I've made a [={_stubs_}=] markup thingie to directly go to the {_stubs_} without it opening on a new tab.
    2013-02-28 07:28 [UTC-7] by Blue Hell -
    Added line 25:
    ->Ah ok, tried some recipes yesterday for that, seemed buggy ... will try [[http://www.pmwiki.org/wiki/Cookbook/Fox|fox]] later on (that one can do some more stuff). ~ [[~Blue Hell]]
    Added line 23:
    2013-02-27 15:36 [UTC-7] by Blue Hell -
    Added lines 13-15:
    Added lines 20-23:
    ->That's a bit of a broader subject, section editing within pages. I've seen recipes being mentioned for it, but did not find time yet to look into that, and am not sure if it would work with stubbing. Will add it to the [[Help.Todo | todo list]]. ~ [[~Blue Hell]]
    Changed lines 13-16 from:
    to:
    !!!Edit a Section
    I was trying to provide an edit link that would enable the editing of one section only, on long pages like this one.. \\
    Added line 48:
    2013-02-27 05:16 [UTC-7] by [Q] - formatting
    Changed lines 16-17 from:
    !!!Re. getting lost ... [[~Blue Hell]]
    to:
    Changed lines 25-50 from:
    -> Thanks.. I'm dyslexic.. I need clickable links.. I tend avoid search engines.. :) . [Q]
    !!!Do we have an Icon for a
    Not sure what you mean by 'Stub' [[~Blue Hell
    ->[[http://en.wikipedia.org/wiki/Wikipedia:Stub]] it helps people to collaborate. Just look down the list of stubs to see what you can add to articles. [Q].
    -->test: {_stub_}
    -->ok
    .. something like that I guess? now it should auto add itself to category / stub ... working on that. Seems to work, is that what you meant?
    -->Hmm .. it does not work as expected ... needs some more work.
    -->Right, it does work, its just that the stub page itself will not be in the stub list o_O
    -->~ [[~Blue Hell]]
    to:
    ~ [[~Blue Hell]]
    !!!Stubs
    [Q].
    ->Not sure what you mean by '
    Stub' [[~Blue Hell]]
    [[http://en
    ->test: {_stub_}
    ->ok
    ->Right
    ->~ [[~Blue Hell]]
    !!!Articles Section
    The
    Changed lines 60-64 from:
    !!!Being able to apply multiple tags to pages should assist in navagation. [Q].
    Have a look at the schematics vault, I put a bunch of tags in there - or is that not what you meant? Heh, glad you just put the chatter back up, guess I was too impatient then ;-) [[~Blue Hell]]
    ->defined tags (categories) - that's it :) . chatting & talking is good :) . [Q].
    to:
    !!!Tags
    ->Have a look at the schematics vault, I put a bunch of tags in there - or is that not what you meant? Heh, glad you just put the chatter back up, guess I was too impatient then ;-) [[~Blue Hell]]
    2013-02-26 20:25 [UTC-7] by Blue Hell -
    Changed lines 42-44 from:
    -->Right, it does work, its just that the stub page itself will not be in the stub list o_O ~ [[~Blue Hell]]
    to:
    ~ [[~Blue Hell]]
    -->ok .. something like that I guess? now it should auto add itself to category / stub ... working on that. Seems to work, is that what you meant? ~ [[~Blue Hell]]
    ... needs some more work. ~ [[~Blue Hell]]
    to:
    2013-02-26 20:24 [UTC-7] by Blue Hell -
    Changed lines 36-38 from:
    -->test: {_stub_} - hmm ok .. something like that I guess? now it should auto add itself to category / stub ... working on that. Seems to work, is that what you meant? ~ [[~Blue Hell]]
    to:
    -->test: {_stub_}
    2013-02-26 20:23 [UTC-7] by Blue Hell -
    Added lines 10-11:
    Feel free though to add stuff here, anything related to the Wiki as a whole, comments, complaints, requests can go here.
    2013-02-26 20:17 [UTC-7] by Blue Hell -
    Changed line 9 from:
    Please add new items at the top and precede item with [=!!!=] to get it into the table of contents.
    to:
    2013-02-26 20:14 [UTC-7] by Blue Hell -
    Changed lines 38-39 from:
    -->Right, it does work, its just that the sub page itself will not be in the stub list o_O ~ [[~Blue Hell]]
    to:
    Added line 46:
    2013-02-26 20:11 [UTC-7] by Blue Hell -
    Added line 38:
    2013-02-26 19:50 [UTC-7] by Blue Hell -
    Added line 35:
    2013-02-26 19:49 [UTC-7] by Blue Hell -
    Changed line 35 from:
    to:
    -->Hmm .. it does not work as expected ... needs some more work. ~ [[~Blue Hell]]
    2013-02-26 19:09 [UTC-7] by Blue Hell -
    Added lines 7-8:
    Changed lines 10-11 from:
    to:
    2013-02-26 19:08 [UTC-7] by Blue Hell -
    Deleted line 3:
    (:num:)
    Added lines 8-9:
    Deleted lines 13-36:
    !!!The Articles section could benefit from having sub sections such as: Audio, DIY, Bio's, etc. [Q].
    !!!Do we have an Icon for a Stub and a page for all Stubs. [Q].
    Not sure what you mean by 'Stub' [[~Blue Hell]]
    Added lines 25-48:
    2013-02-26 19:00 [UTC-7] by Blue Hell -
    Changed lines 36-37 from:
    to:
    Deleted lines 44-45:
    [[~Blue Hell]]
    to:
    2013-02-26 18:59 [UTC-7] by Blue Hell -
    Added lines 10-11:
    Changed lines 14-19 from:
    -->defined tags (categories) - that's it :) . chatting & talking is good :) . [Q].
    to:
    Changed lines 22-25 from:
    ->An index of tags would do this.. [Q].
    to:
    Changed lines 28-35 from:
    ->Not sure what you mean by 'Stub' [[~Blue Hell]]
    -->[[http://en.wikipedia.org/wiki/Wikipedia:Stub]] it helps people to collaborate. Just look down the list of stubs to see what you can add to articles. [Q].
    --->test: {_stub_} - hmm ok .. something like that I guess? now it should auto add itself to category / stub ... working on that. Seems to work, is that what you meant? ~ [[~Blue Hell]]
    to:
    Changed lines 50-51 from:
    to:
    2013-02-26 18:58 [UTC-7] by Blue Hell -
    Added line 8:
    2013-02-26 18:57 [UTC-7] by Blue Hell -
    Changed lines 1-2 from:
    to:
    !!Contents
    (:toc:)
    (:num:)
    (:indent:)
    Changed lines 17-18 from:
    to:
    Changed lines 23-24 from:
    to:
    to:
    2013-02-26 18:56 [UTC-7] by Blue Hell -
    to:
    Changed lines 9-10 from:
    to:
    Changed lines 15-16 from:
    to:
    Changed lines 25-27 from:
    Re. getting lost ... maybe these help ... these are on [[Help.Search]] too BTW
    to:
    2013-02-26 18:42 [UTC-7] by Blue Hell -
    --->test: {_stub_} - hmm ok .. something like that I guess? now it should auto add itself to category / stubs ... working on that. Seems to work, is that what you meant? ~ [[~Blue Hell]]
    to:
    2013-02-26 18:36 [UTC-7] by Blue Hell -
    --->test: {_stub_} - hmm ok .. something like that I guess? now it should auto add itself to category / stubs ... working on that. ~ [[~Blue Hell]]
    to:
    2013-02-26 18:33 [UTC-7] by Blue Hell -
    to:
    2013-02-26 18:32 [UTC-7] by Blue Hell -
    to:
    2013-02-26 18:30 [UTC-7] by Blue Hell -
    --->test: {_stub_}
    to:
    2013-02-26 18:26 [UTC-7] by Blue Hell -
    --->test: Attach:Site.Icons/stub-icon.gif This article is a stub (:comment [[!$pagename]]:)
    to:
    --->test: {_stub_}
    2013-02-26 18:24 [UTC-7] by Blue Hell -
    --->test: Attach:Site.Icons/stub-icon.png This article is a stub (:comment [[!$pagename]]:)
    to:
    2013-02-26 18:18 [UTC-7] by Blue Hell -
    Added lines 20-21:
    Changed line 19 from:
    to:
    Added lines 19-20:
    Added lines 32-33:
    2013-02-26 17:52 [UTC-7] by Blue Hell -
    Added lines 26-27:
    Could also use an rss feed like ... http://electro-music.com/wiki/pmwiki.php?n=Site.AllRecentChanges?action=rss&count=50 maybe.
    2013-02-26 17:48 [UTC-7] by Blue Hell -
    Added lines 7-8:
    Added lines 13-14:
    Added lines 19-20:
    Changed lines 27-29 from:
    [[~Blue Hell]]
    to:
    [[~Blue Hell]]
    2013-02-26 17:47 [UTC-7] by Blue Hell -
    Changed lines 11-21 from:
    to:
    *Find [[Help.Search?action=search&q=%22-Talk%22 | all '-Talk' pages]]
    *Find [[Help.Search?action=search&q=%2f | all pages]]
    *Find [[Site.AllRecentChanges | {+all+} recent changes]]
    [[~Blue Hell]]
    Added lines 5-6:
    Added lines 8-9:
    Changed lines 5-7 from:
    to:
    . [Q].
    2013-02-26 17:06 [UTC-7] by Blue Hell -
    Added lines 2-3:
    Added lines 1-3:
    Edit - History - Print - Recent Changes - Search Page last modified on 2015-03-03 17:17 [UTC-7] - 7533 views
