Recent Changes - Search:
go to the forum
Contents
Site
Help
« jan 2024 · may 2024 »
add a calendar item
PmWiki / Debug Variables
%audienceAnonymous
$EnableDiag
The following actions are available only if you set $EnableDiag = 1; in your configuration file. They can be used for debugging and should not be set in a production environment.
?action=ruleset
displays a list of all markups in 3 columns:
  • column 1 = markup-name (1. parameter of markup() )
  • column 2 = when will rule apply (2. parameter of markup() )
  • column 3 = PmWiki's internal sort key (derived from #2)
(see Custom Markup Using the Markup() function for custom wiki syntax ).
To see more than what ?action=ruleset gives you, apply the Cookbook:MarkupRulesetDebugging recipe: it can also show the pattern and the replacement strings.
  • doesn't make use of PmWiki's authorization mechanisms.
?action=phpinfo
displays the output of phpinfo() and exits. no page will be processed
?action=diag
displays a dump of all global vars and exits. no page will be processed
$EnableIMSCaching
A variable which, when set equal to 1, recognizes the "If-Modified-Since" header coming from browsers and allows browsers to use locally cached pages. Disabled by default to help the administrator customize its page without needing permanent reloading.
$EnableStopWatch
This activates an internal stopwatch that shows how long it takes to render a page. (If you have a wiki that composes a HTML page from multiple pages, such as a normal layout with a sidebar, you'll get separate timings for each subpage and for the total page.)
The timings can be displayed by adding <!--function:StopWatchHTML 1--> in the wiki template.
Valid values are:
        $EnableStopWatch = 0; # No timings (the default). No HTML will be generated.
        $EnableStopWatch = 1; # Wall-clock timings only.
        $EnableStopWatch = 2; # Wall-clock and CPU usage timings. Won't work on Windows.
See Stopwatch for more details.
See also:
  • scripts/refcount.php is useful for debugging
Is it possible for someone with admin priviledges to always have access to debugging tools, without letting everyone else access them?
You can easily & automatically allow debugging for anyone with admin priviledges (meanwhile leaving it off for everyone else) by including this line in config.php - just be sure that 1) $EnableDiag is either null or set to 0, and 2) to include it near the end of config.php, AFTER declaring your passwords, and after any AuthUser or other priviledge settings:
if (CondAuth($pagename, 'admin')) $EnableDiag = 1; # allows admin to always call phpinfo, etc
This page may have a more recent version on pmwiki.org: PmWiki:DebugVariables, and a talk page: PmWiki:DebugVariables-Talk.
Edit - History - Print - Recent Changes - Search Page last modified on 2011-09-10 16:08 [UTC-7] - 277 views
