PmWiki / Group Customizations
(redirected from PmWiki.PerGroupCustomizations) administrators (intermediate)
One of the purposes of Wiki Groups is to allow a Wiki Administrator to customize the features of PmWiki on a per-group basis. Here is where per group customizations come into play.
To perform local customizations for a particular WikiGroup,
These files will be automatically processed after processing any local customizations in the config.php and local.css files. For example, to change the image displayed in the upper-left corner of pages in the "GroupName" WikiGroup, one could create local/GroupName.php containing <?php $PageLogoUrl = "/myimages/chess.gif"; The example's effect would cause all pages in the GroupName Wiki Group to use "/myimages/chess.gif" as the logo image instead of the default. To add markup to the beginning or end of each page in a wiki group, see Group headers. Per-page customizations
PmWiki also allows per-page customizations, simply use the full name of the page to be customized instead of the group. For example, one can use the file local/Chess.HomePage.php to set local customizations for Chess.HomePage. Almost any customization that would be placed in config.php can be used as a per-group or per-page customization. An important exception to this is setting per-group or per-page customizations for recipe scripts included in config.php. Most recipe scripts would need any customization variables defined before the script is included. Instead of using a per-group or per-page customization php file, use a per-group or per-page conditional statement in config.php, before including the recipe script. Example: $page = PageVar($pagename, '$FullName'); $group = PageVar($pagename, '$Group'); //per-group customizations: if($group=='GroupName') { $RecipeVariable = 'valueA'; etc. ... } //per-page customizations: if($page=='GroupName.PageName) { $RecipeVariable = 'valueB'; etc. ... } //include recipe after variables are set: include_once('cookbook/recipescript.php'); Note that this method cannot be used to set Processing order
For all local customizations, PmWiki first processes the local/config.php file, and then looks for a per-page customization file in the local/ subdirectory to process, followed by any per-group customization file. If no per-page or per-group customizations are loaded, then PmWiki loads local/default.php. If a per-page customization wants to have the per-group customizations loaded first, it can do so directly by using PHP's Custom CSS styles per group or per-page
To apply CSS styles to pages of a specific group named Group Name?, create a file named GroupName.css in the pub/css/ directory and add the CSS style rules there. To apply styles to a specific page, create a file GroupName.PageName.css in this directory with your style rules. Any CSS rules to be applied for all wiki pages can be put into pub/css/local.css. /pub/css/GroupName.css: body { background: #F4C4B4; } Preventing group-Level configurations
Any customization file can set Authentication
Any passwords required for a group should be set in the group's Group Attributes? page (see Passwords Administration) and not in a group customization file. Consider Wiki Farms
Wiki Groups are an easy way to host multiple sites in a single PmWiki installation by giving each site its own group. Another approach is to use Wiki Farms, which allows each site to have its own set of Wiki Group and local customization files. Read about If you are looking for nested group levels, you may want to consider Pm's design considerations on hierarchical groups. How can I apply CSS styles to a particular group or page? Simply create a pub/css/Group.css or pub/css/Group.Page.css file containing the custom CSS styles for that group or page. Why shouldn't passwords be set in group (or page) customization files? Why shouldn't group or page passwords be set in config.php? The reason for this advice is that per-group customization files are only loaded for the current page. So, if
and because the GroupA.php file wasn't loaded (we're looking at Main.WikiSandbox --> local/Main.php), there's no read password set. The same is true for page customization files. Isn't that processing order strange? Why not load per page configuration last (that is after global configuration an per group configuration)? Many times what we want to do is to enable a certain capability for a group of pages, but disable it on a specific page, as if it was never enabled. If the per-group config file is processed first, then it becomes very difficult/tedious for the per-page one to "undo" the effects of the per-group page. So, we load the per-page file before the per-group. If a per-page customization wants the per-group customizations to be performed first, it can use the techniques given in PmWiki.GroupCustomizations (using include_once() or setting This page may have a more recent version on pmwiki.org: PmWiki:GroupCustomizations, and a talk page: PmWiki:GroupCustomizations-Talk. |
Edit - History - Print - Recent Changes - Search Page last modified on 2011-09-10 16:08 [UTC-7] - 419 views
