Recent Changes - Search:
go to the forum
Contents
Site
Help
« feb 2024 · jun 2024 »
    add a calendar item
    PmWiki / Security Variables
    %audienceAnonymous
    $DefaultPasswords
    Specifies default passwords for user admin or actions (edit, read, upload). See PasswordsAdmin#settingsitewidepasswords.
    $EnablePostAttrClearSession
    A switch to control whether or not changing a page's attributes causes any existing passwords to be forgotten. The default is that changing attributes forgets any passwords entered; this can be changed by setting $EnablePostAttrClearSession to zero.
    $EnableSessionPasswords
    Control whether passwords are saved as part of the session. If set to zero, then session passwords are never saved (although any AuthUser authentications are still remembered).
    $SessionEncode
    Function to use to encode sensitive information in sessions. Set this to NULL if you want to not use any encoding. (See also $SessionDecode below.)
    $SessionDecode
    Function to reverse the decoding given by $SessionEncode above. Set this to NULL if sensitive session values are not encoded.
    $HandleAuth
    This sets the required authentication Level that is necessary to perform an action. When using the following example in your config.php you need to be authenticated as editor in order to view the page history:
            $HandleAuth['diff'] = 'edit';
    $PageAttributes
    Set the string shown on the attributes page when entering a password for an action.
    $AuthLDAPBindDN
    For sites using AuthUser with LDAP authentication, this specifies the distinguished name (DN) to be used to bind to the LDAP server to check identity.
    $AuthLDAPBindPassword
    For AuthUser with LDAP authentication, this specifies the password used for binding (in conjunction with $AuthLDAPBindDN above).
    $EnablePublishAttr
    Adds a new "publish" authorization level to distinguish editing of drafts from publishing - See $EnableDrafts.
    $EnablePageVarAuth
    In PmWiki versions 2.2.22 and 2.2.23 this variable should be set to 0. In 2.2.24 it will no longer be used.
    See also:
    This page may have a more recent version on pmwiki.org: PmWiki:SecurityVariables, and a talk page: PmWiki:SecurityVariables-Talk.
    Edit - History - Print - Recent Changes - Search Page last modified on 2011-12-20 09:57 [UTC-7] - 376 views
