Recent Changes - Search:
Contents
Site
Help
« nov 2017 · mar 2018 »
    add a calendar item
    Schematics / Diode Ladder VCF
    < Korg late MS20 filter | Schematics | Serge Resonant Equalizer >
    < Korg late MS20 filter | Listbytype | Serge Resonant Equalizer >
    DIY | Filter | VCF | Diode ladder | Yves Usson | EMS | 3046 | 3096
    Diode ladder VCF by Yves Usson ,as part of the Yusynth Modular , page dedicated to this filter is here http://yusynth.net/Modular/index_en.html with details on construction ,calibration , wiring and demo. From the notes on the page :
    Well, here is another classical and very special filter based on the EMS diode ladder filter! This filter has a sound of its own and is the signature of the classical Pink Floyd's song "On the run".
    My aim here was to design a quite faithful copy of this mythic filter while using components that minimize the burden of selecting a great number of matched transistors. This is why I used transistor arrays (CA3046, CA3096). However, because the CA3096 has become a rare part and is now overpriced, I have also designed a PCB with discrete trannies to replace it. As for all the other filters of my YUSYNTH project, I have added an input and an output buffer to adapt this filter to the input and output levels of my modular system. I also added an input for voltage control of the resonance : everything was there in the original module but was not made available, probably because of the limited size of the patch pin matrix of the AKS/VCS3... Because, my power supply standard is +15/-15V, I have included a power regulator IC (78L12) to convert +15V to +12V and a single transitor voltage regulator -15V to -9V (I wanted to use a 79L09 but changed my mind when I realized that this voltage regulator is quite a rare part and is difficult to source).
    here presented is a schematic for the discrete version .More Info and troubleshooting ,building experience by other people on the Yusynth subforum : http://electro-music.com/forum/index.php?f=170
    Edit - History - Print - Recent Changes - Search Page last modified on 2013-02-24 17:53 [UTC-7] - 4211 views
