Recent Changes - Search:
Contents
Site
Help
« mar 2018 · jul 2018 »
add a calendar item
Schematics / Dual Sine Suboctave Og 3 By Scott Bernardi
< Frequency Divider by Roman Sowa | Schematics | ElectroNotes 129 TZVCO from Bernie Hutchins >
Listbytype
DIY | Divider | Wave Shaping | Scott Bernardi | Sub octave
Dual Sine Suboctave (og3) by Scott Bernardi ,this is his description given on the page dedicated to this module http://www.bernacomp.com/elec/og2/og3_sine_suboctave.html :
I got the idea for this circuit from a Synth-DIY thread. This suboctave unit accepts a +/-5v sawtooth and generates the following waveforms within the circuit:
  • Inverted saw
  • 1 octave saw
  • 1 octave square
  • 1 octave sine
  • 1 octave triangle
  • 2 octaves saw
  • 2 octaves square
  • 2 octaves sine
  • 2 octaves triangle
The sine suboctaves have the advantage of adding a big bass boost without adding a lot of buzzy harmonics.
The output mixer has pots to mix in the original saw with the other waveforms. This implementation mixes in the square and sine waveforms only, but it would be a pretty simple matter to mix in the suboctave sawtooths (sawteeth?) and triangle waveforms also.
The circuit is designed to handle a +/-5v sawtooth at the input. I added the INV switch to be able to handle either up-ramp or down-ramp saws. You can also get some very interesting waveforms by purposely having this switch in the "wrong" position.
PBC layout shared by mph on this thread : http://electro-music.com/forum/post-179951.html
Listbytype
Edit - History - Print - Recent Changes - Search Page last modified on 2013-02-24 15:05 [UTC-7] - 2740 views
