Schematics / SEKU Sequencer
Schematics.SEKUSequencer HistoryHide minor edits - Show changes to output Added lines 1-3:
[[!DIY]] | [[!Sequencer]] | [[!Mauno Tuominen]] | [[!16 step]] | [[!CMOS]] ---- Added lines 1-11:
SEKU Sequencer by Mauno Tuominen ,page dedicated to this module http://www.studiomanus.com/seku.htm from there the description : SEKU is a two-channel 16-step analog sequencer.Heart of SEKU is CMOS 4520 dual synchronous divide-by-16 counter. RESET-in-jack must be normalised to ground when not used (16-step mode). Length of the sequence can be set to N by patching PULSE OUT from N+1 step to RESET IN jack. When no clock is connected to CLK IN sequencer can be manually stepped from STEP button. CMOS 4067 1-of-16 analog switch is used for GATE, CV and PULSE outputs. Inhibit-pin of GATE OUT 4067-switch is clocked at the same frequency as the 4520 with 4001 nor-gate turning each GATE OUT off before turning the next GATE on. You can mute any one of the 1-16 steps with the STEP MUTE switch. I have used slider potentiometers for STEP CV adjusting so that it is easier to draw waveforms when SEKU is used as an oscillator. I havent buffered the CV and GATE outputs with op amps in order to keep the power supply simple, just +5V to ground. I have also an adjustable power supply so I can adjust the octave range of SEKU by adjusting the supply voltage (+3 to +5 V or from 3 to 5 octaves in 1V/oct systems) %width=95pct% http://electro-music.com/forum/phpbb-files/seku_191.gif |
Edit - History - Print - Recent Changes - Search Page last modified on 2013-02-24 22:00 [UTC-7] - 6298 views
