Recent Changes - Search:
Contents
Site
Help
« mar 2018 · jul 2018 »
add a calendar item
Schematics / Simple Dual ASR By Strazdas
< Multifunction LFO - EG Generator by Osamu Hoshuyama | Schematics | Music Easel Adaptation - Envelope Generator by Aaron Lanterman >
< ADSR design by Nicolas Woollaston | Listbytype | Music Easel Adaptation - Envelope Generator by Aaron Lanterman >
DIY | EG | AR | ASR | Strazdas
Simple dual A(S)R by Strazdas ,following this thread http://electro-music.com/forum/viewtopic.php?t=50401 as it's noted : Idea is taken from old russian Radio 1992 magazine, but adopted to modern modular needs .
All diodes n4148. With trimmers R13, R20 you set max EG voltage (you may vary from near 15V to 0V). Timing caps are C2 & C4 (tantalum are best), but you can change them for your needs or make switch for different timing eg. FAST-SLOW-MEDIUM as shown in MFOS dual EG. With R1 and R2 you set GATE voltage (now it's +0,9V), for ±12V users calculate your own needs. Will work with ±12V PSU.
NOT TESTED! but breadboarded and tested with +8V with no op-amps as on original schematics (it uses russian K176 series CMOS with operational voltage max +9V)
This is V2 of this Envelope Generator .
Edit - History - Print - Recent Changes - Search Page last modified on 2013-02-24 13:28 [UTC-7] - 2764 views
