Recent Changes - Search:
Contents
Site
Help
« mar 2013 · jul 2013 »
add a calendar item
Schematics / Tau 1005 VCO
< Voltage Controlled Glide | Schematics | Paia Gator >
< The SN-Voice Project | Listbytype | A440 Oscillator Version X >
DIY | VCO | Tau Systems | Aaron Lanterman | 3080
Tau 1005 VCO by Tau Systems ,brief comment from Aaron D. Lanterman on this circuit http://users.ece.gatech.edu/~lanterma/ems11/projectideas_sp11.html :
Looking at the schematic, you'll see it's a triangle core like the Buchla 259 core we discussed in class, except a CA3080 is used instead of the "roll your own" 4-transistor OTA Buchla uses. The HA2500 op ap is acting as the comparator, and the FET and BJT at the output of the 3080 are acting as a buffer. I think the weird configuration of Q5 and Q6 is acting as a voltage clamp. It appears to have been intended to be some sort of plug-in module for a bigger circuit.
Edit - History - Print - Recent Changes - Search Page last modified on 2013-02-24 14:49 [UTC-7] - 98 views
