alien_transmissions
Page 1 of 4 [84 Posts]
Goto page: 1, 2, 3, 4 Next
[Q]
Audio files: 57
PostPosted: Fri Apr 27, 2012 4:45 am    Post subject:  alien_transmissions Reply with quote  Mark this post and the followings unread
alien_transmissions on the Open Port
Broadcast today @ 07:00 GMT
alien_transmissions #001 [generative]
A generative session in Pd, using a single oscillator and a sample chopper. Midi was provided by Noatikl and a touch of tape echo by Midiverb. Oh and tweaking by alien appendages.
A No Refunds Production for electro-music.com
alien_transmissions_001.mp3
 Filename:  alien_transmissions_001.mp3
 Filesize:  82.39 MB
 Downloaded:  2137 Time(s)
PostPosted: Fri Apr 27, 2012 5:20 am    Post subject: Reply with quote  Mark this post and the followings unread
just tuned in - what are the voices?
[Q]
Audio files: 57
PostPosted: Fri Apr 27, 2012 6:05 am    Post subject: Reply with quote  Mark this post and the followings unread
the voice samples are mostly me and one Japanese all of them pitch shifted and chopped up..
or aliens Smile
PostPosted: Fri Apr 27, 2012 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
The the single oscillator had not started, but now it did - simple and nice :-)
[Q]
Audio files: 57
PostPosted: Fri Apr 27, 2012 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan.. thanks for listening Very Happy
PostPosted: Fri Apr 27, 2012 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Was a nice listen - and good to have you on the radio again :-)
too bad you choose to transmit that early ;-)
[Q]
Audio files: 57
PostPosted: Fri Apr 27, 2012 7:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Jan wrote:
and good to have you on the radio again Smile
It's good to be back on the radio Very Happy
too bad you choose to transmit that early Wink
Hehe sorry, was trying to avoid the rush hour.. Smile
[Q]
Audio files: 57
PostPosted: Fri May 04, 2012 6:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Broadcast today @ 10:00 GMT
alien_transmissions #002 [from the archive]
This session is from the archives as the new patch is not yet ready.
KV007 is an interim recording on MiniDisc from around 2006 ish.
The finished track was released as Experimental Compositions Vol.3 by jfox.
The technique was like the old tape to tape method, only using Audacity and MiniDisc recorder.
A No Funds Production for electro-music.com
alien_transmissions_002.mp3
alien_transmissions #002 [from the archive] - This session is from the archives as the new patch is not yet ready. KV007 is an interim recording on MiniDisc from around 2006 ish.The finished track was released as Experimental Compositions Vol.3 by jfox. T
 Filename:  alien_transmissions_002.mp3
 Filesize:  57.5 MB
 Downloaded:  2077 Time(s)
PostPosted: Fri May 04, 2012 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for playing that earlier on John - enjoyed it :-)
[Q]
Audio files: 57
PostPosted: Sat May 05, 2012 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for listening Jan Very Happy
PostPosted: Fri May 11, 2012 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
listening at the moment,.. gotta go work in 30 minutes but I can actually start later so I might stick around a bit longer Smile
[Q]
Audio files: 57
PostPosted: Fri May 11, 2012 3:19 am    Post subject: Reply with quote  Mark this post and the followings unread
[Q]
Audio files: 57
PostPosted: Fri May 11, 2012 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for listening PHOBoS Very Happy
I'll post it in a bit..
[Q]
Audio files: 57
PostPosted: Fri May 11, 2012 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Broadcast today @ 10:05 GMT
alien_transmissions #003 [field recording & collage]
This session used a field recording and some odds and ends from various projects. The field recording was made with a Sony ECM-MS907 mic [out the bathroom window], and a MiniDisc recorder.
WARNING! This is VERY LOUD in places!
A No Fun Production for electro-music.com
alien_transmissions_003.mp3
 Filename:  alien_transmissions_003.mp3
 Filesize:  82.49 MB
 Downloaded:  1956 Time(s)
[Q]
Audio files: 57
PostPosted: Fri May 18, 2012 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Broadcast today @ 10:40 GMT
alien_transmissions #004 [soft noise]
This session used two Pd patches and a MidiVerb. The first Pd patch was a table oscillator. The second patch produced FM feedback, I used a simplified version of fmFeedback.pd by noizeHack, which you can see and get here..
http://noizehack.com/fm-feedback-matrix/
A No Funk Production for electro-music.com
alien_transmissions_004.mp3
alien_transmissions #004 [soft noise] - made using a simplified version of fmFeedback.pd by noizeHack
 Filename:  alien_transmissions_004.mp3
 Filesize:  39.28 MB
 Downloaded:  1922 Time(s)
PostPosted: Fri May 18, 2012 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Enjoyed the transmissions this morning :-)
[Q]
Audio files: 57
PostPosted: Sat May 19, 2012 11:14 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for listening Jan.. Very Happy
[Q]
Audio files: 57
PostPosted: Fri May 25, 2012 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Broadcast today @ 09:35 GMT
alien_transmissions #005 [generative]
This session used a G2 driven by a Pd patch followed by a MidiVerb.
A Non Functional Production for electro-music.com
alien_transmissions_005.mp3
 Filename:  alien_transmissions_005.mp3
 Filesize:  82.52 MB
 Downloaded:  1986 Time(s)
PostPosted: Fri May 25, 2012 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
That was a nice listen, thanks for posting :-)
[Q]
Audio files: 57
PostPosted: Sat May 26, 2012 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
ThankQ for listening Jan.. Very Happy
[Q]
Audio files: 57
PostPosted: Fri Jun 01, 2012 5:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Broadcast today @ 09:10 GMT
alien_transmissions #006 [experimental]
This session used a G2, manually controlled by a Pd patch followed by a touch of MidiVerb.
[The signal is panned hard right for the first 2 minutes!]
A Non Production for electro-music.com
alien_transmissions_006.mp3
alien_transmissions #006 [experimental] - This session used a G2 and a Pd patch. [The signal is panned hard right for the first 2 minutes!]
 Filename:  alien_transmissions_006.mp3
 Filesize:  41.18 MB
 Downloaded:  1919 Time(s)
[Q]
Audio files: 57
PostPosted: Fri Jun 08, 2012 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Broadcast today @ 10:03 GMT
alien_transmissions #007 [experimental]
This session used a G2, manually controlled by a Pd patch and a field recording.
alien_transmissions_007.mp3
alien_transmissions #007 [experimental] - This session used a G2, manually controlled by a Pd patch and a field recording.
 Filename:  alien_transmissions_007.mp3
 Filesize:  41.18 MB
 Downloaded:  1945 Time(s)
[Q]
Audio files: 57
PostPosted: Fri Jun 15, 2012 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Broadcast today @ 10:30 GMT
alien_transmissions #008 [experimental]
This session used a G2 and a midi file [for control changes].
alien_transmissions_008.mp3
alien_transmissions #008 [experimental] - This session used a G2 and a midi file [for control changes].
 Filename:  alien_transmissions_008.mp3
 Filesize:  40.35 MB
 Downloaded:  1925 Time(s)
PostPosted: Tue Jun 26, 2012 6:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Another nice one Q Cool
[Q]
Audio files: 57
PostPosted: Wed Jun 27, 2012 9:51 am    Post subject: Reply with quote  Mark this post and the followings unread
