 Forum index » Clavia Nord Modular » G2 Performances - Completed
doctor2
G2 patch files: 626
PostPosted: Mon Mar 24, 2014 2:14 am    Post subject: doctor2
Subject description: 2 rhymes with who
A long time ago I posted a prf called radiophonic which was an attempt at the bass line from the doctor who theme. Reproducing the melody proved more that I could handle.
Here is a re-do using assistance from a (poorly made) midi file. The score uses triplet notes quite a lot so it is a bit like putting a round peg into a square hole. The sequencer structure and time scale ran out of space so the ending is an imperfect recycling of one of the earlier sections.
This one plays automatically when loaded but there is a 2 bar pause with just the huffy noises at the beginning. Push stop after the fade out.
I have to post it or I will keep fiddling with it forever.
drwho.mid
midi file used for the patch, not intended for midi playback as it is designed specifically for this G2 prf
 Filename:  drwho.mid
 Filesize:  6.85 KB
 Downloaded:  737 Time(s)
doctor2.prf2
the prf of the midi
 Filename:  doctor2.prf2
 Filesize:  18.33 KB
 Downloaded:  4387 Time(s)
