 Forum index » Clavia Nord Modular » G2 Patches - Completed » FX
NOISE TOISE
Page 1 of 1 [13 Posts]
Tim Kleinert
G2 patch files: 236
PostPosted: Wed Feb 22, 2006 12:55 pm    Post subject:  NOISE TOISE
Subject description: does as it says on the tin, or your money back
A simple chaotic network:
OSC1 x OSC2 > OSC3 linFM
OSC2 x OSC3 > OSC1 linFM
OSC3 x OSC1 > OSC2 linFM
...plus the option to monitor oscs or mod busses.
That's all, I'm afraid... Embarassed
All variations filled (NOT by the mutator).
You'll probably find it boring, but I can play with this for hours.
best,
tim
NOISE TOISE TK.pch2
recreational purpose audio toy
 Filename:  NOISE TOISE TK.pch2
 Filesize:  1.82 KB
 Downloaded:  2414 Time(s)
cebec
G2 patch files: 31
PostPosted: Wed Feb 22, 2006 10:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I LOVE this sort of stuff!
PostPosted: Thu Feb 23, 2006 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
And so do I, it;s nice to see something simple that has a lot of diversity.
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Feb 23, 2006 4:19 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Oops, guys -I found a mistake. Embarassed
I made this thingie on the demo software, and just now loaded it into the hardware G2 -just to find out that the patch doesn't sound the same. Some of the variations that sound very interesting and lively on the demo just botch up into a semistable state on the G2 or sound boring otherwise. Sorry about that. I spent quite some time on those. If interested, load the patch into the demo for listen.
Seems as if the FM inputs of the demo behave slightly differently. Or maybe it's a issue of different mathematical resolution on a Pentium CPU. Within a feedback network, such minute differences can have big effects.
The patch is intended to be tweaked live. I can spend hours dialling away at this thing. Very often, it has me up in stitches. Laughing Instant arcade videogame FX maker. Just plug in, twiddle and record.
Tip: the most interesting results occur when one of the oscs is at or near zero frequency, and acts as a waveshaper or LFO. When using square on this one with subtle FM and twiddling the PW, funny things happen quite often. Subtlety is the key anyway. With too high FM indexes, the thing just warbles or produces noise.
Man, it's addictive.
PostPosted: Thu Feb 23, 2006 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
The fun part was in the tweaking anyway :-)
This is an intersesting phenomenon though, the demo sounding better.
Tim Kleinert
G2 patch files: 236
PostPosted: Thu Feb 23, 2006 4:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well, it doesn't sound "better", it's just that the mod indexes seem to behave different. So if you set up a variation that noodles away nicely on the demo, it might just lock up in a stable (uninteresting) state on the G2 and vice versa.
cebec
G2 patch files: 31
PostPosted: Fri Feb 24, 2006 8:41 am    Post subject:   Reply with quote  Mark this post and the followings unread
i use the demo often enough for this to 'bug' me. kinda defeats part of the purpose, to me, at least, of the demo... should i/we do some tests and make a report?
Audio files: 228
PostPosted: Fri Feb 24, 2006 11:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Bravo, Tim. This is facinating a loads of fun to play with.
Audio files: 228
PostPosted: Fri Feb 24, 2006 12:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is an interesting patch. I think a lot of what we are hearing as differences between the real G2 and the Demo has to do with initial conditions. Some of these variations go on for a long time and then suddenly they change the nature of the sound.
It proves you don't need an analog circuit to get lots of uncertainty and unpredictability. It seems like this patch can get into boring predictable states, but sometimes when you think it is in one it will change. Very Happy
cebec
G2 patch files: 31
PostPosted: Fri Feb 24, 2006 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
that's a good point.
PostPosted: Sat Feb 25, 2006 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
How do I get the variations to work?
PostPosted: Sat Feb 25, 2006 5:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
By pressing the variation buttons in the toolbar, or by using the keyboard 1 .. 8 keys as shortcuts.
W.T.
G2 patch files: 11
PostPosted: Thu Aug 17, 2006 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
this is great stuff tim!
it sounds a bit like circuit bending but then many times greater!!
this is Cool
