Set the number of cycles of a LFO
Page 1 of 1 [3 Posts]
heid'
PostPosted: Sun May 28, 2017 1:36 pm    Post subject: Set the number of cycles of a LFO Reply with quote  Mark this post and the followings unread
Hello,
I would like ton find the way to program a number of cycles for the LFO. For example, you press a key on the keyboard, a square LFO modulates a filter, but 'X' times ('X' is deteminated by a constant level) and after the last cycle, the sound is without filter modulation. Sorry, I don't speak very well english, but I hope you'll understand the problem Wink
Tim Kleinert
G2 patch files: 236
PostPosted: Sun May 28, 2017 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Voilà.
LFOCycleCount TK.pch2
Adjustable amount of LFO cycles on note-on.
 Filename:  LFOCycleCount TK.pch2
 Filesize:  1.4 KB
 Downloaded:  3857 Time(s)
heid'
PostPosted: Mon May 29, 2017 12:04 am    Post subject: Reply with quote  Mark this post and the followings unread
Excellent ! Merci beaucoup ! Very Happy
