today> Twyndyllyngs cancelled tonight Chez Mosc
Browser Based Lunetta - State Machine
Page 1 of 1 [13 Posts]
passepartoutduo
PostPosted: Sun Nov 16, 2025 12:40 pm    Post subject: Browser Based Lunetta - State Machine Reply with quote  Mark this post and the followings unread
Hi everyone!
It's my first post here - but Lunetta and this forum has been a big inspiration to me! A couple years back I put together a little CMOS synth with a bunch of logic circuits:
Since then, I've made a synth you can play in your browser called State Machine - it's a patching environment where the modules mainly emulate CMOS 4000 series chips.
Feel welcome to check it out here: https://passepartoutduo.com/state-machine
Let me know what you think - if there are bugs, a module you think should be included, etc. please tell me about it!
You can click the info icon to get some relevant info about the module, and also a mention of the analogous hardware - so most things patched up here could be easily made in hardware too.
You can also check out example patches in the file browser
PostPosted: Sun Nov 16, 2025 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, cool, nice idea, and welcome
I'll mark this post as unread - to check things out later - maybe to get some build ideas myself too Cool
PostPosted: Mon Nov 17, 2025 9:45 am    Post subject: Reply with quote  Mark this post and the followings unread
I love this! Thank you so much for sharing it.
JacobWatters.com
PostPosted: Mon Nov 17, 2025 11:07 am    Post subject: Reply with quote  Mark this post and the followings unread
very nice work! Razz
and now that I found night mode (I see it's a lightbulb/moon combo, and not an enlightened duck) I can actually read it,
though my monitor is a bit too small for this kind of stuff.
as for missing modules; a euclidean generator is always fun and a BCD to 7-segment decoder can also be quite useful,
you could even add an 'LED display' to it.
passepartoutduo
PostPosted: Mon Nov 17, 2025 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks so much for checking it out!
Yes a 7-segment decoder and display would be great! I'll give it a go sometime soon Very Happy
I think the euclidean generator is the type of thing that you could put together with existing modules and save as a snippet (Ring counters, binary counters + some logic should get you pretty close!)
PostPosted: Mon Nov 17, 2025 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
What about pots that you can use as voltage dividers or for volume control? Then you could create a sequencer.
Maybe a filter too - even if it's just 6dB/octave. It would help tone down the bright square waves.
JacobWatters.com
passepartoutduo
PostPosted: Mon Nov 17, 2025 1:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah! So regarding the volume + filters: basically I decided early on that I want to keep it really 'pure binary' in the sense that the output is always going to be 0s and 1s - but actually there is still some volume control and filters.
If you go into performance mode (knob icon in the top right) you'll have access to the oscillators and buttons of your patch in a big interface (you can assign different ones), and also a global filter and delay effect, just to give some space and mellow out the sound if desired. You can keep the filters and delay as you patch if the 'fx link' toggle is on (top right in performance mode).
You have global volume, not per channel, if you hover or long tap over the audio icon.
When it comes to sequencing, it's just a slightly different idea, instead of sequencing via CV, the way to achieve a basic 8 step sequencer is to patch 8 oscillators into a multiplexer's inputs, and count through it with a binary counter for ordered sequencer, or whatever other logic for more complicated sequences.
Hope that helps and you can achieve what you're looking for! Thanks for checking it out Smile
Happy to send over an example patch if it helps!
PostPosted: Mon Nov 17, 2025 1:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Awesome! Thanks. I missed that.
JacobWatters.com
passepartoutduo
PostPosted: Tue Nov 18, 2025 12:09 am    Post subject: Reply with quote  Mark this post and the followings unread
I had a go at adding the 7-segment display and decoder - it's pretty fun! It should be live on the site if you wanna try it out -
PostPosted: Tue Nov 18, 2025 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
works perfect and looks very nice too Smile
I did notice it only counts from 0..9, you could add A..F (hex) to it so there are always some outputs active.
passepartoutduo
PostPosted: Tue Nov 18, 2025 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! I was thinking about it - I want to make sure there's always some hardware to back it up, so it's just copying the operation of a CD4511... But I agree that it's a bit silly not to just have A-F after.
passepartoutduo
PostPosted: Tue Nov 18, 2025 10:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Added the hex too, why not! Just note that it wouldn't work like that on a CD4511
Ruebezahl
PostPosted: Wed Nov 19, 2025 4:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello, I already had a lot of fun with it Smile
