Kaoss Pad 1 and G2
Page 1 of 1 [3 Posts]
5inusoid
PostPosted: Wed Sep 26, 2007 7:27 pm    Post subject: Kaoss Pad 1 and G2 Reply with quote  Mark this post and the followings unread
OK more questions....
I'm basically (no pun intended) using my G2 engine as the effect unit for my live bass rig. I'm using a Kaoss pad to change patches, and want to use its midi cabailities to alter patches. I've been able to use the Y-axis (up and down? or is that reversed) to send cc#2 that I can midi learn to whatever. The X-axis is set to cc#1 - pitchbend. How can I use pitchbend messages to affect parameters?(Midi learn chart starts at 2 and goes to 127). Also, the effect on/off button on the Kaoss pad supposedly sends on cc#94, and I would like to use this to control switches within patches, but it doesnt seem to be working. Anyone use a Kaoss pad with the G2, or anyone able to tell me what I'm doing wrong?
jamos
G2 patch files: 41
PostPosted: Wed Sep 26, 2007 10:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
CC1 is not pitch bend. Read your manuals.
Use the MIDI receive module if you want to have complete access to MIDI controllers; use the Device module for pitch bend.
5inusoid
PostPosted: Thu Sep 27, 2007 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, you are right. Scolding duly noted.
http://www.thewretch.com
