Mixer Strips
Page 1 of 1 [2 Posts]
Would Mixer Strips be helpful?
Yes
62%
 62%  [ 5 ]
I don't care
37%
 37%  [ 3 ]
No
0%
 0%  [ 0 ]
Total Votes : 8
jamos
G2 patch files: 41
PostPosted: Tue Aug 17, 2004 10:17 am    Post subject: Mixer Strips Reply with quote  Mark this post and the followings unread
The current G2 mixer complement is very rich, but at times, mixing several parts within a voice can be tricky. The capabilities of the various mixers decrease as the number of inputs increase. This is understandable, but it means that, as a patch [especially a sequencer patch] grows, it becomes difficult to build the mixer section of a patch.
This proposal is for a scalable mixer based on strip components, which each contain all the basic controls for a single "track", as shown below. These strips each connect directly to one of the 6 output pairs, and also have an alternate "send" output which ties directly to another output pair. This allows effects, especially reverbs, to be shared among multiple parts, with independent wet/dry mixes.
Stereo and mono versions are provided: the mono version has an associated pan control.
 Filesize:  2.71 KB
 Viewed:  2675 Time(s)
 Filesize:  2.55 KB
3phase
G2 patch files: 141
PostPosted: Tue Aug 17, 2004 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
This would be not bad but some of the other mentioned wishes have an higher value for me. But it would help to safe some percents memory load. The stereo module should have a pan aswell. with this you can use a stereo patch with a single output in live situations without the need to rewrite the patch.
