Minimoog VCF transistor question
Page 1 of 1 [3 Posts]
Mick Bailey
PostPosted: Tue Jan 19, 2010 12:56 pm    Post subject: Minimoog VCF transistor question Reply with quote  Mark this post and the followings unread
How does the Hfe of the ladder transistors affect the way the filter behaves? I used matched pairs of BC 547B (Hfe worked out at 317 after selecting the transistors from a batch of 30)
I have a batch of 100 2N5088 with a Hfe of 480 which I could use instead.
The reason I ask is that I'm fairly happy with the filter, but the resonance control has a very narrow range of operation even with the trimmer at its minimum setting. It will self-oscillate though.
I wondered if swapping out the transistors would be beneficial to the way the filter performs.
yusynth
PostPosted: Wed Jan 20, 2010 6:46 am    Post subject: Reply with quote  Mark this post and the followings unread
The Hfe of the ladder transistor has nothing to do with the response of the resonance.
What is important and gives a progressive resonance control is to use a reverse audio (or reverse log) 50K potentiometer, that is the C curve, as stated in the BOM. Using a linear or an audio (log) potentiometer (A and B) will not give the good resonance control and all the range gets concentrated over a very short range.
50KC pots can be purchased at banzaieffects, musikding and smallbear electronics
Yves
Mick Bailey
PostPosted: Thu Jan 21, 2010 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the advice on the transistors. I'm currently using a 47k log pot, but wired so that maximum resonance is fully anti-clockwise (control operates backwards). This is a temporary arrangement until I build up a list of items to make placing an order with Banzai worthwhile.
