 Forum index » DIY Hardware and Software » Musical Interfaces
Keytar Mod Plus Ribbon Controllers
Page 1 of 1 [3 Posts]
dshay
PostPosted: Sat Aug 25, 2012 5:38 pm    Post subject: Keytar Mod Plus Ribbon Controllers Reply with quote  Mark this post and the followings unread
Making a Keytar out of an old Korg microKontrol I got off ebay for $50 because it was missing a fader knob.
Made it wireless out of a transciever I breadboarded and I'm going to hack the Pitchbend/Mod wheels, bypassing the joystick in place of a Digital Potentiometer that's controlled by the Ribbon Controllers, aka Soft Pots.
Posted Image, might have been reduced in size. Click Image to view fullscreen.[/img]
prosperitymusic
PostPosted: Mon Sep 24, 2012 2:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you get the softpots working?
Where there any modifications needed, or did you just connect them?
dshay
PostPosted: Mon Sep 24, 2012 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
prosperitymusic wrote:
Haven't got them working yet, I've got a few other projects to get to before this.
You do not just hook them up.
You'd have to bypass the joystick potentiometer and replace those two axis with a Dual Digital Potentiometer that is controlled by a microcontroller that is reading the soft pots on it's Analog to Digital inputs.
There would be a couple tricks to this, most of which, the MOD effect you would want to stick in the last touched position instead of returning to a zero.
