Fix Morph assign
Page 1 of 1 [4 Posts]
Should the value of a knob remain the same when a morph is assigned to it?
Yes
100%
 100%  [ 3 ]
Don't care
0%
 0%  [ 0 ]
No
0%
 0%  [ 0 ]
Total Votes : 3
jamos
G2 patch files: 41
PostPosted: Wed Nov 10, 2004 8:42 pm    Post subject: Fix Morph assign Reply with quote  Mark this post and the followings unread
This has been bugging me since I started using Morphs, which is about 1/2 hour after I opened the box.
Whenever I assign a morph on a knob.. the knob's base value jumps to zero. This means that my carefully adjusted settings go out the window when I add a morph.
I'd like to see the initial value retained when a morph assignment is made. Wouldn't you?
Audio files: 213
PostPosted: Wed Nov 10, 2004 9:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
This has been a bit of a problem for me too, but I figured there was some trick that you could use to do what you describe. Apparently not...
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Wed Nov 10, 2004 9:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Select the morph group you want by clicking on the respective knob in the top right of the editor, then click twice on the knob you want to assign, holding down the second click. When you drag the mouse with the second click held down, the knob will be assigned to the current morph group, and as you drag the mouse around you will be setting the morph range relative to the knob's current value.
Audio files: 279
PostPosted: Thu Nov 11, 2004 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Or press the control key while you click. On my laptop's touch pad I have to usr CTRL + one-and-a-half clicks (taps, actually).
This is the same combination as is needed to pull wires out of connectors (e.g. to break a connection by dragging).
Jan.
