My WSG build has started!
Page 1 of 1 [6 Posts]
abstraktor
PostPosted: Mon Feb 21, 2011 1:49 pm    Post subject: My WSG build has started! Reply with quote  Mark this post and the followings unread
Well. after buying the WSG pcb and front panel last year, I've finally gotten round to populating the board this weekend and am nearly finished stage 1 (3 caps and 2 diodes to go).
I had to buy a new variable temperature soldering iron because my old one wasnt getting hot enough, but this is a dream to use. I can also recommend a powered de-soldering pump for these...embarrassing moments.
I'm trawling around looking for a box or enclosure to put the WSG in, but so far no joy -maybe a trip to IKEA is on....
Next stage is the wiring to the panel, and then a test!
(The multimeter is on standby Wink )
[/img]
 Filesize:  1.03 MB
 Viewed:  148 Time(s)
abstraktor
PostPosted: Wed Mar 02, 2011 1:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Having finished the board and sourced the last few pots, I managed to get a cigar box for £1.50 from a local shop which is almost a perfect fit for the WSG panel-result! Soaked it for an hour in warm water to remove the paper. Its a bit flimsy, but should hold together ok (!). Wiring the miniature pots to the board will be a bit of a pain, but the end is in sight.
Weird (No) Sound Generator? Hope not! Laughing
 Filesize:  1.89 MB
 Viewed:  129 Time(s)
Audio files: 156
PostPosted: Wed Mar 02, 2011 1:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice case Smile
hope the wiring goes well.
abstraktor
PostPosted: Wed Mar 02, 2011 3:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
cheers dave Smile
I know I am but a novice in light of your impressive builds!
abstraktor
PostPosted: Fri Mar 11, 2011 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
nearly finished the panel wiring but these miniature pot terminals are a bitch to solder multiple wires to!
 Filesize:  1.87 MB
 Viewed:  138 Time(s)
Audio files: 43
PostPosted: Fri Mar 11, 2011 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
That looks great!
I just ordered a WSG PCB -- I'm building one for my granddaughter.
She already told me what color she wants -- a yellow case with purple lettering. Smile
