Cfish
Posted: Sun Mar 13, 2016 8:41 am Post subject:
Looking for vca recommendations |
Hi all. I am hoping you all may be able to shed a little light on the VCA subject for me.
I have scratch built a few different vca circuits from different schematics. I have ben looking for something to use in my second mono synth project.
Circuits I have built so far were all based around the action of a single transistor or single fet .
When I look at more advanced circuits I think I may be missing something in the (cosmic uses and purposes of a vca) in the synth world.
I use my VCAs for the usual gate the audio path with either the gate signal or an envelope generator.
A lot of the schematics I am seeing seem to have additional purpose in there grand scheme. (AC and DC SETUPS) (odd control inputs)
I would appreciate any guidance on this topic. |
synaesthesia
Audio files: 85
Cfish
Posted: Sun Mar 13, 2016 6:37 pm Post subject:
Thanks Synaesthesia. I'm digging for an or gate now to give this a run on the breadboard. Only enhansment FET I have on hand is 2n7000. Data sheet looked close enough to keep the magic smoke inside where it belongs.
Thanks again. I'm always looking for new circuits to try out |
synaesthesia
Audio files: 85
Cfish
Posted: Wed Mar 16, 2016 2:06 pm Post subject:
| i like that concept really well. I used something similar in a past project, using LDRs to ground and used LEDs to trigger. A lot of signal still made it through. Made a nice tremolo though. Will give that one a shot on the breadboard. The first was rough on a sign wave. |
Cfish
Posted: Wed Mar 16, 2016 2:18 pm Post subject:
| No hex inverter on hand so I will try inverting with an opamp. I really like the simple sample and hold capicitor layout for the decay. |
synaesthesia
Audio files: 85
Posted: Thu Mar 17, 2016 12:26 am Post subject:
| You don't have to use an inverter, you can use any gate. All you need is a brief low pulse at the 1K resistor. |
Posted: Fri Mar 18, 2016 7:05 am Post subject:
| I like Thomas Henry's VCA from _Analog Synth for the 21st Century_. Uses two stages of a V2164/SSM2164, so one chip (and the other various op amps etc) can provide a dual VCA. |
Cfish
Posted: Fri Mar 18, 2016 5:33 pm Post subject:
| Thanks Elmegil, looks like I need to order the book. |
Posted: Fri Mar 18, 2016 8:29 pm Post subject:
| Cfish wrote: | | Thanks Elmegil, looks like I need to order the book. |
I bought the e versions on lulu.com, was not expensive.... |
Posted: Sat Mar 19, 2016 12:40 am Post subject:
Where is the paper copy?
I've heard somewhere it's only on magic smoke, which I don't entirely trust to not be a money pit. |
Cfish
Posted: Sat Mar 19, 2016 4:42 am Post subject:
| I had read the stories about (magic smoke). Found several second hand copies available on line. |
Posted: Sat Mar 19, 2016 6:23 am Post subject:
Lulu.com is not affiliated with Magic Smoke directly, and they sell both the PDF and the paper copies. You don't need to worry about their fulfillment process, Tim's not in charge of it  |
