Thalassa
Posted: Thu Mar 05, 2009 11:11 am Post subject:
BC547 question ( applied to other ICs) |
Hello Yves
I have little experience on DIY and this will be the first time that I order my own components so I have some doubts.
I'm ordering the necessary components to build some of your modules and I have a question about the BC547
One of the modules that I want to build is the Matched BC547 VCO version. On this module the BC547 has to be BC547B, and the question is that in other modules I need also BC547 ( Moog Filter, Clock Divider,diode ladder filter,lfo ). So I'm wondering if I can order a bunch of this BC547B to use on the other modules and this way will be easy to find 2 matched BC547 ( I also need to match them for the minimoog filter). I can't find the differences between the models because the datasheet that I found are the same for both models.
My doubt can be applied for other IC, when you don't specify other thing,can I use whatever version I have ? For example when you said TL074, Can I use one of this TL074CN ,TL074BCN ,TL074ICN?
Pablo _________________ http://www.corsynth.com |
wmonk
Joined: Sep 15, 2008 Posts: 528 Location: Enschede, the Netherlands
Audio files: 15
Posted: Thu Mar 05, 2009 2:20 pm Post subject:
Hi Pablo,
There are typical two common types of BC547: the BC547B and the BC547C. The difference is the pin-layout.
You can see the difference here: http://www.datasheetcatalog.org/datasheet/SGSThomsonMicroelectronics/mXytvtz.pdf
Perhaps it's a good idea to have the schematics at hand when building. But I think Yves only uses the B.
Wmonk
EDIT: sorry, did have something wrong. The Yusynth ADSR needs BC547C, |
yusynth
Posted: Thu Mar 05, 2009 2:38 pm Post subject:
In general I use BC547C in my designs because they can handle most of the currents that are required in those circuits. For the VCO I used the B kind because they offer a Ic versus Vbe relationship that is better suited for an exponential current converter.
Anyway a BC547b is really cheap, therefore you can buy a bunch of them in order to select matched pairs. In general when coming from the same production batch you can find four matching pairs out of 25 trannies. And even in circuits where I use BC547C you may use BC547B.
Concerning the TL074 you may use any kind, it really doesn't matter. _________________ Yves Last edited by yusynth on Mon Jun 28, 2010 1:25 pm; edited 1 time in total |
Thalassa
Sebo
Posted: Thu Mar 05, 2009 4:41 pm Post subject:
| wmonk wrote: | Hi Pablo,
Wmonk
I could be wrong, but I think that the subfix letters in transitors reffers to different
hFE ranges.
The pin-layout should be the same for the 3 kinds (A, B or C).
I checked the datasheet you posted and confirms what I'm saying  _________________ Sebo
My Music:
https://www.facebook.com/cosaquitos/ |
wmonk
Audio files: 15
Posted: Thu Mar 05, 2009 5:50 pm Post subject:
Yeah, I was wrong. Realised it when I had it posted, but the beer was waiting on me
Anyway, it's always good to have a pile of both B and C to get good matched pairs, and they're cheap to! |
Thalassa
Posted: Fri Mar 06, 2009 12:13 am Post subject:
| Sebo wrote: |
hFE ranges.
I checked the datasheet you posted and confirms what I'm saying  |
Yes, I also notice that,
BC547B Hfe = 200-450
BC547C Hfe = 420-800
Thanks , Now I know the difference  _________________ http://www.corsynth.com |
intoodeep
Posted: Sat Apr 24, 2010 3:34 pm Post subject:
| A little confused.. people who have successfully built the moog filter clone, what trans did you use for the ladder? BC547, BC547B, or BC547C? |
Sebo
Posted: Sat Apr 24, 2010 5:34 pm Post subject:
I don't think that the subfix letter matters. They should be the same letter
because it will be easier to match them. _________________ Sebo
My Music:
stilz
Joined: Jun 22, 2010 Posts: 13 Location: Germany Eschwege
Posted: Mon Jun 28, 2010 11:26 am Post subject:
| The subfix letter matters! But Yves describes it very good. Use BC547C |
intoodeep
Posted: Mon Jun 28, 2010 5:31 pm Post subject:
| Thanks for the reply, i got the filters working using 547C. The subfix is the range that the current gain will be in i think and it definitely does matter afaik in the circuit.. I also had a lot of problems using 547 and 547B in the expoconverter for the VCO. That one I had to use B. |
stilz
Posted: Tue Jun 29, 2010 3:05 am Post subject:
| Nice to hear it works now. |
MrZ
Posted: Sat Mar 23, 2013 1:13 pm Post subject:
I used 2N3904 for the tran ladder of the moog vcf clone
it works. |
Freq Band
Posted: Fri Nov 17, 2017 2:22 am Post subject:
What about BC549 (b) ??
I mistakenly bought these, but I see they are "low noise".
Will these work ?
(minimoog transistor ladder VCF)
BC549 voltage specs:
CBO 30v
CEO 30v
EBO 5v
BC547 specs (suggested part)
CBO 50v
CEO 45v
EBO 6v |
yusynth
Posted: Fri Nov 17, 2017 2:46 am Post subject:
I see no reason why they would not _________________ Yves |
Freq Band
Posted: Fri Nov 17, 2017 10:21 am Post subject:
I'll give it a try.
Thanks YuSynth !! |
