Roland VCF 703 Yves's redrawing
Page 1 of 1 [2 Posts]
alanwilder81
PostPosted: Sat Jul 15, 2017 1:43 am    Post subject: Roland VCF 703 Yves's redrawing
Subject description: error in the original Roland VCF schematics?
hello Yves,
i am comparing the original Roland 703 VCF schematics to your redrawing of it. It looks that you corrected what i think it's a mistake on the original.
In your redrawing, on the third integrator cell, the resistor R 22 (470 k), coming from the DC offset trimmer wiper, is connected to the 3080 positive input, just like in the other three cells the 470 k resistor goes to the positive 3080 input.
Now, on the original Roland 703 VCF ,and in the third cell only , the 470 k resistor goes to the negative 3080 input.
Why would the third cell configuration be different to the other three?
is that a Roland mistake you corrected, Yves?
thanks for any hint !
 Filesize:  72.53 KB
 Viewed:  386 Time(s)
yusynth
PostPosted: Thu Jul 27, 2017 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes there is a discrepancy and I haven't checked on the PCB (what I ought to do for sure). Anyway, the trimmer is there to reduce the bleed-through of the control CV. The fact it is connected either on the inverting input or non-inverting input has no importance really. But you're right I will check on the PCB.
Yves
