mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Tue Mar 06, 2007 7:13 am Post subject:
Ok i bought some ua726's from the guy.
I got them gave him feedback etc...
But a month a go a friend needed one and none of them did work.
A friend of my bought some ca3080's same story.
Same goes with his mn3xxx ic's.
They are all relabeld crap.
And no bad word about cy (chipforbrains) here!
He really is the best and honnest chip/part suplier from the east!
I think most people should check their stuff before putting up feedback.
Because i am kinda sure most MN3xxx ic's i bought from hkss are relabeled crap to. |
kryptic
Posted: Tue Mar 06, 2007 12:10 pm Post subject:
Oh, that definitely sheds some new light on it then. I did not realize that cy was actually chipforbrains. I must say that I have actually dealt with chipforbrains myself and the transactions went flawlessly and he is a very good and recomended seller. My friends who dealt with hkss did not purchase many chips but rather jacks and pots which were the same quality as futurlec only cheaper pricewise. Thanks for informing me of your experience mono-poly, I think I will have to reevaluate my opinion on hkss being that I was not basing my opinion on chips but rather other parts such as jacks and pots. If the chips are relabeled, that is just horrible business practice, so I will not be making any chip purchases from him.
(although I still think the HK mafia story was a bit of a stretch. I doubt the mafia is interested in making profits by selling $.02 switches and relabeled chips, the profit would not justify the time/trouble) |
funkyfarm
Posted: Tue Mar 06, 2007 12:36 pm Post subject:
| fonik wrote: | | funkyfarm wrote: | | fonik wrote: | | funkyfarm wrote: | Isn't there any Q compensation in the SSM2044 ? for volume drop ?
this is a specific _feature_ of the ssm filter, i think
AFAIK it's typical... |
Oh for sure ?
Even the superstar 2040 ? no Q compensation ? |
the datasheets for ssm2040/44 don't say nothing about it... i breadboarded that circuit and i couldn't hear a dramatic volume drop. |
In fact, volume drop is not so dramatic, but I am still quite surprised.
What the hell these dedicated IC were made for ?
Integrated VC-resonance is great, for sure
[edit] Feebacks should be forbidden on eBay. I've got twice shameless defeated devices and the sellers always say : "I really don't understand !? Look at all my positive feedback, etc, etc..."[\edit] |
Posted: Tue Mar 06, 2007 2:32 pm Post subject:
as you might already know these filter ICs where used inside Korg Polysix, Korg Mono/Poly, Fairlight II, PPG Wave 2.2 und 2.3, Emu SP-1200, Siel DK600 and Siel Opera 6... _________________
Tech Buddy at Random*Source |
mono-poly
Posted: Wed Mar 07, 2007 4:40 am Post subject:
Feedback is nice to blackmail each other
I am pretty sure you can buy knobs etc from hkss but i would avoid ic's etc for sure. |
amos_joseph
Posted: Wed Mar 07, 2007 8:54 am Post subject:
| I've purchased knobs and switches from him several times without any problems, but I've never picked up any ICs from him. It's a good thing I saw this post, I was looking for some CA3080 ICs. I guess I'll order them from Small Bear Electronics instead. |
sneakthief
Posted: Mon Mar 12, 2007 4:13 am Post subject:
I would love to hear some sound samples of this filter! Anybody?
I searched and only found a couple of tiny mp3's... _________________ Sneak-Thief - raw electrofunk |
Posted: Mon Mar 12, 2007 4:18 am Post subject:
maybe tonight i could do a sample... _________________
Posted: Mon Mar 12, 2007 5:00 pm Post subject:
here are two samples.
first the ssm2044 as filter. a 5th saw wave sound is filtered without resonance first. the cutoff lowers and the modulation appears. then the resonance comes in (you can hear the volume drop):
ssm2044_VCF (1.7MB)
then the ssm2044 in selfoscillation, no filtering:
ssm2044_OSC (1MB)
the samples are recorded direct from the output of the filter into my terratec EWT88 I/O.
hope that helps. _________________
Funky40
G2 patch files: 5
Posted: Mon Mar 12, 2007 8:15 pm Post subject:
hi fonik,
while you are thinking about a PCB run:
I like and will do the SSM together with the Wasp into 1 Frontpanel,+ also an input and output mixer.
( + also inverting switch for the CV inputs)
I had this Idea in the first weeks having my doepfer SSM and Wasp.
I used them always as a Team patched up in parallel.
( i like in general to patch up synthvoices with LP, BP, and Hp in parallel, and mix them up as neeeded .
And no, i nearly never use my Dotcom state variable filter Q107 )
And i serously thought about to take the dopefers out of their Faceplates.
so l'm happy for the fonik PCB layouts....................
what do you guys think about such a module ?
__________________________________________________________________
And as i have now another Polivoks filter with input mixer (3inputs) and an outputmixer for Lp + BP ( +single outs),
i can say:
i definitly make other music with this, then with the "normal" polivoks).
will say: An SSM and an Wasp filter togehter with two mixers as single modules will be used different, not only by me, i think.
Buildin this modules togehter into one must be really very handy.
ok, maybe it's just my route, but maybe not.  |
softfin
Joined: Oct 11, 2006 Posts: 271 Location: Far in the north
Posted: Tue Mar 13, 2007 8:43 am Post subject:
Thank for the samples Fonik!
Sounds so good that now I have no other option than to build one
If you end up ordering a run of PCBs for these, I'm definately in for a couple.
Best,
Lassi |
Posted: Tue Mar 13, 2007 9:03 am Post subject:
| softfin wrote: | Thank for the samples Fonik!
Best,
Lassi |
i want to see how the PS3100 thing works out at least.
concerning the ssm2044 i could think of a singlesided PCB without soldermask or screenprint (homebrew kind of thing like the marc barreille PCBs) but with a SSM2044 IC as companion.
it depends on the amount of interest... _________________
Posted: Thu Apr 19, 2007 11:19 am Post subject:
| fonik wrote: | | concerning the ssm2044 i could think of a singlesided PCB without soldermask or screenprint (homebrew kind of thing like the marc barreille PCBs) but with a SSM2044 IC as companion. |
i just made 4 such PCBs.
i would sell each PCB together with a ssm2044 IC for 18EUR/25USD
shipping 4EUR/6USD. (paypal only)
first come, first serves...
consider that these PCB are handcrafted: no solder mask, no silkscreen.
BTW i did a simple sample yesterday: SN voice, EFM dual VCO, CGS utility LFO, baby10 sequencer and SSM2044 VCF:
ssm2044 8MB _________________
vtl5c3
Posted: Thu Apr 19, 2007 12:06 pm Post subject:
Hi Matthias,
Those boards look really nice. How do you cut them to get such straight edges? I'm still using tin snips, which doesn't look good at all.
Romeo |
Posted: Thu Apr 19, 2007 10:57 pm Post subject:
| vtl5c3 wrote: | Hi Matthias,
Romeo |
oh, i didn't etch them by myself - someone else did it for me. so i don't know how they are cut.
when i do PCBs i cut them with tin snips and sand them down then. _________________
etaoin
Joined: Jun 30, 2005 Posts: 761 Location: Utrecht, NL
Posted: Thu Apr 19, 2007 11:31 pm Post subject:
| Quote: |
There are dedicated PCB cutters. Much like metal sheet cutters, they cut the PCB over the full length in one go. |
krisp14u
Posted: Thu Apr 19, 2007 11:38 pm Post subject:
as some one who got there hands on some of these PCB's early
they are top quality
cheers Matthias
paul D |
etaoin
Posted: Thu Apr 19, 2007 11:45 pm Post subject:
Fonik,
How does this new design differ from the one on your website? |
Posted: Fri Apr 20, 2007 12:43 am Post subject:
| Etaoin wrote: | | How does this new design differ from the one on your website? |
this layout is based on the same schematic. the layout on my site is "customized" for my special needs (footprints for cliff sockets with 20mm grid).
this new layout is compressed, no terminal power header. _________________
Posted: Fri Apr 20, 2007 12:50 am Post subject:
| krisp14u wrote: | as some one who got there hands on some of these PCB's early
cheers Matthias
paul D |
hello paul,
did you built one yet? _________________
ambi-J
Posted: Fri Apr 20, 2007 7:18 am Post subject:
very nice layout, indeed and
as you can see from the schematics i added a unity gain to mix the CVs for the Q control. the 2nd section of this unity gain has a trim pot in its feedback path to adjust the point of self oscillation. i furthermore added a resistor to the q control potentiometer to get a reversed audio response.
i wonder about the input section. i actually added a attenuator to lower the gain on the input, since i have some hot signals in my modular
i decided to put the PTC in physical contact to the IC. i have had no time yet to measure the stability of the tune. what are your experiences? _________________
krisp14u
Posted: Fri Apr 20, 2007 8:04 am Post subject:
| fonik wrote: |
hello paul,
did you built one yet? |
Err no not yet
I need to order some resisters due to all the electro-music PCB I've got
I have run out of many common values but i didn't realise until yesterday
going to put an order in for some today
running low on caps too
Paul D |
softfin
Posted: Fri Apr 20, 2007 10:33 am Post subject:
I built it on stripboard recently, sounds fine, and to me it resembles considerably my moog filter with 22n (they're changeable to 68n with a 4pdt toggle) caps in the filter core.
Anyway I think Fonik's SSM2044 is a good and useable filter. Only the resonance control needs to be adjusted slightly to get it easier into selfoscillation.
I'm not yet sure how to do it, but probably it would be possible simply by reducing/increasing some resistors in the resonance control path.
Hey Fonik btw, could you sell me a couple of those SSM2044 boards without the SSM chips ? I have a handful of those chips already so I think I don't need more at the moment... |
ambi-J
Posted: Fri Apr 20, 2007 12:05 pm Post subject:
you can lower the point of self-oscillation by decreasing the value of the 13k resistor on pin 2 in the schematic on the data-sheet (the one i use in my pdf)
I use a 10 k value and it gives selfoscillation on the last 10à20 pc of the pot.
if you go too low i think you may damage the chip?
I don't use ptc on my boards. I think you do not need them: the chip heat almost nothing and even if I put my finger on the chip (to warm it up) the frequention did not rise notably.
it might be neccesary on older batches of the chip (the one i use is one of the last. it comes from cfb) especially in extreme conditions like in a ppolyphonicsynth in live conditions, but even then i never have seen a tempco on a filterchip.
a bigger problem is the tracking: I can't get it better than 3 octaves (self-osc without input). with a little input from a osc ( even not audible) it's better. |
