today> Twyndyllyngs cancelled tonight Chez Mosc
Moog ladder HP mode
Page 1 of 1 [7 Posts]
Fernando
PostPosted: Mon Jun 25, 2007 9:34 am    Post subject: Moog ladder HP mode
Subject description: do the Morita trick work?
Hi all,
Reviewing Moog ladder schematics in my archive I found this variation:
http://www5b.biglobe.ne.jp/~houshu/synth/moritaVCF76.gif
it includes a switch to HP mode by just injecting the input signal to the output buffer (through a trimmer and a resistor)
I like this version:
http://homepage2.nifty.com/rjb/pdf/rjb_diy_synthe_202a_vcf_moog_schem_revB.pdf
http://homepage2.nifty.com/rjb/pdf/pcb_202a_vcf_revA.pdf
http://homepage2.nifty.com/rjb/diy_synthe9.htm
and wonder if it would be possible to implement the Morita trick to get HP response...
Dan Lavin
Audio files: 21
PostPosted: Mon Jun 25, 2007 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll be honest with you that high pass filters are neither something I use or am an expert at, however, I did take a peak at a couple schematics of state variable filters and they do seem to take the HPF output off of the input stage. I can also understand your attraction to this: everyone likes the Moog LPF, but likes the versatility of a state variable type. If I were you, I'd build the Moog LPF, then tack solder on the HPF mod (or breadboard) and see how it performs. If it doesn't work, you still have a nice Moog LPF. Or, you could always breadboard the whole circuit.....
Now, I do recall seeing a Moog filter with either a HPF or a BPF filter option and I don't think the circuit you listed was it. Unfortunately googling this will give you a million hits as Moog is a popular search.
I'm sure you don't like my answer. It's like when you ask a question in school and the teacher tells you to research the answer yourself and report back the results to the whole class! What you end up with is a bunch of kids who keep their mouths closed during class! Sorry, my apologies. Hopefully someone else out there is a better HPF expert.
PostPosted: Mon Jun 25, 2007 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's not quite /that/ bad, I got just 54 hits on "moog lpf hpf filter schematics" - they might be "bad hits" of course.
What sometimes helps for cases like this is to search for images instead.
goldenechos
PostPosted: Mon Jun 25, 2007 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Moog Voyager does something of this sort... It has Two LPF and the ability to switch one of the two iinto a HPF mode giving you a high pass into a low pass.
TR
zipzap
PostPosted: Tue Jun 26, 2007 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I saw a schematic with the ladder in pb mode. have to look.
Basically it´s like this:
If you substract the lp from the original you get a HP.
If you substract the HP from the LP you get a BP (?)
If the filter performs very good this will sound as expected. I tried this with my moog ladder. It sounded different. That´s because the LP was not only cutting away the highs, but also changing the low signal parts in such a way, the substracting them from the original still left a lot of bass in the signal.
BTW, anyone know the sherman filterbank?
It´s got two pots to set the filterresponce.
One to blend from Lp to BP to HP.
One to blend from -BP to -BP+LP+HP
With this everything is possible, and it sounds really great. No idea how this is done, though.
http://www.myspace.com/lorolocoacousticpop
http://www.myspace.com/petrolvendor
music and transcribed jazz basslines
goldenechos
PostPosted: Tue Jun 26, 2007 4:25 am    Post subject: Reply with quote  Mark this post and the followings unread
The above is a good description of how the Voyager achieves HP filter using 2 of Bob's LP ladder filters.
TR
Fernando
PostPosted: Tue Jun 26, 2007 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
all very interesting info, thank you
I'm not looking for multifunction, I plan to build many different kinds of filter topologies
BTOH, Ken Stone's "CV Cluster" can be used (among a miriad of other uses) to control two filters and get variable bandwidth response a la Moog modular filter controller using an HP and a LP, etc.
I posted that schematic because I found interesting the trick.
Maybe does not give you a real HP response out of the ladder but something interesting, we'll see...
and since I do not have a Moog ladder built yet I was trying to stimulate someone to try it, since it's just a trimmer, a switch and a resistor =:)
hey, and if it works (or it does something interesting) a switched pot could be used to get intermediate responses...
