 Forum index » How-tos
Modulating theremin / mongolian throat singers
Page 1 of 1 [12 Posts]
verneda
PostPosted: Tue Aug 07, 2007 1:56 am    Post subject: Modulating theremin / mongolian throat singers Reply with quote  Mark this post and the followings unread
Hi everyone,
I've recently added a moog etherwave theremin (sd) to my live setup, which is in turn fed into a korg kaos pad (for real-time modulation of delay and reverb).
I'd like to modulate the signal with harmonic overtones (randomly fluctuating resonances, multiple pitches etc), similar to Mongolian throat singing. Is there some piece of hardware kit that I can add into my signal chain to achieve this?
Thanks
madhatter
PostPosted: Wed Aug 22, 2007 4:42 am    Post subject: Reply with quote  Mark this post and the followings unread
If you route it through a PC you can set it up in fruity loops with some formula controllers... if you want to use a PC that is...
.//VelkroSmaak
View user's profile Send private message Send e-mail MSN Messenger
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Wed Aug 22, 2007 7:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I think a Nord Micro Modular (no longer in production so find a used one) or G2 engine would do nicely.
The theremin's wave is close to sine so needs some basic shaping to provide harmonics for the vowel filters to work with.
The nord could full wave rectify the sine to produce a glottal type waveform for it's voice filter. It also has a vocoder.
iPassenger
G2 patch files: 78
PostPosted: Fri Aug 24, 2007 1:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Any chance of you patching one of these up on the G2? Would really like to hear some Mongolian throat singing coming out of my little red brick.
R.
iP (Ross)
verneda
PostPosted: Fri Aug 24, 2007 2:20 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, thanks for the replies!
The G2 sounds like just the thing I'm looking for. Is it easy to program? I was searching for some kind of description for glottal waveforms, and got the impression that complicated algorithms are needed to create them. This really seems a bit beyond my knowledge of sound synthesis. Are their any premade patches available for the G2 that have been made specifically for this effect, or could anyone kindly create a patch as an example/experiment?
Much thanks
PostPosted: Fri Aug 24, 2007 3:16 am    Post subject: Reply with quote  Mark this post and the followings unread
The Clavia G2 is basically a digital version of something like this:
It does come with a few presets but probably nothing which would be useful for your mongolian singers out of the box.
You will need a PC in order to run the G2 editor application.
You use that application to build patches. Patches can then be saved in the G2 and accessed from the front panel.
You will have to build your patches yourself. I wouldn´t say it is difficult, but you will have to invest a lot of time into this. Thing is, with a G2 you will be able to learn both basic and advanced synthesis and this is a good thing. Very Happy
Flickr
Audio files: 266
PostPosted: Fri Aug 24, 2007 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
So would I, but I don't know quite what it should sound like - maybe like attached?
This will run in the Clavia Demo software.
07-040-001.pch2
Throat sounds
 Filename:  07-040-001.pch2
 Filesize:  4.02 KB
 Downloaded:  1999 Time(s)
ian-s
Audio files: 42
G2 patch files: 626
PostPosted: Fri Aug 24, 2007 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well that's exactly how I imagined it would sound like. Very Happy
In addition to distorting the theremin wave to add harmonics, you could also experiment with the pitch tracker and envelope follower.
Audio files: 266
PostPosted: Fri Aug 24, 2007 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
This was the key Laughing
I ended up with half wave rectification and a bit of FM-ery.
JLS
G2 patch files: 303
PostPosted: Sat Aug 25, 2007 2:55 am    Post subject: Reply with quote  Mark this post and the followings unread
hey Blue Hell nice Tuvan KARGYRA Smile
Sorry my bad English Smile
https://soundcloud.com/1jls
https://soundcloud.com/user-819966312-266044932
https://github.com/jlswbs
iPassenger
G2 patch files: 78
PostPosted: Mon Aug 27, 2007 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Hehehe...fab, this is really close.
Cheers Jan.
iP (Ross)
cappy2112
PostPosted: Thu Oct 18, 2007 5:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cheers Jan.
I saw this documentary a few months ago- because I had no idea what Tuvan throat singing sound like, or where it came from.
http://www.imdb.com/title/tt0187859/
The documentary isn't very exciting, but is quite informative.
