ericcoleridge
Posted: Thu Oct 11, 2007 8:59 am Post subject:
MFOS VCO module question Subject description: Is the sync suppossed to sound like this? |
The sync on my VCO sounds like it's stepping through different octaves or harmonics rather than the fluid phasing/flanging type sound that I normally think of as oscillator sync. Is this normal for the MFOS VCO? |
RF
Audio files: 28
Posted: Thu Oct 11, 2007 11:31 am Post subject:
I think that has to do with where you have the frequency pot set on the 'slave' VCO... IIRC it need to be set lower in frequency than the 'master' |
ian-s
Joined: Apr 01, 2004 Posts: 2670 Location: Auckland, New Zealand
Audio files: 42
G2 patch files: 626
Posted: Thu Oct 11, 2007 12:29 pm Post subject:
RF wrote: | I think that has to do with where you have the frequency pot set on the 'slave' VCO... IIRC it need to be set lower in frequency than the 'master' |
You only hear the sync effect when the slave frequency is higher than the master. Can you post an example? |
RF
Audio files: 28
Posted: Thu Oct 11, 2007 3:45 pm Post subject:
yeah - what he said my answer was inverted....
Thanks G2.
bruce |
ericcoleridge
Posted: Fri Oct 12, 2007 1:30 pm Post subject:
I think I had the master tuned lower, I mean, the MFOS VCO was definitely syncing... but it doesn't sound like oscillator sync on any synth I've ever heard.
It's almost like it's too strong, it's "stepping" through harmonics in a choppy way instead of sweeping. The oscillator sync sound that I know, and really like, is more of a vocally formant type sound... sort of like phasing. |
Broadwave
Joined: Feb 16, 2007 Posts: 347 Location: Manchester UK
Audio files: 6
Posted: Wed Oct 17, 2007 8:41 am Post subject:
Hi Eric,
I know exactly what you mean... I've built 4 of them, and the sync wasn't what I expected either.
Change the value of the sync input cap to 0.01uf, and you'll get much closer to what you want. It's not perfect, but it's much closer to conventional hard sync. I've found that using a square or pulse wave for the sync input signal also helps
Andy
www.solarmaxx.co.uk |
ericcoleridge
Posted: Sat Oct 20, 2007 5:47 pm Post subject:
Thank you very much for the reply. It's funny, I got this same recommendation from someone else. I'm looking forward to trying it out.
I believe I have a 102 Ceramic cap in there right now. Maybe a box cap would be better also? |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
Posted: Mon Oct 22, 2007 3:22 am Post subject:
Shouldn't the slave VCO be at lower frequencies? I've always thought so
If you tune the slave VCO to a higher frequency than the master, the slave actually manages to squeeze two wave cycles in one cycle of the master. Hence, the "stepping-through-octaves" effect can be heard.
If the slave vco is set to a very low frequency and then sweeps up, I believe you should hear the real syncing effect as the slave wave is gradually introduced inte the mix... I have't really managed to try this on my vco's, but I certainly will _________________ YouTube channel
flickr photostream
http://loxodrom.blogspot.com
http://soundcloud.com/loxodrom |
Broadwave
Audio files: 6
Posted: Mon Oct 22, 2007 6:06 am Post subject:
Pehr wrote: | Shouldn't the slave VCO be at lower frequencies? I've always thought so |
Yes, I agree definately!
The problem is that some VCO designs are Soft Sync and some are Hard... And there lays the problem - which is which?
Some people see Soft sync as harmonics latching in intervals (3rds, 5ths octaves etc.) where as Hard sync gives that typical agressive vowel sound, but I've also read that the opposite is true... Hard Sync latches and Soft is smooth!! Very confusing!
But I can assure you that the Ray Wilson VCO's sync is latching onto harmonics, and it's not until the input cap is changed that I get (amost) the typical sync sound I crave for.
I think it's all down to the reset pulse the sync input is working with... Is it Bi-polar or positive voltage only? Is the amplitude enough? etc.
Many sync input circuits I've seen also involve extra 1N4148 diodes, resistors and NPN/PNP transistors - probably to rectify (positive going pulse only) and sharpen up the incomming sync signal - but as yet, not a single VCO that I've built gives me that perfect ARP Oddy sync sound
Andy. _________________ Kronos 2-88, Kronos 61, Studiologic Sledge V2/SL, Broadwave ARP 2600EX, Broadwave 18U ARP based Eurorack Modular, Broadwave Minimoog Clone, GEM S2 Turbo.
Synth DIY Projects
Musical Doodlings |
Pehr
Joined: Apr 03, 2004 Posts: 24085 Location: The Netherlands, Enschede
Audio files: 278
Posted: Mon Oct 22, 2007 9:35 am Post subject:
This is based upon the Nord Modular G2 synth, but it might still be of interest as a general source of knowledge about synthesis. To experiment with it you could download the free G2 emulator software from the Clavia website (here), for Windows and for OSX. _________________ Jan
Broadwave
Audio files: 6
Posted: Tue Oct 23, 2007 7:30 am Post subject:
Hi Jan, thanks for the link, very useful info..
I bought a G2 Engine about 3 months ago, but not had the time to really get into it since I started building my modular.
Anyway... back to that syncing feeling!
I did some digging around Ray's site and found all the info on his previous VCO designs, including some recommended mods.
His older designs (http://www.musicfromouterspace.com/analogsynth/August2003VCO.html) have a dedicated sync output taken directly from the integrator pulse (is that the correct technical term?), which is very similar to the ARP Odyssey, which seems the obvious way to go.
There is also another design (http://www.musicfromouterspace.com/analogsynth/VCO200503REV01/tomandianssuggestions.html) where Ray has some recommended mods suggested by Ian Fritz and Tom Arnold... including sync modifications - quote "the hardest sync you'll ever hear", although I don't understand why Ray didn't incorporate this mod in his current design.
As soon as I get home, I'll give it a go and report back. _________________ Kronos 2-88, Kronos 61, Studiologic Sledge V2/SL, Broadwave ARP 2600EX, Broadwave 18U ARP based Eurorack Modular, Broadwave Minimoog Clone, GEM S2 Turbo.
Synth DIY Projects
Musical Doodlings |
Broadwave
Audio files: 6
Posted: Wed Oct 24, 2007 7:56 am Post subject:
Hi all,
Followed the instructions for the Fritz/Arnold mods... The sync is great!!! Exactly what I was looking for.
BUT, I now have problems with the pulse width side of things - all sorts of clicks and pops, and the oscillator stops if the initial frequency is taken too high!! GRRR!!!!!
I'm hoping it's all down to the changes I made in the "ref section" of the integrator i.e. removing C8 and exchanging a resistor for a diode, changing the integrator cap from 1n etc.
Will put that section back to what it was, but keep the sync mod in, if I can.
Getting there, but very slowly. _________________ Kronos 2-88, Kronos 61, Studiologic Sledge V2/SL, Broadwave ARP 2600EX, Broadwave 18U ARP based Eurorack Modular, Broadwave Minimoog Clone, GEM S2 Turbo.
Synth DIY Projects
Musical Doodlings |
Pehr
funkyfarm
Posted: Wed Nov 07, 2007 6:58 am Post subject:
Can anyone tell me which is the best waveform to sync vco ?
I remember once using square but I was told (maybe by Tony Allgood, about his OAKLEY 1o3 VCO) that sawtooth were better for that...
So, you'd vote for falling ramp sawtooth, triangle, pulse or sinewave ?
I guess it has to have sharpen edges... |
Broadwave
Audio files: 6
Posted: Thu Nov 08, 2007 4:27 am Post subject:
Pehr, Glad I've been of some use - it's always nice to give back to the community
Funkyfarm:
As far as the sync signal is concerned, I've always used Square/Pulse on the MFOS Oscillators - I've got a feeling that the sawtooth output on these oscs are actually ramp so not good as a sync source (I may be wrong, but I'm on vacation 7,000 miles away from home, and can't verify that for you at the moment).
Synth DIY Projects
Musical Doodlings |
Pehr
Pehr
loss1234
Posted: Wed Apr 02, 2008 5:20 am Post subject:
i'm confused. i have one of the newer mfos vco's where it looks like the diode mod and a few others have been implemented. BUT the sync is still very weak. So i am wondering, which mods should I do? just the cap size or are there other mods that Ian recommends? there are so many mods listed on rays site that some of them cancel each other out and i dont want to mess up my vco which is almost fine except for the sync
thanks _________________ -------------------------------------------- check out various dan music at: http://www.myspace.com/lossnyc
http://www.soundclick.com/lossnyc.htm http://www.indie911.com/dan-snazelle |
Pehr
loss1234
Posted: Wed Apr 02, 2008 10:12 am Post subject:
replaced the cap
sync now seems to work pretty good at some tune knob settings...its not as thick as my ken stone vco and it seems to act weird if you dont get the knob setting JUST right but,,,better than what it was before. i also followed the advice of Ian and put in the opa2134 (Sp?) and to change the integrator cap to a 103 styrene...and to change the ref cap as well. i am now tracking the whole keyboard...awesome!!
j.dilisio
Posted: Thu Jun 11, 2009 8:07 am Post subject:
it's a good thing I found this thread.
I was just getting ready to order 2 of these vco's.
I can hear from the sample on MFOS that the sync sounds a little rough and jumpy.
Is there any way someone could upload a sample that demonstrates the sync after changing the cap? |
Argitoth
Joined: Jun 24, 2008 Posts: 152 Location: Gilbert, Arizona
G2 patch files: 6
