MXR Phase 100 Repair
Page 1 of 1 [19 Posts]
PostPosted: Tue Dec 18, 2007 6:11 pm    Post subject: MXR Phase 100 Repair Reply with quote  Mark this post and the followings unread
I've got this MXR Phase 100 which I'm fixing for a client, (yes, I'm tempted to say "Oh,.... parts ar bastard, can't be fixed" Wink ) But one of the most important things in business, as far as I'm concerned, is honesty.
So,
There's no phasing effect, but power etc. checks out good. It's driven by 3 * VTL5C3/2s, and powered up, I've got the voltage across two of the LEDs floating around 1V, and the third is pretty static up at about 5V.
The third one is cactus hey?
Can I test it by putting a standard LED into that position and get a partial effect happening?
You can find the schem here:-
http://www.generalguitargadgets.com/pdf/ggg_p100_sc.pdf
But I'm figuring there are a couple of people around here who know a thing or two about VTLs Wink
How hard are they to get? I can't get them here in Australia at all.
Thanks all for any help I can get.
Andrew
Scott Stites
Audio files: 96
PostPosted: Tue Dec 18, 2007 7:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would think it would at least tell you something. Can you tell if the LFO is working?
Yes you can. Wink
My Site
moran514
PostPosted: Tue Dec 18, 2007 7:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
you might want to try to ask about this on http://www.diystompboxes.com/smfforum
View user's profile Send private message AIM Address MSN Messenger
PostPosted: Tue Dec 18, 2007 9:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm pretty sure the LFO is working, because the 1V across the other two slides up and down by about 0.3V when I set the speed to slowest, and sits steady at half that when the speed is up.
Are you inferring that I might be able to get them added to my MPS proto package Mr Stites? For a pre-determined sum this time I hope. Very Happy
I'll try the LED substitution and see what happens. I could always roll my own Vactrol I s'pose. I'm sure I've got a rough one around here somewhere.
PostPosted: Wed Dec 19, 2007 6:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I put the LED in, and it just glowed consistently. No sign of any phasing effect. Then I touched the trimpot, and noticed the LED dim somewhat, and, yes, it was pulsing! I had a listen, and there was phasing. I re-installed the vactrol, and,......... nothing.
So, the moral of the story is. Don't go looking for a fault. Explore, and be prepared to find two. Wink
Yes, I think I need some vactrols Scotty! I'll be in touch. Smile
Scott Stites
Audio files: 96
PostPosted: Wed Dec 19, 2007 11:05 am    Post subject: Reply with quote  Mark this post and the followings unread
Righto.
My Site
PostPosted: Wed Dec 19, 2007 1:50 pm    Post subject: Re: MXR Phase 100 Repair Reply with quote  Mark this post and the followings unread
These are the 'double type' vactrols right? 2x LDR in a single case? Because I too have had terrible trouble trying to get my hands on these in the UK. I assume it's just as bad in Aussie?
anyone got any suggestions?
You Americans have it so cushy! Evil or Very Mad Wink
ACHTUNG!
StephenGiles
PostPosted: Wed Dec 19, 2007 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.4shared.com/file/32516286/22128833/mxr110.html
This is the factory schematic for the MXR 110 which was apparently a revised model that never reached the factory, but not much different from the MXR 100.
PostPosted: Wed Dec 19, 2007 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Stephen.
I'm thinking about building one now.
Scott Stites
Audio files: 96
PostPosted: Wed Dec 19, 2007 9:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
It only takes 16 VTL5C3/2s to do this kind of stuff to a purposely dull DW6000 voice. All modulation, gooey stretching, warbling, and other mayhem in this sample is done by the Multiphase - remember that? The boards are patiently waiting a home behind a rack panel.
You're tempting me to go get back to it.... Laughing
xgen_snippets.mp3
Memories from the Multiphase
 Filename:  xgen_snippets.mp3
 Filesize:  3.46 MB
 Downloaded:  967 Time(s)
My Site
PostPosted: Thu Dec 20, 2007 4:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I take it then that you can lay your hands on these types then Scott?
Next time you order some, can you order some for us- and I'll paypal you or whatever?
:grovel: !
ACHTUNG!
germaniac
PostPosted: Thu Dec 20, 2007 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Private STITES! Front and center! What do you think you're doing lollygagging around here? Get back to work on the Multiphase PDQ! That's a DIRECT ORDER! salut
(Thanks for the snippets, I had forgotten how really incredible that thing sounds. . . . )
Scott Stites
Audio files: 96
PostPosted: Thu Dec 20, 2007 11:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Yessir! I'd all but forgotten about it, and I happened across some samples on the hard drive.
I've got two of these boards built - it'd be a shame to waste so many VTL5C3/2s!
Tom - my purchasing power has been curtailed for the immediate future (right at the time all of these awesome JH boards are coming out Evil or Very Mad ), but when things pick up, I'll be sure to grab you some. I have a few in my larder; those I should send to Andy so he can get that Phase 100 up and running.
Cheerios,
Scott
My Site
TheAncientOne
PostPosted: Thu Dec 20, 2007 11:48 am    Post subject: Re: MXR Phase 100 Repair Reply with quote  Mark this post and the followings unread
Bridechamber sell them, are quite fast and a good price - I got the standard ones for my wogglebugs from them.
http://www.bridechamber.com/
In the UK, Pacer are the distributers. I bought my first batch there.
http://www.pacer.co.uk/jkcm/default.aspx?pg=116&path=213
They have a minimum order of £15 plus VAT.
If you only need one or two, pm me.
Mike
Mike
Clack
PostPosted: Thu Dec 20, 2007 12:10 pm    Post subject: Re: MXR Phase 100 Repair Reply with quote  Mark this post and the followings unread
Maybe its time for another group order of them for people in the uk? I certainly would like to get my hands on a few more - I managed to get 2 of the last person who group bought cos I missed it - forgot his name. Lots of great vactorial projects out there
i'll sort it out
Clacktronics.co.uk
EdisonRex
Audio files: 172
PostPosted: Thu Dec 20, 2007 2:19 pm    Post subject: Re: MXR Phase 100 Repair Reply with quote  Mark this post and the followings unread
i'll sort it out
I would participate in a group buy. Are you volunteering to coordinate? Idea
Garret: It's so retro.
PostPosted: Thu Dec 20, 2007 2:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
No, don't worry Scott. I'm already in the middle of a bit of home surgery on this one, and I think she's gonna pull through! Laughing
However, I might be interested in the future. How many are there in a multiphase? Laughing
I actually ordered a load of high brightness yellow LEDs so I could start rolling my own. I've been collecting a big pile of LDRs too. Now I've seen inside this Vactrol I'm quite sure I can make (almost) exact copies.
PostPosted: Fri Dec 21, 2007 5:53 am    Post subject: Re: MXR Phase 100 Repair Reply with quote  Mark this post and the followings unread
You decent chap! Thanks Mike Very Happy
ACHTUNG!
PostPosted: Fri Dec 21, 2007 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
cheers as well Scott Smile
ACHTUNG!
