5-channel Attenuverting AC/DC Mixer PROFESSIONAL PCBs
Page 6 of 7 [162 Posts]
PostPosted: Thu Jan 24, 2008 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
still got a view boards left. anybody?
bugfight
PostPosted: Thu Jan 24, 2008 12:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'll take a couple
julianw
PostPosted: Sat Jan 26, 2008 6:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey, I'll take 2 if they are still available, have PM'd you.
Cheers Julian
PostPosted: Sun Jan 27, 2008 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
SOLD OUT.
thanks guys. hope you'll have fun with it. i do.
Luka
PostPosted: Sun Jan 27, 2008 8:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
hey matthias
were the headers used in this module bought from futurlec?
http://www.futurlec.com.au/Connectors/POLHDCON2.jsp
http://www.futurlec.com.au/Connectors/POLHDCON3.jsp
luke
problemchild
melbourne australia
PostPosted: Mon Jan 28, 2008 12:15 am    Post subject: Reply with quote  Mark this post and the followings unread
hi luke,
no, i bought them at a german online store... but they look almost the same.
for the manufactured PCB you would need headers that could be put in line, just like the ones from rs-components i mentioned earlier in this thread.
Luka
PostPosted: Mon Jan 28, 2008 12:41 am    Post subject: Reply with quote  Mark this post and the followings unread
ok cheers for that
i found some really cheap ones on ebay
but they do look neat
but cant go past 7cents a piece, even if they wont fit the pcb exactly
problemchild
melbourne australia
mono-poly
PostPosted: Mon Jan 28, 2008 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Do another run Smile
sneakthief
PostPosted: Mon Mar 10, 2008 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'll take one if you do another run!
Sneak-Thief - raw electrofunk
Danno Gee Ray
PostPosted: Mon Mar 10, 2008 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
I would be in the market if you do another run.
ericcoleridge
PostPosted: Mon Mar 10, 2008 10:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd sign up for at least 2, and maybe 3 or 4, if there is another run. I had too many other projects going on when the first run was made. I've been regretting it since because I could use bunch of these now.
PostPosted: Tue Mar 11, 2008 4:40 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you so much, boys. Very Happy
there won't be a 2nd run in near future, though. i want to encourage everyone to do it on proto- or stripboard instead, since this is an easy low part count circuit and you could modify it to your very own purposes.
sneakthief
PostPosted: Tue Mar 11, 2008 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
oh well... if anybody has an extra one, i'll gladly take it off your hands.
norman phay
PostPosted: Wed Mar 26, 2008 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
OK, I just about finished building up these things, had to grind the connectors down on a sheet of emery paper because I didn't read the thread w/r/t the little plugs being close together, I am an idiot ::rollseyes.gif::
A question though - does anyone have a link/location for 50K pots with a centre detent, like the balance knob on a stereo? It would be cool to have these if possible.
Thx.
BananaPlug
PostPosted: Wed Mar 26, 2008 4:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just thought I'd share this layout idea for a normal-less banana plug Frac rack version of the mixer.
I added a sixth input (aux in) with no scaling. Aux in and channel one are always in the mix out and toggle switches allow adding a couple more channels to the mix.
I hardly ever need to mix 5 CVs together and this provides several useful configurations.
 Filesize:  22.77 KB
 Viewed:  7273 Time(s)
norman phay
PostPosted: Thu Mar 27, 2008 5:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Found 'em. Mouser has them, I typed "50k pot center" into their search window and got a hit.
Usine Karate
PostPosted: Wed Apr 02, 2008 12:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello, quick question, I was just wondering if I could use 47K lin pots instead of 50K? Much easier to get for me, but would it affect the circuit?
I'm sure I've read somewhere that they are practically the same...
Any help will be most appreciated!
BananaPlug
PostPosted: Wed Apr 02, 2008 12:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't think you'll notice the difference. Pots are not terribly accurate to begin with.
Usine Karate
PostPosted: Wed Apr 02, 2008 2:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks BananaPlug, I'll get 47k... Smile
PostPosted: Wed Apr 02, 2008 11:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
i did no measures myself but the mouser catalogue states a +/-20% tolerance for 16mm alpha potentiometers Shocked
to partly balance this i implemented the trimmers.
Peake
PostPosted: Sat Apr 05, 2008 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello, I've missed out on the initial order. If anyone has one, two, three or more boards available for purchase or trade, please PM me. Thanks.
Pehr
PostPosted: Sat May 24, 2008 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
he he. an attenuverter gives both: attenuation of the original and the inverted signal. say pot in middle position: no signal, pot clockwise: original signal, pot counterclockwise: inverted signal. in other words: each channel allows you to invert and/or attenuate the signal...
I don't really get this from your schematic. It looks like the signal is just attenuated, inverted and then mixed, right?
EDIT: No, wait! now I get it Razz
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
PostPosted: Sat Jul 12, 2008 5:35 am    Post subject: interest in a 2nd run? Reply with quote  Mark this post and the followings unread
some people asked for this. so if there would be enough interest i could do a 2nd run.
50 PCBs would be enough for me to start it.
again, this is a simple but nevertheless very useful and versatile module. it is a nice project for beginners as well (as long as they are already in possess of a modular Wink )
so what do you think?
asafnetzer
PostPosted: Sat Jul 12, 2008 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Two for me, maybe more.
Thanks for this 2nd run offer,
Best regards,
Asaf
crashlander42
PostPosted: Sat Jul 12, 2008 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd take two. I've regretted not getting in on the first run.
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
