Inventor
Audio files: 267
Posted: Wed Mar 26, 2008 1:43 am Post subject:
Nicely done, Frostburn, I enjoyed the sound sample and the code looks very well written as is your usual style. Now along the same lines, I am wondering if we can use this DigitalTape class to create songs such as this one by Amy X Neuburg:
http://amyxneuburg.com/sound/tattoo.seg.mp3
It has a vocal track that you can discern, and underlying that is noisy stuff that sounds somewhat like grains of the vocal track. I think it's really samples of other singing, but we could approximate that with grains.
I'm thinking that a ChucK program could record the vocals and then construct that underlying grainy chaos from the recording. The program could construct many layers of granularity, or really a continuum of granularity from fine to coarse simultaneously. We would then have the ability to automatically generate this kind of song from any vocal track.
That could be a very effective music creation tool. Just sing the lyrics and a complete enjoyable song is automatically generated by ChucK.
In addition to vocals, it might work well using a single instrument as the source, such as a sequence from Guitar Lab. Create one good musical track of any single source and out pops a finished song.
I may give this a try if you or kijjaz don't feel so inclined, what do you think? |
Frostburn
Audio files: 9
Posted: Wed Mar 26, 2008 12:11 pm Post subject:
My few experimentations with DigitalTape suggest that it is some kind of a super filter. It can do flanger, reverb, time dilation, scrathing... Well pretty much anything and even some more.
I've added cubic interpolation and better loop control for DigitalTape but there are some nasty bugs related to the new system that I've yet to catch.
I'll be posting when it's ready. _________________ To boldly go where no man has bothered to go before. |
kijjaz
Joined: Sep 20, 2004 Posts: 765 Location: bangkok, thailand
Posted: Wed Mar 26, 2008 12:28 pm Post subject:
This turns out to be very general as i expected.
Soon we'll have many read and write heads flying around,
creating some monster machine hahhaha -_-"
I wanna try one take with the idea also.
i'll try to make something that sounds different in character. |
Frostburn
Audio files: 9
Inventor
Audio files: 267
Posted: Wed Mar 26, 2008 3:14 pm Post subject:
Very cool, guys. Now I want to write a signal control interface for it and plug it into Synth Lab. I'll wait and see what you do with it first, though. _________________ "Let's make noise for peace." - Kijjaz |
quintopia
Inventor
Audio files: 267
Posted: Wed Mar 26, 2008 8:34 pm Post subject:
How interesting. I'd like to hear it but it won't run on my miniAudicle or on the command line version for some reason. It looks like an interesting song, but it won't run. Can you post an mp3? _________________ "Let's make noise for peace." - Kijjaz |
Inventor
Audio files: 267
Posted: Wed Mar 26, 2008 8:56 pm Post subject:
I was just looking over the DigitalTape class, and I think there is a good way to hook it up into Synth Lab. I have already established floating point input and output from between the analog signals and thet methods of a class. It's just a $ int cast to add integer capability. Plus I have already established logic levels for receiving bits from analog signals. I can just add an input node slider or two for each function call and an output slider for each return value. Hmm... it would be a good idea to have this in Synth_Lab, so I think I will do it. _________________ "Let's make noise for peace." - Kijjaz |
quintopia
Inventor
Audio files: 267
Posted: Thu Mar 27, 2008 8:22 am Post subject:
Well, iti was OK. I liked the music at the end best. It's a good example of granular synthesis as I understand it to be, where you have shredded up the sound at the beginning into smithereens. That is kind of cool in a way. The only problem I had was the tweedling sound that exists somewhat at the beginning and especially in the middle such high pitched sound hurts my ears, but that's my limitation not yours. My ears hurt when women shout for example. Might be better with lower frequencies I guess. _________________ "Let's make noise for peace." - Kijjaz |
Frostburn
Audio files: 9
Frostburn
Audio files: 9
Posted: Sun Mar 30, 2008 8:17 am Post subject:
I added anti aliasing cosine interpolation to the reader but I'm still pondering on how to implement it on the writer side...
Description: |
Letting a write head and a read head roam freely on a piece of Digital Tape. |
Download |
Filename: |
digitaltape.mp3 |
Filesize: |
208.88 KB |
Downloaded: |
753 Time(s) |
Description: |
Digital Tape version 0.2 beta |
Download |
Filename: |
digitaltape.ck |
Filesize: |
33.58 KB |
Downloaded: |
316 Time(s) |
Inventor
Audio files: 267
Posted: Sun Mar 30, 2008 9:08 am Post subject:
Wow that mp3 was awesome, It seems like a very professional effect. I tried to get the example to work by removing the /* and the */ plus putting a digitaltape.wav file in the samples directory but it only made silence. Not sure why that was, but I'll mess with it to try to make it work. It was running though, because it slowed my computer down to the point where the mouse was jumping when I moved it. _________________ "Let's make noise for peace." - Kijjaz |
Frostburn
Audio files: 9
Posted: Sun Mar 30, 2008 9:57 am Post subject:
Inventor wrote: | It was running though, because it slowed my computer down to the point where the mouse was jumping when I moved it. |
Yeah... High quality antialias and cubic interpolation require an insane amount of floating point operations for ChucK to handle. It would propably be 50 times faster if it was written in C++.
Try writing the output to a file and run chuck with --silent.
It a does make sound file here when I copy/paste it to a new .ck file and uncomment Code: | Impulse impulse => dac => WvOut wvout => blackhole; "foo.wav" => wvout.wavFilename; |
EDIT: And everyone's free to try it out and experiment. Please report poor documentation and bugs. Questions are welcome. _________________ To boldly go where no man has bothered to go before. |
kijjaz
Posted: Sun Mar 30, 2008 11:17 pm Post subject:
wow.. the sound quality of the above example is great. it's clear and warm. i like it.
i'm still roaming around northern part of Thailand and still don't have time to play with your digital tape. -_-"
it's so exciting... |
Inventor
Audio files: 267
Posted: Sun Mar 30, 2008 11:56 pm Post subject:
I hope you're having fun roaming about Thailand, kijjaz! _________________ "Let's make noise for peace." - Kijjaz |
Inventor
Audio files: 267
Posted: Mon Mar 31, 2008 12:21 am Post subject:
As for DigitalTape, I appreciate your efforts to make it a high quality audio tool, but it's just plain unusable on my old Mac. I let it run for five minutes each on miniAudicle and command line ChucK with --silent, and no sign of completion. It did produce a 26-second output file, but it was inaudible. DigitalTape will just have to wait until I get a faster machine, which is not soon. _________________ "Let's make noise for peace." - Kijjaz |
Inventor
Audio files: 267
Posted: Mon Mar 31, 2008 1:31 am Post subject:
Oh, and um, I don't intend the above post to be taken the wrong way. We're all pushing the limits of ChucK in various ways including CPU usage as we explore what we can do with this awesome tool. LiSa and SndBuff will have to do if you haven't got the oomph to run DigitalTape, I guess is the story. _________________ "Let's make noise for peace." - Kijjaz |
Frostburn
Audio files: 9
Posted: Mon Mar 31, 2008 5:25 am Post subject:
Yeah, I totally understand.
Working with Digital Tape as it is requires patience and a good cooling system. I cannot do anything about that. You can try running everything with 0 => myDigitalTapeWriter.interp => myDigitalTapeReader.interp; but it's still too slow for realtime on most machines. Doing advanced stuff in ChucK that requires sample precission and a lot of operations will always be out of the reach of live gigs and impatience. (unless ChucK gets super optimized all of a sudden)
Maybe one day I'll port it to ChucK on the source level and then it'll become usable. No promises though. :)
Inventor wrote: | It did produce a 26-second output file, but it was inaudible. |
That's odd.
Oh well, next time I make an example I'll try to keep it simple and independant of external .wav files. _________________ To boldly go where no man has bothered to go before. |
kijjaz
Posted: Mon Mar 31, 2008 1:11 pm Post subject:
Inventor: Or the example needed to be run at an exact sample rate..? 44,100hz? |
Inventor
Audio files: 267
Posted: Mon Mar 31, 2008 2:17 pm Post subject:
kijjaz wrote: | Inventor: Or the example needed to be run at an exact sample rate..? 44,100hz? |
Yep, ChucK is running at 44,100 Hz on this machine... _________________ "Let's make noise for peace." - Kijjaz |
Frostburn
Audio files: 9
Posted: Mon Mar 31, 2008 2:19 pm Post subject:
ChucK has a default sample rate of 48,000 when running JACK. That's what I used. _________________ To boldly go where no man has bothered to go before. |
kijjaz
Frostburn
Audio files: 9
Posted: Mon Mar 31, 2008 3:34 pm Post subject:
Oh ok. That example sounded like cutting tape in to pieces and splicing them back together after a good shake. Except it was more crazy and digital sounding. I liked it!
However to me digital means high quality and tape brought up the idea of a looped medium to work on. The sense of unviolatible topology in me wouldn't have dared to cut such a pretty picture in to separated individual grains. There must be continuity and preferably smoothness (differential continuity).
But now that I think about it. Tape fits better in with the grainy splicy idea. While turntable would fit my approach.
I think I'll change the name in to DigitalTurntable so that you can use Digital Tape.
Of course you can break the sound buffer in to grain fragments with my classes but my intention is to create an abstract turntable with read and write heads that is not bound by the limits of time. (Only by the limits of processing power and available data). And the main focus is on quality instead of lightness so it's better/only suited for audio rendering than live performance. _________________ To boldly go where no man has bothered to go before. |
Inventor
Audio files: 267
Posted: Mon Mar 31, 2008 3:40 pm Post subject:
Woah, take me to your leader! That sounds like a professional quality recording done for an electromusic track. It made a similar impression as Frostburn's mp3 - well done! It evan ran on my klunky old machine, wow. _________________ "Let's make noise for peace." - Kijjaz |
