Wild Zebra
Posted: Fri May 30, 2008 8:18 am Post subject:
What passive modules can I make??? |
Hello Hello it's been awhile I've definately been reading man it's hard to keep up. Other hobbies have me busy right know, but I have been slllooooowwwwllly but surely working on a modular I started in an old speaker cab and it's almost done. I'm looking for some easy, boring, but useful passive modules. I already made a 4 passive attenuator module and I'm getting ready to make a mutiple (any tips for the multiple) how may is too many, whats not enough??? I thought about a few sets of 4?? Anyway what other modules can I make?? I have space for like two more and I'm trying to decide if I should make another cool module or fill it with some passive stuff that I'm overlooking. Pics soon. The backlog is growing. _________________ "your stripes are killer bro" |
numbernone
Joined: Aug 16, 2006 Posts: 477 Location: new york city
Posted: Fri May 30, 2008 8:35 am Post subject:
Being a bananaman I cant say I have any use for mults, however I would say look at Scott Stites' mother of all mults. IT IS WAY COOL. |
Pehr
Joined: Aug 14, 2005 Posts: 1307 Location: Björkvik, Sweden
guitarfool
Wild Zebra
Posted: Fri May 30, 2008 9:10 am Post subject:
Sweet keep em coming. Man I have a Passive RM in my Sound Lab and I just ordered from Mouser I should have ordered some transformers to make another argh. I'll definate have to throw one in there. _________________ "your stripes are killer bro" |
GlassX
Posted: Fri May 30, 2008 9:53 pm Post subject:
JFET Buffers aren't passive, but are just one transistor and one resistor, so you don't need circuit boards.
You can also build passive Min/Max (or Peak/Through) modules with one diode for each input and one resistor, plus a Buffer...
(see http://www.musicfromouterspace.com/analogsynth/mmlogic.html ) |
Joined: May 16, 2005 Posts: 8933 Location: Birmingham, England, UK
Posted: Sat May 31, 2008 12:26 am Post subject:
Hey Zeb! Been a while!!
Howabout a potential divider between -15v and +15v, with a pot in the middle? Some wild sweeps can be achieved here. This, although really simple can yield some wild sounds when feeding oscillators into ringmods.
-Original idea btw, from my old Korg MS-50. Oh I miss her! _________________ ACHTUNG!
Posted: Sun Jun 01, 2008 2:21 pm Post subject:
You folks should be reading this too;
http://electro-music.com/forum/topic-26450.html
Pehr
RF
Audio files: 28
Posted: Mon Jun 02, 2008 4:40 am Post subject:
Re: What passive modules can I make??? |
fonik wrote: |
what i did was to add a switch to link multiples. this way i can choose to have 2x 4 multiples or 1x 8 multiples... |
I don't recall where I saw it - but if you replace the fourth jack from the top with a switching jack you could eliminate the switch. When you plug into the fourth, it automatically switches in the next four...
bruce |
Posted: Mon Jun 02, 2008 4:54 am Post subject:
RF wrote: | fonik wrote: |
bruce |
indeed, but i would not have two independent 4xmultiples. just one 3x and one 4x. matter of taste, i guess.
or what about the other way round? disconnect two 4x multiples as soon as you plug IN the 4th of the 1st multiple? then we had either two independent 4x multiples or one 7x multiple. this would make more sense to me, since i very seldom use the 8x multiple and 7x would be enough for me at least. good idea. _________________
Tech Buddy at Random*Source |
Wild Zebra
Posted: Tue Jun 03, 2008 8:35 am Post subject:
Hey thanks everyone, It has been awhile thanks for all the ideas hopefully I'll be done soon and post pics, not much to look at for the amount of time it's been. _________________ "your stripes are killer bro" |
Posted: Tue Jun 03, 2008 8:41 am Post subject:
guitarfool wrote: | There's always the simple (but very useful) passive filters from the Moog modular. |
If a dual-gang pot was to be placed where the 10k resistors are, would an all-pass or bandpass filter be created? _________________ ACHTUNG!
zthee
Posted: Tue Jun 03, 2008 11:05 am Post subject:
numbernone wrote: | ..I would say look at Scott Stites' mother of all mults. IT IS WAY COOL. |
Where can I find info on the mother of all mults? |
RF
Audio files: 28
Posted: Tue Jun 03, 2008 6:06 pm Post subject:
from http://mypeoplepc.com/members/scottnoanh/birthofasynth/index.html
<SNIP>
M.O.M. (Mother Of all Mults)
45 connectors in three columns of 15. Every five connectors in each column are conneted together. The fifth connector of each section is normalled to the section below it.
</SNIP>
That's all I see..... |
guitarfool
Posted: Tue Jun 03, 2008 6:51 pm Post subject:
v-un-v wrote: | guitarfool wrote: | There's always the simple (but very useful) passive filters from the Moog modular. |
If a dual-gang pot was to be placed where the 10k resistors are, would an all-pass or bandpass filter be created? |
You can get a bandpass type filter by using the two in series. I suppose you could use a ganged switch, but it would be more flexible as-is. As for substituting the 2 10k resistors with a dual pot - try it |
shebb
Posted: Wed Jun 04, 2008 9:54 pm Post subject:
a ring mod can be made with schottky diodes like bat43, I made one from the ken stone site's schematic with radio shack audio transformers, and it took about 5 minutes! it sounded good tho |
doctorvague
Posted: Thu Jun 05, 2008 8:00 am Post subject:
Here's my 'Two Simple Filter'. Parts count: 2. The NSL mp3 uses a NSL-32SR3 and other mp3 is using a VTL5C3. Lacking vactrols you can always use an LED and photocell. You can also put 2 vactrols in series, parallel and of course try different cap values, or use a rotary switch to switch between caps (increases parts count tremendously, though)
Sorta works like a VCA with no cap at all: Parts Count: 1
I only feed the CV input with positive voltages, like an envelope and haven't blown up a vactrol yet.
Phil
Description: |
Filesize: |
16.4 KB |
Viewed: |
61591 Time(s) |
Description: |
Download |
Filename: |
Two_Simple_Filter.mp3 |
Filesize: |
233.47 KB |
Downloaded: |
2152 Time(s) |
Description: |
Download |
Filename: |
Two_Simple_Filter_NSL.mp3 |
Filesize: |
219.18 KB |
Downloaded: |
1945 Time(s) |
Wild Zebra
Posted: Thu Jun 05, 2008 9:52 am Post subject:
Sweet well I just made a simple multiple with 4 rows of 5 each, hope that does the trick for now and I decided to try and put a delay in there. Just so you all know the danelectro Slapback can be modified for full on feedback and delay times and they will run in 12V. Sweet! So I'm going to build a simple true bypass do the mods and slap it in there soon. Then I have a tiny bit more room maybe a ring mod will fit. Then pics will come. Thanks Y'all!! _________________ "your stripes are killer bro" |
Tim Servo
Joined: Jul 16, 2006 Posts: 924 Location: Silicon Valley
Posted: Thu Jun 05, 2008 11:41 am Post subject:
Hey Dr. Vague,
NICE! I think you win the prize for Simplest VCF... EVER! Also, they sound pretty good. You might even try putting two or three different units in parallel. Drive them from the same envelope, and due to the slightly different response times (the NSL sounds a little faster and snappier, while the VTL sounds a bit slower and more "vactrol-like"), you would get an interesting sound. I think. Anyway, thanks for sharing that!
Tim (definitely a bit slower) Servo |
doctorvague
Posted: Fri Jun 06, 2008 4:45 am Post subject:
Tim Servo wrote: | Hey Dr. Vague,
LOL I challenge anyone to come in with a lower parts count passive VCF! Or should it be "VCF" in quotes? It is a filter and it's technically voltage controlled...
Tim - or anyone -Is there a way to chain these without active buffer stages in between? I was never able to figure out a way. I tried opamp buffers between stages but it didn't sound the same. I do like really passive kinds of filters like this though, and would like to do what you said - somehow figure out how to chain 3 or 4 of them. I have another filter that uses 3 different kinds of vactrols (2 at one time and another one switchable) that takes advantage of different vactrol characteristics, as you touched upon, but that's OT for this thread.
Phil |
Posted: Fri Jun 06, 2008 5:17 am Post subject:
Awesome!
I wonder if you could introduce feedback into the circuit via a pot (or even a vactrol???)
Very cool. very cool indeed (not even I have an excuse not to build one!) _________________ ACHTUNG!
doctorvague
Posted: Fri Jun 06, 2008 5:48 am Post subject:
v-un-v wrote: |
Awesome!
Very cool. very cool indeed (not even I have an excuse not to build one!) |
Without some of kind of summing, any attempts to introduce feedback would simply short the input and output, yes-no??
Feedback was always the big challenge on the other 3 vactrol filter I was talking about, too, which was an offshoot of Scott Stites Mutant vactrol which was an offshoot of a Buchla design. Off-shooting reigns supreme...
It kinda goes without saying, but of course you can add a standard 2 transistor convertor CV circuit in front of the CV input which works well and evens out the CV response to something resembling an actual filter, and doesn't affect the audio path.
Of course my electronics knowledge fits neatly into a thimble as you can probably tell!
Edit: A good variation of this is to use 2 vactrols, putting the LED's in series and the resistive sides in parallel. |
Posted: Fri Jun 06, 2008 6:12 am Post subject:
doctorvague wrote: |
yep that would make sense.
A diode in the chain? would that help at all?
I'm trying to balance electronics with architectural visualisation (don't ask ). Perhaps I should be the vague one? _________________ ACHTUNG!
