crashlander42
Joined: Oct 21, 2006 Posts: 292 Location: Orlando, FL (US)
Posted: Sun Aug 31, 2008 12:58 am Post subject:
Polivoks filter |
I breadboarded the Polivoks filter tonight using the schematic form http://m.bareille.free.fr
I like it a lot. It reminds me of the MS20 filter clone with the input gain turned down, but when you turn the input gain up there's magic. It turns into a nasty evil distorted beast. It has that crazy squelchy resonance that the MS20 dies when it's turned to max. I'm definitely putting this together on veroboard tomorrow.
Here's a video of my trial run. I crank the gain about 1/3 of the way through and crank the resonance at the end.
http://www.youtube.com/watch?v=3ZypalMfkFI
I'm curious if anyone else has built this and if theirs sounds similar. I used the UA776 and UA741 in mine, if that makes any difference _________________ When they plug me in the lights go down in Hong Kong.
http://www.myspace.com/isaciongun
http://www.youtube.com/user/Crashlander42
My DIY stuff Flickr |
Funky40
G2 patch files: 5
Posted: Sun Aug 31, 2008 4:31 am Post subject:
it sounds good your one.
I think better than my one. But i have unfortunately no input attenuation which is higly recommended.
Then it's also recommended to build with The UA776 ( i just know this, never got the LM4250. but everybody who has compared them says the same )
and i then would recommend to build it with a Outputmixer stage,
but this might be a thing of personal taste.
I use my Polivoks mostly in BP mode, but mix sometimes some LP to it.
But sometimes when jamming with a sound i twiddle around with the mixer.
so i have allways a mixer next to the Polivoks and the polivoks patched by default to it
shit, i shoulda make a friendship with the Breadbord too.
Nice setup you have !
check good the Range of the CV input pots if you have not.
they may need some adjustment. On my filter it is really bad.
edit:
my old thread:
http://www.electro-music.com/forum/topic-13248.html
the demo is made without any input attenuation.
the module on the left is akllways in use. THATS my polivoksfilter
the one on the right is in frac format, but i have no fracrac still today
I'm on the way to repanel them. i make a dual Polivoksfilter.
But i'm not shure if i should make a new panel as i have allready more Ideas. |
crashlander42
Posted: Mon Sep 01, 2008 12:18 pm Post subject:
I lucked out on the UA776's. My local surplus store had some. I used attenuators on my inputs, which makes a huge difference. It also amazes me the range of different tones you can get just from adjusting your input levels.
I like your layouts. The bandpass filter on this thing sounds awesome. I have plenty of mixers, so I didn't do an output mixer. I nearly gave it the same panel I did for the MS20 clone.
Here's my panel. I know it's a little jagged, but I cut it with a jigsaw. I need to get to a table saw to cut some more blank panels.
Here's a picture of the vectorboarded (stripboard, veroboard, whatever it's called) Polivoks as well. I was pretty pleased with my work.
| Description: |
| Here's my Polivoks panel. I know it's a little jagged, but I cut it with a jigsaw. I need to get to a table saw to cut some more blank panels. |
| Filesize: |
95.74 KB |
| Viewed: |
505 Time(s) |
| Description: |
| Here's a picture of the vectorboarded (stripboard, veroboard, whatever it's called) Polivoks as well. I was pretty pleased with my work. :D |
| Filesize: |
105.34 KB |
| Viewed: |
552 Time(s) |
Funky40
G2 patch files: 5
endif
haxster
Joined: Feb 01, 2006 Posts: 246 Location: MONTEREY PARK, CA 91754
Posted: Sun Dec 07, 2008 4:28 pm Post subject:
I recently have been fooing around with this design. Here is a schematic of the values i used and how i fixed the cutoff problem.
http://electro-music.com/forum/viewtopic.php?highlight=polivoks&t=23246
I have designed a new Pro PCB. I just need to make sure it is 100% error free. It is to arrive 2 week of December 2008. It is self powered, more like an external modular unit. |
davebr
Joined: Jun 09, 2007 Posts: 198 Location: portland, or
